Old 08-01-2014, 09:29 PM   #29
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Originally Posted by Walla Walla View Post
had a hard time too to lift everything... from driver side, we had to disconnect a few more wire to be able to fit it. passenger side was a piece of cake
but, i will go and buy a new tube for the vacuum. it really seems to short to stay in place, even with the zip-tie
This is how my install went today also the drivers side was a PITA
loved the way it drove, about a 60 mile trip back to my house mostly freeway. Driving up my hill check engine & traction control light pop on
Jmonty is offline   Reply With Quote
Old 08-06-2014, 02:33 AM   #30
ric342
FR-S driver
ric342's Avatar
Drives: ULTRAMARINE Scion FR-S
I second the pvc valve, I would like some assurances that the valve wont come off or loosen, maybe a longer valve
mod on
ric342 is offline   Reply With Quote
Old 08-07-2014, 12:42 AM   #31
Jmonty
They include an extra hose and adapter to extend it.
Old 08-07-2014, 04:06 AM   #32
ric342
FR-S driver
ric342's Avatar
I ended up not using those parts, do u have a pic of the valve after it is extended?
mod on
Old 08-07-2014, 05:20 PM   #33
Jmonty
Bad Picture but here you go
The Following User Says Thank You to Jmonty For This Useful Post:
ric342 (08-08-2014)
Old 08-07-2014, 05:42 PM   #34
Hawk77FT
Drives: GTS 86
I think I might've disconnected something because the revs go high ,drop and the engine dies. It most likely be a pvc line. Any other guesses?
Hawk77FT is offline   Reply With Quote
Old 08-07-2014, 08:01 PM   #35
Jmonty
could be the PVC or I had one of my gaskets pop out and that was causing a vacuum leak
Old 08-08-2014, 04:10 PM   #36
ric342
FR-S driver
ric342's Avatar
i figured it out the same day I quoted u lol
mod on
Old 08-08-2014, 04:21 PM   #37
Jmonty
Sure have been enjoying the different power band with the BPB installed
Old 10-15-2014, 12:17 AM   #38
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
New video BC my old one the audio was lost.
[ame="https://www.youtube.com/watch?v=jcsOr1RlfMw&list=UUOo7XX5p4bbt5L5hAW0R73A"]How to Install Crawford Performace Power Blocks BRZ FRS GT86 - YouTube[/ame]
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 05-15-2015, 05:29 PM   #39
Diz86x
Drives: GT86 Nur spec
did you guys have the check engine light lit up?
Diz86x is offline   Reply With Quote
Old 05-17-2015, 11:12 PM   #40
Jmonty
No check engine light
Old 05-25-2015, 04:20 PM   #41
P5yk0t1c
Drives: 2014 FR-S
That was a tough install for sure, but do able if you take your time. +1 on the cutting of every single piece of black tape you can find. I also took apart every clip I could see. The drivers side is the worst for sure. Running the OFT Stage 2 UEL BPB map.
The car sounds unreal now...so good.
P5yk0t1c is offline   Reply With Quote
The Following User Says Thank You to P5yk0t1c For This Useful Post:
Jmonty (05-26-2015)
Old 06-28-2015, 02:39 PM   #42
Trac Toy
Trac Toy's Avatar
I bought my kit used and I'm missing one washer for the long bolts. Considering the washers are smaller than the actual head of the bolt, what value are these washers?
Are the long bolts just a bit too long and the washers are being used as spacers?
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
The Following User Says Thank You to Trac Toy For This Useful Post:
MoarGeesPlease (05-22-2016)
Third Party Testing: Crawford Billet Power Blocks (BPB / Manifold Spacers) nelsmar Engine, Exhaust, Transmission 295 08-25-2018 03:19 PM
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks Shiv@Openflash Engine, Exhaust, Transmission 129 11-24-2017 07:58 PM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 05:01 PM
***VISHNU*** Crawford Billet Power Blocks: +19HP +15TQ Garrett@Openflash Engine, Exhaust, Bolt-Ons 34 06-11-2014 06:28 PM
Crawford Performance Air Oil Separator install xn7485 DIY (Do-It-Yourself) Guides 10 09-25-2013 08:58 PM
