Old 05-01-2014, 09:25 PM   #141
wparsons
wparsons's Avatar
Sports are fine on the stock shocks, but koni or bilstein would be a nice upgrade. It all depends what you want from them (and the car).
If it were me, I would wait until the stock shocks are worn out, then consider upgrading them or replacing with coilovers entirely.
What's your goal with the car?
I'm running FRS rate Sports on my car, and don't find it bouncy at all. Anyone finding it bouncy, did you trim the bump stops? Were they installed correctly (allen key and pass through socket on the top nut, not an impact gun)?
flickr
Old 05-08-2014, 09:11 PM   #142
mush
mush's Avatar
i dont know if im getting used to it, but the ride is getting much better now
i think im at 2500 miles with the springs on stock shocks, about 2 months since installation
Old 05-10-2014, 04:27 PM   #143
getbent
Drives: 2013 FR-S Blue MT
I have the BRZ-spec swift springs on my FR-S with the factory dampers. The ride was harsh in the winter but now that the weather is warming up I think the dampers seem to be less harsh.
I do wonder whether the Bilstein B8 would be more comfortable since they allow for more suspension travel?
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 05-10-2014, 04:31 PM   #144
8686
8686's Avatar
Drives: 86
I have the BRZ spec with the B8.
I felt like potholes are less felt. But the car was difinitly firmer. I was satisfied.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
The Following User Says Thank You to 8686 For This Useful Post:
Proof (05-17-2014)
Old 05-11-2015, 09:39 PM   #145
CallmeDave
CallmeDave's Avatar
Drives: 13 BRZ, 07 WRX
Bringing these thread back from the crypt.
What else is needed to run these springs with a "good" alignment, I've heard crash bolts, camber bolt all the way to A-arms....
I haven't had any luck getting a straight answer searching.
Thank you
13 BRZ Premium. 07 WRX.
CallmeDave is offline   Reply With Quote
Old 05-11-2015, 09:54 PM   #146
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Thank you
how much camber adjustment are you looking for? If your alignment is not lop-sided like my FRS is, then you'll likely end up with around -2 degrees and change in the rear which is just enough for most situations. With camber bolts out front you can get -2.5 or more when the cars is 1" lower.
You honestly don't "need" anything to run lowering springs besides the springs themselves and alignment. What kind of "alignment" you want will dictate what parts you will require.
The Following User Says Thank You to solidONE For This Useful Post:
CallmeDave (05-11-2015)
Old 05-11-2015, 09:57 PM   #147
solidONE
solidONE's Avatar
"bouncy" can be subjective I guess. I did cut bumpstops when I had them. I wonder how differently the suspension would behave if I hadn't trimmed the bumpstops, especially the rears.
Old 05-11-2015, 10:26 PM   #148
CallmeDave
CallmeDave's Avatar
Just looking to get back to near to the factory alignment.
I've had other cars that when lowered I needed a rear camber kit to dial it back to stock since there is no factory rear camber adjustment. That was on a RSX but I was wondering if it was the story on the BRZ.
Old 05-11-2015, 10:59 PM   #149
solidONE
solidONE's Avatar
If that the case then you wont even need front camber bolts. You'll likely get about half a degree of negative camber in the front, but you will need an upper or lower rear control arm to correct the -2 or more degrees of camber resulting from lowering 1". You can probably get away with just adjusting the toe and leave the camber wherever it ends up from the drop, though.
Old 05-12-2015, 12:33 AM   #150
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Got the Sport BRZ spec Swifts ordered tonight for my 2013 with 22k miles. Wish i could go ahead and do struts too but will have to wait a little while. I'll get some SPC/Eibach LCA's here before install most likely.
Prototype Swift Springs for FR-S mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 09-17-2013 09:36 PM
Stance coilovers with Swift Springs clickfiveZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-05-2013 06:20 PM
Swift springs rate ID subaruferrucci Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 04:26 PM
Fortune auto with swift springs? DarkCard Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 03-29-2013 03:15 PM
SWIFT lowering springs ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 10-31-2012 06:15 PM
