Old 05-11-2015, 06:35 PM   #1
LordTaikun
LordTaikun's Avatar
Drives: 2015 Raven FR-S
TRD lowering springs
So I was looking to get some lower springs for the 2015 FR-S.
I heard that the TRD springs wont void the warranty.
However, on the site they show them compatible for 13,14 and 16 model years.
LINK HERE :
http://www.trdusa.com/parts-detail.h...ring%20Springs
WHY NO 15?!?!
Do you guys know any other parts like this that are just different for the 15?
LordTaikun is offline   Reply With Quote
Old 05-11-2015, 06:55 PM   #2
InspGadgt
InspGadgt's Avatar
Drives: 2015 Scion FR-S (Asphalt)
I believe the front spring rate changed for 2015 so the TRD springs may not have been changed yet to match.
InspGadgt is offline   Reply With Quote
Old 05-11-2015, 06:56 PM   #3
They will be completely compatible with the 15. Probably just an oversight in the write up on them.
Old 05-11-2015, 06:58 PM   #4
LordTaikun
LordTaikun's Avatar
I see, it just seems odd that they already have the 16s up but no 15s.
I ran into a similar thing when trying to find out how to remove the scion logo on the headunit at start up.
Found on the older models it was possible.. no love for the 2015s... which is what got me thinking about my second question in post.
Old 05-11-2015, 07:02 PM   #5
Same head unit in the 14s.
The change in the spring rates on the 15s won't have any affect since by changing the springs you are changing the spring rate anyway. Everything else in the suspension is exactly the same across all the years.
Old 05-11-2015, 07:17 PM   #6
InspGadgt
InspGadgt's Avatar
Ah so the lowered springs are a different rate...Given that they were designed for the previous model years did the TRD springs change the handling characteristics of the car or were they designed to keep the same balance at a lower ride height? If so what affect is that going to have on the 15 and 16 since the front spring rate was changed and something done to the rear (bushings I think?) to make the car turn in aggressively but less tail happy?
Old 05-11-2015, 07:28 PM   #7
They pretty much did the same thing to the 13s and 14s that the changes made to the 15s did. So on a 15 or 16 you will have pretty much the same handling as stock only lower.
Old 05-11-2015, 08:55 PM   #8
SolemnWishes
Drives: 2015 Scion FR-S Series 1.0
RS1.0 includes TRD lowered springs in its package.
So there are definitely TRD lowered springs for 2015 models. And I am with Tcoat that its most likely a typo.
SolemnWishes is offline   Reply With Quote
The Following User Says Thank You to SolemnWishes For This Useful Post:
Tcoat (05-11-2015)
Old 05-11-2015, 09:04 PM   #9
TRD-X
TRD-X's Avatar
Drives: Da-Big Banana
LINK HERE :
WHY NO 15?!?!
Same TRD lowering springs OP here's a link for the 2015 FR-S.
http://www.trdsparks.com/displaypart...&parts_id=5037
The Following User Says Thank You to TRD-X For This Useful Post:
Tcoat (05-11-2015)
Old 05-12-2015, 01:24 AM   #10
LordTaikun
LordTaikun's Avatar
Thanks dude! Its just odd they dont have it on their site Zzz.
Old 05-12-2015, 01:36 AM   #11
trvth
trvth's Avatar
Drives: '15 Halo Scion FRS, 1999 Saturn SC2
I'm wearing the TRD lowering springs on my 2015 FR-S. All good so far (5K miles)
trvth is offline   Reply With Quote
The Following User Says Thank You to trvth For This Useful Post:
stevesnj (05-14-2015)
Old 05-13-2015, 07:08 PM   #12
NA_FRS86
Drives: 2015 Scion FRS
thinking about getting me a set do you have pics?
NA_FRS86 is offline   Reply With Quote
The Following User Says Thank You to NA_FRS86 For This Useful Post:
stevesnj (05-13-2015)
Old 05-13-2015, 07:58 PM   #13
Almost forgot to reply to this part!
The TRD springs (or any other parts for that matter) will not void the warranty if installed by the dealer or somebody authorised by the dealer.
If done yourself or at an "unauthorised" shop the dealer can claim that they were not installed properly and attempt to not honour the warranty.
Chimera (05-14-2015), everythingsablur (09-14-2016)
Old 05-13-2015, 11:12 PM   #14
trvth
trvth's Avatar
TRD springs
Here are some shots of my FR-S with TRD lowering springs. I took these shots with a cell phone at dusk, but I think they show the clearance and the wheel gap OK.
The TRD springs were installed by the dealer as part of the original purchase. However, I did drive the car for ~2 weeks (1200 miles) before the TRD additions were installed (springs, sway bars, quick shifter, cold air intake, exhaust, brake pads). With the springs installed, I can no longer use the side entrance to the parking lot at work; it scrapes. I have to use the shallower main entrance. I like the look and the feel of the springs, but I do have to be more careful about clearance now.
I use her as a daily driver, currently averaging a little under 100 miles per day. I likey.
The Following 6 Users Say Thank You to trvth For This Useful Post:
Chimera (05-14-2015), darthpnoy1984 (07-31-2016), everythingsablur (09-14-2016), stevesnj (05-14-2015), stranger things (11-08-2017), Vic4uf (01-05-2017)
WTB: Lowering Springs Stealthy Want-To-Buy Requests 3 01-17-2015 08:55 AM
trd lowering springs tjohnson104 Brakes, Suspension, Chassis 10 01-09-2015 09:25 PM
WTB trd lowering springs Heyitsryan Want-To-Buy Requests 0 07-20-2014 01:52 AM
Lowering car with springs... What else do I need? SurfAndSand Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-25-2013 11:39 PM
RS*R Lowering Springs Soon to be out! tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-16-2013 03:39 PM
