Old 05-10-2015, 01:58 PM   #25593
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by serialk11r View Post
I actually want to see a dual injector system on a Porsche engine or Honda engine, because they have variable lift. The new Porsche engines strike a decent balance between low end and top end, but the last 500 rpm are only good for making noise. The new Honda DI engines have tons of torque but are choked at the top end too. The 991 GT3 engine has horrible low end torque, but I'm not going to ever own one of those lol.
Ever since the 2ZZ, F20, and K20 died, engines that actually make power to 7500rpm have only existed in exotics or at least 100k+ cars. It would be refreshing to see a counterexample. Come on Toyota, 6AR-GSE? lol...
At this point, my hopes are on Porsche because the Japanese companies seem to have cut off their balls. I'm scared Porsche is going down the 6000 rev limit super high boost route too :/ I'm really hoping I don't have to do a 2ZZ Spyder build because I hate the soft top and luggage space so much.
Goddamit, Serial. You are American. You have ANOTHER car for that practical nonsense.
Heh...
Because titanium.
Dimman is offline
The Following 3 Users Say Thank You to Dimman For This Useful Post:
Allch Chcar (05-10-2015), Tcoat (05-10-2015), Ultramaroon (05-10-2015)
Old 05-10-2015, 02:16 PM   #25594
I cheated.
Thought it was funnier yesterday. Not so much today.
I was pretty baffled since I hadn't seen Crda's post.
Tcoat is offline
Old 05-10-2015, 02:22 PM   #25595
I was mentally high-fiving myself yesterday for being so clever.
It's a good thing I'm ok with being such a dufus. It's even better that my wife is ok with it.
Ultramaroon is offline
cdrazic93 (05-10-2015), Tcoat (05-10-2015)
Old 05-10-2015, 02:57 PM   #25596
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Originally Posted by gramicci101 View Post
@Guff, how's the supra?
You will probably have to be more specific with @Guff .
Which Supra?
Also VTEC Mini?
The Supra is a long story, so I'm gonna try and condense it. Basically, when we bought it, we were told it had a bad headgasket, which was cool because that's easy. We fix everything and finally start her up, only to find that there's still coolant in the oil. We assume there must be a crack in the block, so we send the block and head to the machine shop to get inspected. Machine shop says it's likely a crack upon initial inspection, so we go ahead and buy a new block. Send this block to the machine shop and turns out it's got damage from crankwalk, and it ends up being useless. Then, we are planning to get a third block, when the machine shop calls and tells us, he finally got around to doing a more extensive inspection, and there is no crack, and most likely the block just needs a good deck. We have him deck, bore, and hone the block, get him some CP 10.5:1 pistons and Eagle rods, as well as a whole array of new OEM parts and say, whip us up a monster.
So, we should be getting a mostly assembled 3.2L 2JZ sometime this week. Then, we shall burn the midnight oil and get this bad boy together. Then we will wait the painfully long time to get a tune at Sound Performance, and the car will be done. Hopefully making lots of horsepower on E85. Fingers crossed, we'll see something with four digits, even if it's just crank numbers.
As far as the Mini goes, it's at my parents place in Dallas, so I never get to work on it. It needs brake lines, a seat, some modifications to the shifter, a real fuel cell, a little bit of wiring clean up, and then it's driving around. Then I need to finish the fender flares, mount the front clamshell, send it to the body shop for paint and reassembly, and the car is finished.
Edit: I should mention, I'm talking about the Red 94 6-spd Supra. The Green 93 5-spd, is chilling in my other brothers garage in Dallas waiting for me to show up so we can fix some oil leaks.
- The Ancient BRZ Sacrament
by Zaku
Guff is offline
The Following 2 Users Say Thank You to Guff For This Useful Post:
Dimman (05-10-2015), gramicci101 (05-10-2015)
Old 05-10-2015, 02:58 PM   #25597
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Crda
Crda...hmmm....seedra, cydra, hydra! Cool im a hydra now i can eat 5 hambergers at once!
cdrazic93 is offline
The Following User Says Thank You to cdrazic93 For This Useful Post:
Tcoat (05-10-2015)
Old 05-10-2015, 03:02 PM   #25598
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Jesus christ. Just cut the end off one of those still useful blocks and weld the shit out of it onto the new one. Bam, inline 12. One badass supra.
Or if engine bay space is a problem, lol. Just conjoin at a common crank. Then double bam, V12 fer ya trubles.
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
Guff (05-10-2015), Tcoat (05-10-2015)
Old 05-10-2015, 03:08 PM   #25599
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
So since Dadhawk has Momhawk, would your wife be, Mrs. Maroon, or Megamaroon?
Dadhawk (05-11-2015)
Old 05-10-2015, 03:36 PM   #25600
Ultratolerant
The Following 7 Users Say Thank You to Ultramaroon For This Useful Post:
cdrazic93 (05-10-2015), Dadhawk (05-11-2015), Dimman (05-11-2015), gramicci101 (05-10-2015), Guff (05-10-2015), Special_K (05-11-2015), Teseo (05-11-2015)
Old 05-10-2015, 03:59 PM   #25601
gramicci101
Off Topic
So, hypothetically, say there's a album you want, and you notice that if you get it from Best Buy it comes with an exclusive track that you can't get on iTunes. Simple enough, right? Just go to Best Buy and get it. Except that the first two stores don't even carry music anymore, and the third one has a single small rack for all genres. "Oh, it came out in 2013? No, we won't have that. But here's 14 copies of John Denver for you." ... Thanks.
What if there were no hypothetical situations?
gramicci101 is offline
Old 05-10-2015, 04:18 PM   #25602
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I would probably just buy it off Amazon, you get the CD and able to download it.
Then I would download the exclusive track from a group of connected peers... If you know what I'm saying.
Andrew025 is offline
Old 05-10-2015, 05:17 PM   #25603
serialk11r
Drives: '06 AM V8V Coupe
Heh...
The 86 IS the practical car lol, and unfortunately it eats the whole budget for now. If I end up doing a Spyder build it's going to be pretty crazy and cost way too much money.
serialk11r is offline
The Following User Says Thank You to serialk11r For This Useful Post:
Dimman (05-11-2015)
Old 05-10-2015, 05:21 PM   #25604
I'd like to see the math.
Old 05-10-2015, 09:25 PM   #25605
babydriver
Hit the road and I'm gone
babydriver's Avatar
Because Cruise is not human. He is a clone that they just grab a new one of for each movie.
We knew that. Didn't you see "Oblivion"?
Slip, slidin' away.
babydriver is offline
Old 05-10-2015, 09:30 PM   #25606
gramicci101
Off Topic
Woo! I made someone's signature block!
