Old 05-10-2015, 12:15 PM   #43
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
So where's the audio files?
Old 05-10-2015, 12:21 PM   #44
Teseo
Drives: frs
Sound clip will be apreaciate
Old 05-10-2015, 01:15 PM   #45
cslntuee
Drives: Subaru BRZ Limited
Anyone know the aftermarket catted manifold with heat shield have
chance to pass the smoke test in CA?
I just relocated to CA. ><
Thanks.
cslntuee is offline   Reply With Quote
Old 05-10-2015, 02:11 PM   #46
churchx
churchx's Avatar
Drives: 2014 GT86
It might slightly increase chances but i wouldn't bet on that. For sure shot upgrade catback only. Yes, header upgrade may net most gains, but imho something like Perrin's 3" + TRD intake (IIRC also certified in CA) + tune might get 2/3rds of planned gains with leaving stock header/cats in place. It might be too loud with catless header, but with stock probably within reason.
Old 05-10-2015, 06:23 PM   #47
steve99
Drives: FT86
Thanks.
alternative
leave car stock (or at least header and cats)
As you only have access to 91 fuel in CA your hp is down a bit anyway
Just get an E85 tune and run E85 you will get about 20hp with E85 tune/fuel on a stock car.
come emmissions check flash or switch back to petrol. takes five minutes , no spanners.
cslntuee (05-11-2015)
Old 05-13-2015, 01:12 PM   #48
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
alternative
Don't forget in the US we use R+M/2 while in AZ ou guys use just a RON rating. Our 93 is comparable to your 98. While 91 is everywhere, we can get 93 and 100 R+M/2 in limited locations. My avatar is my car at the pump filling up with VP Racing 100 octane R+M/2
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
steve99 (05-13-2015)
Old 05-13-2015, 02:12 PM   #49
churchx
churchx's Avatar
Drives: 2014 GT86
It's sounds a bit weird to me, as goes against stereotypes of few decades ago, when 'american' seemed to be only low compression big displacement running on low octane. But now - it's other way around, with petrol being shittier on this side of pond.
Old 05-13-2015, 11:27 PM   #50
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Interesting. clean looking and have an option for cat and can use OE cover is always nice.
Very tempting...
Old 05-13-2015, 11:36 PM   #51
steve99
Drives: FT86
Was more think)ng along the lines of its easier to get 20hp with e85 and tune on stock car with all cats ect , 5 mins to flah back
Hyper4mance2k (05-14-2015)
Old 05-15-2015, 08:05 PM   #52
aFe POWER
aFe POWER's Avatar
Drives: 2014 Scion FRS
Got these in stock!
aFe POWER is offline   Reply With Quote
Old 05-16-2015, 05:59 AM   #53
Sphirit
Drives: GT86
we want sound clips please!
Sphirit is offline   Reply With Quote
Old 05-25-2015, 07:25 AM   #54
gms
gms's Avatar
Drives: Toyota GT 86
This seems a fine piece to me so I decided to go for it.
@all non US buyers: They won`t ship outside US, by contacting them I was told to purchase from summitracing or amazon.com. Both don`t have the header listed until now... So I asked for an alternative but no response... I hope the product is better than the contact :-) ... Found it finally on my own @bekkers.com with acceptable shipping costs!
The Header will be combined with Perrin 2,5" resonated headerback, aFe Intake, crawford pbp and OFT. Will post before/after results!
gms is offline   Reply With Quote
The Following User Says Thank You to gms For This Useful Post:
Bonburner (05-25-2015)
Old 05-25-2015, 09:00 PM   #55
aschnell
So i picked one of these up. Got it for the weekend to have time to install. Header looks nice, got it with the cat. Install went fine except the time I wasted with the stock heat shields. Used a crows foot for the middle nuts, couldn't get a socket on them.
Couple of notes.
1. It does NOT fit the stock heat shields. I asked this specifically because I saw mention of it probably in this thread. They told me they would fit after I specifically asked again. Not even close. Wasted my time testing that, going to have to have a chat with the afe guys on that one. They thinking of the skid plate? I feel a little misled. Might have gotten a coated header instead.
2. Front O2 sensor cable ends up a little short. There are two stock cable tie mounts, had to leave one off to keep the cable from being pulled too tight. The rear ends up longer than necessary, but both are ok.
3. Sound. I still have the under tray off so I could drive it and then retorque the fasteners. To me sounds pretty much stock, that's what I wanted. Driving around with the windows down I hear a little more noise but the skid plate is off still.
4. Performance. I have an oft. Also just put in an afe dry panel filter at the same time. Stock otherwise. Running stage 2 93 el tune. Wanted to reduce the torque dip mainly, and I am happy with the end result so far. No dyno, just feel so far. Engine feels much more linear.
aschnell is offline   Reply With Quote
The Following 3 Users Say Thank You to aschnell For This Useful Post:
Bonburner (05-25-2015), JDM4E (04-03-2018), SCFD (11-08-2025)
Old 05-26-2015, 01:07 AM   #56
churchx
churchx's Avatar
Drives: 2014 GT86
Interesting. I hope vendor will comment on (1.).
afe power, fr-s & brz, header, scion, steveforgottosaymicdrop, subaru
Exedy OEM Replacement Clutch Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 **New Site** RallySport Direct Transmission and Driveline 59 09-01-2015 12:18 PM
FS: APR Brake Duct Hose and Backing Kit BRZ / FR-S $275 kanundrum Brakes, Suspension, Chassis 4 04-24-2015 11:24 AM
Beatrush Over Pipe Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 RallySport Direct Engine, Exhaust, Bolt-Ons 17 03-16-2015 11:29 AM
Product Release! Mishimoto Peformance Aluminum Radiator for Scion FR-S / Subaru BRZ! Mishimoto Announcements, Contests, Giveaways 1 10-01-2013 11:44 AM
New Product Release: StopTech Big Brake Kits for Scion FR-S and Subaru BRZ !!! PRO Import Tuners Brakes, Suspension, Chassis 16 08-24-2012 07:59 PM
