Old 05-09-2015, 01:04 PM   #2241
keithr
keithr's Avatar
Drives: 2014 BRZ Limited (DGM)
Originally Posted by dj2020 View Post
Just wanted to share my numbers on this thread:
262 whp
208 ft lbs
CARB Tune
Is the JRSC your only performance mod for these numbers?
keithr is offline   Reply With Quote
Old 05-09-2015, 01:10 PM   #2242
dj2020
Yup. My only other mods are MXP catback and JRSC oil cooler. Cats still meowing in stock exhaust manifold and front pipe.
dj2020 is offline   Reply With Quote
The Following User Says Thank You to dj2020 For This Useful Post:
keithr (05-09-2015)
Old 05-10-2015, 04:37 AM   #2243
alpax
alpax's Avatar
Drives: 2013 Subaru BRZ AT JRSC
262 whp
208 ft lbs
CARB Tune
This was done on Shawn Church's Dynapack here in Las Vegas. The car is a blast to drive!
https://docs.google.com/file/d/0B_np...p=docslist_api
The scan says "Flywheel" power and torque, so it seems like not WHP, but crank HP numbers, which could be directly compared to the stock 200 HP. Power at the wheels then would be around 222 whp/176 lbft, which is actually very close to what I got on a VirtualDyno.
alpax is offline   Reply With Quote
The Following User Says Thank You to alpax For This Useful Post:
dj2020 (05-10-2015)
Old 05-11-2015, 12:13 AM   #2244
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
So I ordered my kit April 27, hope I see it in May?
Jmonty is offline   Reply With Quote
Old 05-11-2015, 12:30 AM   #2245
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
That unusually low isn't it? I thought the carb tune gets you over 250 to the wheels.
Edit: My bad a little over 240 to the wheels. This dyno is from CSG Mike's Dyno
https://fbcdn-sphotos-e-a.akamaihd.n...85657793_o.jpg
http://www.ft86club.com/forums/showthread.php?t=54157
Alltezza is offline   Reply With Quote
Old 05-11-2015, 01:13 AM   #2246
alpax
alpax's Avatar
It's difficult to compare apples and oranges: we all had different measuring systems. VirtualDyno is, well, "virtual" , so cannot be taken as a hard argument. dj2020's graph is from Dynapack, and shows flywheel data. And Mike's results are from Dynojet. BTW, Dynojet AFAIK usually gives high numbers.
I would guess we all should have got similar results, as all tests were with CARB tune on otherwise stock cars. Just different numbers from different dynos.
Old 05-11-2015, 01:35 AM   #2247
dj2020
When it comes down to it, I wish I had done a baseline stock dyno pull for a good delta comparison. I didn't even realize Church's dyno read "flywheel" on the graphs I posted. For what it's worth, his Dynapack reads at the hub since my wheels/tires are removed for the pulls. This theoretically should mean higher readings than a dynojet/mustang dyno because the wheels/tires are not there to contribute to more drivetrain loss. (This is all speculation on my part. Far from being an expert). My butt dyno nonetheless is enjoying the power increase. The induction, spooling, and bypass noises are pretty awesome too! Cheers to everyone getting their kits soon. You guys won't be disappointed.
Old 05-11-2015, 02:54 AM   #2248
CSG Mike
CSG Mike's Avatar
I should probably note that it's a heat soaked run, without an oil cooler.
We don't do hero dynos at CSG, but if we wanted to, it would read much higher on a "hero" run. This dyno reflects realistic output when you're driving it hard.
Old 05-11-2015, 02:56 AM   #2249
CSG Mike
CSG Mike's Avatar
Church's dynapack reads hub horsepower.
The CSG car baselined about 172-173 on Shawn's dyno, which is virtually identical to a non-adultrated dynojet, on a car with zero toe (such as the CSG car). Alignment will affect readings on roller dynos, but not on hub dynos. We've baselined on a LOT of dynos, so we know how the numbers compare at various shops, and specific dynos.
Dynapacks are our tuning tool of choice.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
dj2020 (05-11-2015), Jmonty (05-12-2015), sachu (05-15-2015), wparsons (05-16-2015)
Old 05-15-2015, 05:46 AM   #2250
264grendel
Drives: 2013 Scion FR-s
Any update on how backed up JRSC is on shipping out orders? Are people still waiting about a month for shipments?
264grendel is offline   Reply With Quote
Old 05-15-2015, 01:23 PM   #2251
Germanjap
Drives: 2013 JRSC Firestorm FR-S
Ordered JRSC on May 4. Was told today another 2-3 weeks. So about a month for shipment.
Germanjap is offline   Reply With Quote
Old 05-15-2015, 01:40 PM   #2252
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
We have 3 kits on backorder for install. All of them require engine oil cooler kits so the clog is at that end. Otherwise we should be having them ready after the week of the Memorial Day. Fingers crossed of course. If you want to get in the queue, please send us a PM! Thanks!
CounterSpace Garage is offline   Reply With Quote
Old 05-15-2015, 01:55 PM   #2253
sachu
Drives: rocketship
While its not the reason why I chose VitViper of VitTuned, given he knows his shit unlike anyone else i have met here in the pacific NW, I wasn't surprised he's been tuning on dynapacks as well.
My car with stock tune with all the bolt ons baselined at 166 on his DynaPack while it showed 186 on Drift Office's Dynojet. After tune ended at 180 peak on VitTuned's dynapack.
Been meaning to hit you up with a PM by the way about alignment.
sachu is offline   Reply With Quote
The Following User Says Thank You to sachu For This Useful Post:
CSG Mike (05-15-2015)
Old 05-15-2015, 02:25 PM   #2254
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
I would actually argue the opposite...
Dynojets are giving about 170whp stock. Which is dead on for a 15% drivetrain loss which is pretty typical for a RWD. Others give about 155whp which probably isn't as accurate. I prefer dynojet numbers because of this.
I also prefer crank numbers if you don't have a baseline. This is one of the reasons that people compare percentage of gains rather than gains versus bhp from the factory.
The problem is the estimation of crank hp when almost no one is pulling the engine to run on a crank dyno.
For example, power to weight not withstanding, comparing a v6 mustang 308hp to a s/c'd twin with 300 whp isn't even close. It's going to be closer to 345 bhp on the twin.
Jaden
Jaden is offline   Reply With Quote
The Following 2 Users Say Thank You to Jaden For This Useful Post:
CSG Mike (05-15-2015), Xero-Limit (05-15-2015)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
