Old 05-08-2015, 12:20 AM   #1303
churchx
churchx's Avatar
Drives: 2014 GT86
Khyron686: imho there is one way to eat cake & have it too, if you like those 235/45r17 that much. Install slightly different final gear ratio kit. It might not be enough to compensate speedo changes, but imho it will fix slower acceleration.
Old 05-08-2015, 08:40 AM   #1304
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
"Meaty" is about tire width, not sidewall. Tires are sometimes referred to as Meats and when you say a car has a lot of meat under it, or that it is "laying down a lot of meat" it means it has wide tires. Sidewall doesn't come into it. A 265/35 is meaty. A 185/70 is not.
Old 05-08-2015, 08:50 AM   #1305
pleong
Drives: 2013 Whiteout FR-S
Is 295/30 meaty?
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 05-08-2015, 09:04 AM   #1306
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Originally Posted by pleong View Post
Attachment 109093
Is 295/30 meaty?
Please refrain from posting your car anymore before you cost me more money
BRZZZZZZZZZZ is offline   Reply With Quote
Old 05-08-2015, 09:31 AM   #1307
stevesnj
stevesnj's Avatar
I was wondering why the pics were dead on the side of the wheel and tire and not showing the tire width from below... kids!
My 2016 Build thread
Old 05-08-2015, 10:52 AM   #1308
BRZZZZZZZZZZ
Car Nut
Old 05-08-2015, 10:42 PM   #1309
dito
Drives: SWP BRZ
hey guys so I'm running 245/40/18 on 18x9.5 +34 and on st coilovers. My camber is -1.8 front left and -1.6 front right. rear left is -2.5 and rear right is -2.8. i rub going up driveway or dips at an angle and rub when i hit a dip or bump if I'm not going super slow. not sure what to do thanks in advance.
dito is offline   Reply With Quote
Old 05-08-2015, 11:17 PM   #1310
Vampyre
Vampyre's Avatar
Drives: 2014 FR-S Asphalt
Originally Posted by BRZZZZZZZZZZ View Post
255/40/17
What wheels are this?
Vampyre is offline   Reply With Quote
Old 05-08-2015, 11:27 PM   #1311
ajaxthebetter
Drives: 2014 Subaru BRZ LTD 6MT
Think they are 720 Form GTF1. Fourth page back in this section--can't get link to work.
ajaxthebetter is offline   Reply With Quote
Old 05-09-2015, 12:00 AM   #1312
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by Khyron686 View Post
Wide Tire Nation:
funny how you post appropriate tires to make your point, but then stretched tires with no sidewall to show how width is irrelevant.
any photos?
with that offset you really should roll your rear for some clearance, thats also a lot of camber in the rear with a not that large of a tire (assuming you went 245 for clearance?)
how low are you? reason i ask is ST are a bit on the softer side, so if you're slammed, it makes sense why you rub because your wheels don't fit.
post a photo and we should be able to help you out. i'm assuming your'e talking about tire rubbing, not ground clearance issues. do you have any markings in your tires? good way to see where you are rubbing is to chalk your sidewall. many do it at auto-x, including myself, to see if they are rolling over and should add or take away pressure.
Jive Turkey is offline   Reply With Quote
Old 05-09-2015, 12:08 AM   #1313
Vroomin86
Drives: 2015 Fire
Vroomin86 is offline   Reply With Quote
Old 05-09-2015, 06:09 AM   #1314
dito
Drives: SWP BRZ
any photos?
this is how my car sits rn. and yes im mainly talking about fender tire rubbing. i can go over dips and bumps fine. thanks !
image hosting adult
Old 05-09-2015, 02:13 PM   #1315
Skurj
Drives: SOLD...
and nvm... a 245/40/17 RS3 v2 is wider than a 255/35/18 V12 EVO
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 05-10-2015, 04:09 AM   #1316
Thatguyjeremy
Drives: 13' Asphalt FRS
Wide Tire Nation:
275/25R20
345/25R20 !!!!!!!
If only there was a measurement on the tire, that expresses the ratio of width to sidewall....
I tease, I know what you're after, but if you need to read the tire measurement to know its meaty factor, that's not a good way to do it.
Meaty CRX - even though it's only a 195 wide tire.
My favorite meaty/not-balloon size on the twins is 235/45r17 - just looks so nice. But I didn't want to deal with the slightly slower accel.
I have 235/45 on my 17x9s... it does look very nice and "meaty" and as for the slower accel, meh its barely noticeable.
IG: __thatguyjeremy
Thatguyjeremy is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
