Old 05-07-2015, 08:37 AM   #1
FRSupra
FRSupra's Avatar
Vaseline to repair interior scratches
Is anyone familiar with this? Apparently rubbing some Vaseline on scratches in the plastic will make them all but disappear?
FRSupra is offline   Reply With Quote
Old 05-07-2015, 08:53 AM   #2
Will work, but only in the short term. It will dry out and then things look even worse. Better off spending a few bucks and getting one of the better purpose made products.
Bonburner (05-07-2015), FRSupra (05-08-2015), OverSpent (05-07-2015)
Old 05-07-2015, 09:49 AM   #3
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
know any off the top of your head?
Old 05-07-2015, 03:18 PM   #4
I just use the original Armor All protectant gel. I don't do every thing in it just scratched or scuffed areas.
Old 05-11-2015, 12:33 AM   #5
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
I use spit and my thumb like a real man.
Instagram: stimson
The Following 6 Users Say Thank You to Turbo95eg6 For This Useful Post:
BlueSky (05-22-2015), brandonblt2 (06-26-2015), mb_ (05-22-2015), NyC Zn6 (06-23-2015), taguilar18 (08-12-2015), Tcoat (05-12-2015)
Old 05-12-2015, 01:12 AM   #6
jarednoel
Drives: Asphalt
I get scared of using ArmorAll because of the myth that it inhibits cracked dashes in the future from all the chemicals. :/
Somehow, I like Chemical Guys stuff since it's water based.
jarednoel is offline   Reply With Quote
The Following 2 Users Say Thank You to jarednoel For This Useful Post:
Packofcrows (06-02-2015), Tcoat (05-12-2015)
Old 05-13-2015, 03:59 PM   #7
RickyBobby
Drives: 2013 Firestorm FR-S AT
Eventually we all get them on the interior plastic panels, from scuffs to deep scratches, especially in the trunk and at the bottom of the front door panels.
From a Google search I found a number of things that others have tried: from replacing the panels, taking the panels out and spraying them, to using Vaseline/petroleum jelly, toothpaste, Magic Erasers, Sharpies, crayons, 303 Aerospace Protectant, Armor All, Novus Scratch Remover, PlastX, Mother’s Back to Black, heat guns, vinyl dye or plastic paint.
What method will work is dependent on how deep the scratch is.
Our 2008 Nissan HB had an assortment of scratches on the black plastic panels in the cargo area that I wanted to fix before I traded it in.
I'm pretty certain that these panels are made from polypropylene, PP. The only way to be certain is to take the panel off and check the SPI code, PP is 5. I didn't want to take the panel off.
The scratches were not deep enough to fill in. I used some 400 grit sandpaper to sand them smooth. I then wiped the area with 91% isopropanol (available at Walmart) to clean any left over release agent off. Since the plastic is textured you have to be careful not to sand too much. If the scratches are deep you will need a filler like this: http://www.jbweld.com/products/plastic-bonder-syringe
I first tried some of the methods I had come across and what I had on hand. Vaseline, Armor All, and Mother’s Back to Black do not work on scratches, maybe on very light scuff marks. Mother's Back to Black is mainly for oxidized exterior plastic and rubber.
I do not have a heat gun so I tried my wife's 1500 W hair dryer. PP has a MP of 160 - 170 C but the hair dryer at its highest heat setting didn't even soften it.
A black Sharpie was too black and had a purplish hue.
My wife who does a lot of tole painting suggested I try an acrylic paint. She uses them on plastic with no problems. I didn't want to use a spray paint or vinyl dye in the car.
The panels are a satin black. I found a small bottle of multi-surface satin black acrylic paint at Hobby Lobby for $1.69. This brand is also available at other stores. http://www.decoart.com/multisurface/
I used one of my wife's small artist brushes to paint the scratches, let dry; then used a blending technique she uses by mixing the paint 1:1 with water and a 1" artist's brush to blend the color into the rest of the panel. For fine scratches just painting them with a thin artist's brush should be sufficient.
Not perfect but good enough to trade in.
After sanding and wiping with isopropanol. The panel is black but photographed gray since the car was out in the sun.
After painting
RickyBobby is offline   Reply With Quote
The Following 3 Users Say Thank You to RickyBobby For This Useful Post:
kch (06-03-2015), sprintertrueno86 (05-21-2015), TofuJoe (06-22-2015)
Old 05-21-2015, 06:54 PM   #8
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
My center console piece is scratched where it extends to my back seat. I had a piece of MDF in my backseat with a sharp edge not realizing it would scratch the plastic. I'm probably just going to buy a new panel instead of finding ways to fix the damage.
How you looked into the price of panels? I don't think most of them are that expensive.
B-R-Z is offline   Reply With Quote
Old 05-21-2015, 07:09 PM   #9
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
This thread was not what i was expecting
The Following User Says Thank You to cdrazic93 For This Useful Post:
continuecrushing (05-22-2015)
Old 05-21-2015, 10:29 PM   #10
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
be very careful, but you can use a heat gun as well to get rid of scuffs and scratches. I use it here in the Lexus plant that I work in.
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 05-22-2015, 08:19 AM   #11
andrillox
Drives:
How can I achieve this? I have a heat gun.
andrillox is offline   Reply With Quote
Old 05-22-2015, 08:56 AM   #12
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
This thread is surprisingly more SFW than I expected!
Subaru STI :
The Following User Says Thank You to Kimsey47 For This Useful Post:
Tcoat (05-22-2015)
Old 05-22-2015, 09:08 AM   #13
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Are we still talking about cars?
Old 05-22-2015, 11:06 AM   #14
Triumphrider
Just warming it with the heat gun will cause the scratches to lose the white edge and make the scratch pretty much invisible
The Following User Says Thank You to Triumphrider For This Useful Post:
wbradley (06-02-2015)
Interior scratches Craigo Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 14 06-21-2014 12:00 AM
DCW Carbon Fiber interior items! Center console Plaques / Interior panels doggy Interior Parts (Incl. Lighting) 143 10-11-2013 11:17 AM
Interior small plastic scratches, any working products yet? OICU812 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-03-2013 11:04 PM
LED interior conversion kits (interior), USA stock & warranty WTF Interior Parts (Incl. Lighting) 0 05-22-2013 10:17 PM
Scratches on interior trim AlexTheGreek BRZ First-Gen (2012+) — General Topics 25 02-25-2013 03:47 PM
