Old 02-11-2015, 03:40 AM   #113
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
So since Motul 8100 0w-20 is SM rated not SN does that mean it is not recommended for e85? Would it matter for non-regular use of e85 (like once every 5 fillups)?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 02-11-2015, 03:42 AM   #114
l0aded
Addicted
l0aded's Avatar
Originally Posted by k.houan View Post
Havent seen any mention of ENEOS 0W20. I just bought some and was curious if I would be ok running E85 while using this oil?
Cant really find any info about this oil and E85 specifically.
Any input?
I have the same question.
Old 02-11-2015, 05:28 AM   #115
ZZT86
ZZT86's Avatar
Drives: BR86
SN is latest spec and is specifically tested for E85 use & therefore deals with it best. Having said that I have in the past used SM/GF4 Castrol Edge 0W20 & it performed well with high TBN of 5.4 & no fuel dilution after 3000miles on the juice.
ZZT86 is offline   Reply With Quote
Old 02-18-2015, 04:13 PM   #116
07jazzrs5gt86
Drives: Firestorm 86
I'm curious what kind of oil filter you guys using?
OEM
Fram ( regular / synthetic )
Bosh ( regular / synthetic )
Other brands
Thanks
I'll be changing oil this weekend for e85
Planing on using Pennzoil platinum ultra 0-30w
Still have 1 OEM filter but was thinking using fram synthetic selling for $11 or bosh synthetic $13
07jazzrs5gt86 is offline   Reply With Quote
Old 02-23-2015, 01:07 AM   #117
tracerit
Drives: '13 SSM BRZ Limited 6MT
Originally Posted by Phantobe View Post
Pretty much what I read but then you have people buying amsoil & motul 8100 which is like ~$100/oil change.
I think I'm going to give Mobil 1 0W-20 a try. I asked sportsguy83, he's a long time E85 user & thats what he uses. I'll just change every 3500 miles, there have been no failures yet on E85 afaik so thats a good sign. We already know from the WRX & STI that subie motors like the E85. Not to mention the fact that I'm sure many people are running E85 unaware that they're supposed to change oil more frequently.
I'm intrigued by this as well since E85 seems to ask for 3000mile between oil changes. May consider going with the Mobil 1 0w20 which seems to be $27 for a 5-qt jug and $7 for 1-qt bottle. Compared to $70 for 6-qt of Eneos Sustina 0w20.
tracerit is offline   Reply With Quote
Old 02-23-2015, 04:23 PM   #118
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
Moving from Royal Purple 0w-20 (not HPS) to Redline 0w-20 (SN rating for E85 and forced induction) for my 1yr oil change next month.
Vortech SC V3 // 3.12 Pulley // Moto-East Tune (93oct,e40-50,e85)
sissupr is offline   Reply With Quote
Old 02-25-2015, 02:19 PM   #119
DC2R
Drives: 2014 Scion FR-S
About to come up on first non dealer oil change. Do I need to tell dealer
DC2R is offline   Reply With Quote
Old 02-25-2015, 02:19 PM   #120
DC2R
Also seems best cheap oil is Pennzoil or Quaker, yes? Should I bother getting OEM filter?
Old 05-06-2015, 03:27 AM   #121
kchar
Because Racecar
kchar's Avatar
Hey I'm kind of confused as to why some people were saying to go with the Royal Purple's HPS series over the normal oil. The back of the bottles I've been using say its SN/GF5. From reading the thread the HPS series is better due to increased detergent level so is the consensus that the regular oil is usable but the HPS would be preferable?
kchar is offline   Reply With Quote
Old 05-06-2015, 08:02 PM   #122
bluesubie
Drives: 2004 Subaru Forester 2.5XT
E85 specific oil
You'd need a uoa/voa to find out for sure, but I believe the additive packs on the HPS oils have higher detergent levels than the regular GF5 oils. I know they have more ZDDP.
From memory, the HPS oils are similar to the older RP API SL oils. When I did a google search, I found an older regular RP 5W20 that contained normal calcium levels and very high magnesium levels. Rotella T6 has very high magnesium levels as well.
You can also just email Royal Purple and tell them you want a higher detergent oil for E85. Although current API SN/GF5 oils are supposed to be better for E85 use.
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
kchar (05-06-2015)
Old 05-20-2015, 03:26 PM   #123
jaf89f
jaf89f's Avatar
Drives: Raven MT
Here are the responses I received when contacting Amsoil and Motul regarding the recommended oil for daily driving on E85:
Amsoil
"If you are using E85 fuels we would recommend using the original equipment 0W-20 because there is no extended drain with E85 fuels...if the OEM recommended interval is 7,500 miles, Amsoil Inc. recommends using our XL or OE line of products."
http://www.amsoil.com/shop/by-produc...?code=XLZQT-EA
http://www.amsoil.com/shop/by-produc...?code=OEZQT-EA
Don't know why the signature series wouldn't work as well here, may just be overkill I guess.
Motul
Per a phone conversation, 8100 Eco-Lite 0W-20 was recommended for daily driving w/ the occasional spirited canyon session, as 300V is typically overkill in that particular scenario since 300V is more so for racing applications.
OpenFlash Tablet Tune v2.06 E85 Stage 1 - Grimmspeed Intake, Strut Tower Brace & Master Cylinder Brace - MTEC Clutch & Shifter Springs - TRD Quickshifter - cQuartz Finest Paint Protection Coating - and more to come...
jaf89f is offline   Reply With Quote
Old 05-21-2015, 07:10 AM   #124
steve99
Drives: FT86
Best to look at manufacturer data and make sure its recomended for E85 use
example
http://www.penriteoil.com.au/product...id_fuel_type=6
Old 05-21-2015, 07:57 AM   #125
ZZT86
ZZT86's Avatar
Drives: BR86
Only problem with the Motul is that none of their 0W20 stuff is rated SN. I would use one of the Amsoil 0W20 products for a DD.
Old 05-21-2015, 10:44 AM   #126
DC2R
Amsoil
Motul
So they say top keep to the recommended 7500 changes, huh?
Changing my oil this weekend. Maybe swap it out at 5k
WTB: UEL HEADERS! Non specific Asian Delight Engine, Exhaust, Bolt-Ons 1 02-07-2014 04:51 PM
Specific Vishnu OFT threads... Tromatic Software Tuning 6 12-07-2013 03:09 PM
Looking for a specific spoiler ... Need help finding it. pwnisher Cosmetic Modification (Interior/Exterior/Lighting) 8 07-10-2013 10:56 PM
Anyone know where to get FR-S specific key chains? mmieszanek Scion FR-S / Toyota 86 GT86 General Forum 4 02-26-2013 04:28 PM
Specific iso bdanisi Engine, Exhaust, Transmission 1 02-12-2013 09:31 PM
