Old 05-04-2015, 09:50 PM   #1443
knipple
Drives: 2013 Ultramarine Scion FR-S
Originally Posted by BrandonB View Post
Do you get any drone with this setup?
What do you mean by drone? I don't have a lot of experience with exhausts, so I don't know what drone is.
If I am holding constant throttle and not trying to accelerate or decelerate, I can't hear the exhaust, however, the instant I accelerate or decelerate it gets louder, but I would not call it annoying.
knipple is offline   Reply With Quote
Old 05-04-2015, 09:58 PM   #1444
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Originally Posted by knipple View Post
Here is a video of me at an autocross to give an idea of what it sounds like. I have the JDL UEL, JDL 3" Overpipe, JDL 3" catted Front Pipe, and a Perrin 3" resonated exhaust.
P.S. we run a sound meter following the SCCA rules, which is 50 feet away to the side at a location where most cars will be WOT. I barely broke 83 dB.
This is almost the exact set up I am about to finish installing. The only thing different is I decided on a resonated and catted FP/OP combo. Glad to see 3" header back on JDL's UEL isn't as loud as resident experts said it would be. The next question will be did you choke at lower RPM or lose power due to lack of "back pressure"?
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 05-05-2015, 08:55 AM   #1445
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Originally Posted by UnOvertime View Post
You will enjoy the sound with the Grip and the JDL setup. No rasp but, it is definitely louder and sounds like it always should have sounded.
I am going to install the JDL UEL catless header and over pipe, hah.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 05-05-2015, 04:23 PM   #1446
knipple
I have not noticed a loss of power down low. The major change I have noticed is that the torque dip seems to not be as dramatic as before.
I will be getting dyno tuned this weekend to get as much additional power/torque as possible out of my setup.
Old 05-05-2015, 09:15 PM   #1447
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Got back under the car today to see about that hose issue.
Here's how close they are:
DEI recommended a Fire Sleeve for the hose, but I couldn't find one in-town. So I used both a header wrap and an aluminumized sleeve. I slit the sleeve and wrapped it around the hose and wrapped just the area of the primary that is near it.
Here's from above. It's difficult to see, so hopefully it won't attract too much notice.
Btw, that's what happens to your engine after just one winter.
I was able to take it out for a drive up to temperature. It sounds MUCH better. But something is hitting when I engine brake over bumps, and I think there's another part touching the chassis. So I need to get back under it and try and track down where the odd vibration are coming from. Guess I have tomorrow's evening planned.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
BigFatFlip (05-05-2015), tato.valverde (11-17-2015)
Old 05-05-2015, 11:09 PM   #1448
congiiee
Drives: WRB Subaru BRZ
I tried skimming through this thread but couldn't find much information in regards to the CATTED UEL header vs the CATTED EL header in terms of performance. Has anyone compared the two?
congiiee is offline   Reply With Quote
Old 05-05-2015, 11:16 PM   #1449
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by Draco-REX View Post
What's up with the oil?
Old 05-06-2015, 08:23 AM   #1450
Draco-REX
Corner Junkie
Draco-REX's Avatar
Changed the filter without giving it time to drain. I might have accidentally loosened the sandwich a smidge also. But it's not leaking any more, so I'm going to check it at my next change.
Old 05-06-2015, 09:49 PM   #1451
Draco-REX
Corner Junkie
Draco-REX's Avatar
Back under the car tonight to sort out the contact. The overpipe had plenty of clearance. But to be sure, I loosened both ends and made sure I had the maximum of space around it. Upon further inspection, I found that the #4 primary was pressed against a ridge on the metal skid plate. This was sending a lot of vibration through the car. I trimmed a relief hole in the plate to clear the pipe.
On a test drive, the car sounded much better than last time, with no contact with the chassis, even under engine braking. There are still some tones I'm not fully happy with, so next week I'm going to swap on an Invidia resonated front pipe I have and see how it sounds.
So 1(Lo) - 5(Hi):
Build Quality: 5 (Beautiful welds and great attention to detail)
Sound: 4 (Deep, throaty sound. Primary pairing isn't perfect.)
Fitment: 2.5 (Too close to lower rad hose and water pump pulley. Hits skid plate. B1S1 O2 clocked too far.)
Overall: 4 (Good choice. Just needs some tweaking.)
The Following 3 Users Say Thank You to Draco-REX For This Useful Post:
BigFatFlip (05-07-2015), Jyn (05-07-2015), tato.valverde (11-17-2015)
Old 05-12-2015, 02:34 PM   #1452
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Lots of orders shipping today! These 2 guys are in stock and ready to ship if anyone's looking for a uncatted UEL!
Jesse@JDLAutodesign is offline   Reply With Quote
Old 05-12-2015, 04:31 PM   #1453
cjd
cjd's Avatar
Drives: 2017 BRZ
I'm too jaded! The hope that my order is in the batch shipping was quashed with a mental guffaw far too quickly. So that hope is cowering in a corner, but still there... Offsetting it is the thought it would then be likely to arrive while I'm out of town... So maybe...
Can't wait either way.
edit: just got a shipping notice! Wheeee
The Following User Says Thank You to cjd For This Useful Post:
Jesse@JDLAutodesign (05-12-2015)
Old 05-12-2015, 05:00 PM   #1454
benlaz88
Drives: 2013 Asphalt FRS
having uel jdl header n overpipe installed for a while , I'm planning on getting their turbo kit.
benlaz88 is offline   Reply With Quote
The Following User Says Thank You to benlaz88 For This Useful Post:
Old 05-12-2015, 06:16 PM   #1455
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Building stock
JDLAutoDesign is offline   Reply With Quote
The Following 4 Users Say Thank You to JDLAutoDesign For This Useful Post:
2016 Camaro SS (05-12-2015), kch (05-12-2015), PBlack09 (05-13-2015), SP86 (05-19-2015)
Old 05-12-2015, 10:56 PM   #1456
congiiee
Originally Posted by weederr33 View Post
Got my headers on Friday. Excellent quality and I can't wait to get them installed!
Why are you selling it now??
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 10:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 12:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 07:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 08:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 09:05 PM
