Old 05-03-2015, 04:15 AM   #99
350matt
Drives: toyota mr2/ Toyota GT86
I think there's plenty of headroom in the blower as theoretically its good for about 350-380Bhp
its a question of when the stock rod will bend under the pressure
I'd have said if Cosworth thought the stock bottom end was good for more, then they would have supplied the kit with smaller pulleys and more boost
aren't they supposed to be releasing a 'stage 3' kit to capitalise on the blower headroom?
I'm assuming that this will be a small pulley set, although the install I've seen looked like the SC pulley couldn't go much smaller?
So would they have to change all the pulleys do we think?
350matt is offline   Reply With Quote
Old 05-03-2015, 04:19 AM   #100
ajc209
Drives: GT86 Cosworth
Matt - the current belt is not wide enough to reliably drive the sc any faster. They will need to release a pulley set and new belt.....
Stage 3, I am told, is targeted for summer release. It is looking like it will be a bottom end and new pulleys for 325hp initially.
Personally I'd be a bit concerned about low oil pressure when things get hot, for more than stage 2. Stage 3 might be new bearings though....
ajc209 is offline   Reply With Quote
Old 05-03-2015, 12:36 PM   #101
350matt
OK that's going to be all of the pullies including the AC and the crank then?
should look good
interesting that the edelbrock and harrop blowers are still using the 6 rib belt then? as they are bigger blowers you'd think they would also need a bigger / wider belt
or are Cosworth being too conservative?
Old 05-03-2015, 01:02 PM   #102
ajc209
Or the others might be under engineering it. The larger pulley is just what I have heard from one of the uk distributors, but was direct from Cosworth aparently. It makes sense that you wouldn't make it too easy to upgrade the pulley to make more power without their bottom end stage 3.....
The thing is, Cosworth will be able to do clever things like finite element analysis to determine the strength of the bottom end. They might find that the rods can do 100 billion stress rotations before wthe rods bend or break, or it might be 100 thousand. The fact that they can do that puts them at the top of my list.
The same sort of thing is true of belts. Cosworth engineers will make damn sure if never slips or breaks for a resonable amount of miles. Is there a belt change interval come to think of it?
Old 05-03-2015, 04:04 PM   #103
350matt
Only trouble with that is on 1st glance it will make the 'upgrade' seem expensive as a pulley for a Kraftwerks or Sprintex is about $150 whereas a complete set of pulleys will be what a $1000?
I wonder if Cosworth are going to subscribe to the same view of the rest of the tuning industry and delete the crank damper with their new pulley?
cue a bunch of comments about how its not neccesery and OEM's only fit them for a laugh.......
Old 05-03-2015, 06:49 PM   #104
ajc209
I've already been shot down when suggesting a possible reason a bearing went on low milage car was because of the lightweight pulley fitted to he crank....
At least if Cosworth do it, I trust that it is safe. My main beef with most tuners is the lack of actual engineering skills. Instead they try it a few times on the dyno or drive 1k on the road and start selling it as a safe upgrade without proper consideration of engineering tolerances.
Old 05-03-2015, 09:09 PM   #105
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
A $1000 crank pulley from Cosworth? I could see that
I figured their Stage 3 would include larger injectors, and forged internals with a smaller pulley?
MS, CSCS, TSAC-F, CPT
Old 05-04-2015, 03:31 AM   #106
ajc209
I reckon stage 3.1 for 325hp will be bottom end and pulleys/belt and for stage 3.2 375hp could be bigger injectors and a pulley.
Old 05-04-2015, 03:51 AM   #107
350matt
I meant that you'll get a complete set of pullies , as if they go to an 8 rib belt everything will have to be replaced, inc the AC pulley
I suppose if you need bigger injectors then they'll include them in the kit?
what would we expect to pay for the SC upgrade kit then? assuming that their bottom end costs about the same as everyone else?
I was thinking pullies + injectors + bottom end / short block is what would be required to make a reliable 380Bhp
possibly an intake? as I think Cosowrth mentioned the stock intake was starting to choke about 300bhp?
Old 05-04-2015, 04:01 AM   #108
ajc209
IIRC they said the stock airbox was okay up to about 350hp... so might be a new airbox included in stage 3 to get 375hp.
Id expect a bottom end (depending on what actually gets changed) and pulleys/belt ~ £3.5k + cost of someone fitting it all....
Old 05-04-2015, 08:46 AM   #109
350matt
are there any aftermarket intakes that actually do anything?
Old 05-04-2015, 11:06 AM   #110
weederr33
weederr33's Avatar
Supposedly Grimmspeed
Old 05-04-2015, 11:09 AM   #111
ajc209
Most of the intakes mess with the maf calibration to gain a few hp. I am not aware of any that improve flow. I think most of the high hp turbos have a cone filter in place of the stock airbox....
Old 05-04-2015, 11:16 AM   #112
ajc209
The grimspeed looks like an injen copy to me..... to actually improve flow at 350+ hp id expect the pipe diameter to made larger. I'm not an expert though.....
MCA Blue coilovers - Now with first impressions and install pics!!!!!!!! Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 52 05-23-2016 08:18 PM
Cosworth Stage 2 Supercharger Install (Dyno,Tech,Photos,Videos) RallySport Direct Forced Induction 49 08-20-2015 07:32 AM
Cosworth Stage 1.1-1.3 Power Package BRZ 2013-2014 / FR-S 2013-2014 With Videos! RallySport Direct Engine, Exhaust, Bolt-Ons 104 07-02-2015 10:10 AM
Stage 1.1 Cosworth FRS FR-S89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 12-22-2014 01:23 PM
Cosworth Stage 2 v86 Software Tuning 2 11-05-2014 07:47 PM
