Old 04-30-2015, 12:57 PM   #29
SamGam
Drives: '13 BRZ SWP 6MT
Just shopping around for a header right now. Is the best price on the website? Any gb coming up or coupons? Thx!
SamGam is offline   Reply With Quote
The Following User Says Thank You to SamGam For This Useful Post:
aFe POWER (04-30-2015)
Old 04-30-2015, 12:59 PM   #30
aFe POWER
aFe POWER's Avatar
Drives: 2014 Scion FRS
That all depends on how many people want the header. Group buy maybe possible
aFe POWER is offline   Reply With Quote
Old 04-30-2015, 02:01 PM   #31
churchx
churchx's Avatar
Drives: 2014 GT86
Originally Posted by aFe POWER View Post
Both the underside and actual stock exhaust manifold covers fit on our header.
Now THAT's interesting. First time hearing such feat for twins aftermarket headers. I guess this might rise a bit interest from chaps @CA.
Old 05-02-2015, 01:00 PM   #32
cslntuee
Drives: Subaru BRZ Limited
I have two questions as below.
1. Did I need to buy any additional manifold gaskets for install?
2. Did you suggest to change the overpipe together or it is not
necessary?
I also interested in group buy.
Thanks.
cslntuee is offline   Reply With Quote
The Following 2 Users Say Thank You to cslntuee For This Useful Post:
aFe POWER (05-04-2015), danthedirt (05-02-2015)
Old 05-04-2015, 11:48 AM   #33
aFe POWER
aFe POWER's Avatar
necessary?
Thanks.
Thank you for the questions
1. We always recommend replacing the gaskets when replacing the exhaust manifold or upgrading to a header, this way you have the best seal possible.
2. Since you are doing the headers, a overpipe will help further increase performance a little bit and reduce restriction. Plus while you are down there, might as well upgrade the overpipe. We know that the headers are the biggest restriction in the exhaust system for the twins.
Old 05-04-2015, 11:36 PM   #34
Yap
Yap's Avatar
Drives: Scion FR-S Whiteout
What two states aren't they legal in?
Yap is offline   Reply With Quote
Old 05-05-2015, 12:34 AM   #35
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
California, for starters.
JohnJuan is offline   Reply With Quote
The Following 2 Users Say Thank You to JohnJuan For This Useful Post:
aFe POWER (05-05-2015), TM (05-05-2015)
Old 05-05-2015, 11:44 AM   #36
aFe POWER
aFe POWER's Avatar
California and New York unfortunately
Old 05-05-2015, 11:16 PM   #37
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
Still waiting for sound clips...
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 05-06-2015, 06:34 AM   #38
Sphirit
Drives: GT86
+1
Sphirit is offline   Reply With Quote
Old 05-06-2015, 02:27 PM   #39
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Commiefornia and New USSR unfortunately
Fixed.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
JazzleSAURUS (07-19-2016)
Old 05-06-2015, 08:24 PM   #40
Foobar
SLO NO MO
Foobar's Avatar
Technically, you can't mess with the stock emissions system in any of the 50 states due to fed regs except in specific situations:
Rules for Replacing Converters
In 1986, the U.S. Environmental Protection Agency issued new guidelines for the construction, efficiency and installation of aftermarket catalytic converters. All CleanAir converters listed in this catalog have been designed, tested and manufactured to meet this policy.
In addition, CleanAir converter listed in this catalog is appropriate for use under the current requirements of the California Air Resources Board (C.A.R.B.).
E.P.A. guidelines state that replacement converters may be installed only in the following situations:
1. The vehicle is missing a converter
2. A state or local inspection program has determined that the existing converter needs replacement
3. Vehicles manufactured prior to 1996 must have more than 50,000 miles, and a legitimate need for replacement must be established and documented
4. In cases of OBD Il-equipped vehicles (1996 and later), the O.E. manufacturer's 8-year/80,000-mile warranty must have expired and a legitimate need for replacement must be established and documented.
Please note that Federal law prohibits removal or replacement of a properly functioning O.E. converter.
When replacement of the converter is appropriate (as outlined above), the E.P.A. further requires that:
1. It be installed in the same location as the original
2. It be the same type as the original (i.e., two-way, three-way, three-way plus air/three-way plus oxidation)
3. It be the proper model for the vehicle application as determined and specified by the manufacturer
4. It be properly connected to any existing air injection components on the vehicle
5. It be installed with any other required converter for a particular application
6. It be accompanied by a warranty information card to be completed by the installer.
The Following User Says Thank You to Foobar For This Useful Post:
aFe POWER (05-07-2015)
Old 05-09-2015, 12:09 PM   #41
cslntuee
Is this the only aftermarket header option which can fit stock exhaust manifold covers? anyone knows?
Thanks.
Old 05-09-2015, 12:50 PM   #42
churchx
churchx's Avatar
Drives: 2014 GT86
Only one i've heard of such. IIRC there were posts about PTuning's one, that they had at some time possible plans of developing own oem-look-alike heatshield .. but i guess it never resulted in actual product. That's it. So for others .. about the only idea that crosses my mind is to have them dark ceramic coated to look not shiny/clearly aftermarket ones .. or go for Perrin 3" catback and leave header & frontpipe with cats intact to go for 100% legal setup in all the states. Yes, that 3" one will be too loud together aftermarket catless header, but with stock one it should be noise-wise on par with 2.5" unresonated one, and together with tune bring most gains not touching both stock cats.
afe power, fr-s & brz, header, scion, steveforgottosaymicdrop, subaru
Exedy OEM Replacement Clutch Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 **New Site** RallySport Direct Transmission and Driveline 59 09-01-2015 12:18 PM
FS: APR Brake Duct Hose and Backing Kit BRZ / FR-S $275 kanundrum Brakes, Suspension, Chassis 4 04-24-2015 11:24 AM
Beatrush Over Pipe Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 RallySport Direct Engine, Exhaust, Bolt-Ons 17 03-16-2015 11:29 AM
Product Release! Mishimoto Peformance Aluminum Radiator for Scion FR-S / Subaru BRZ! Mishimoto Announcements, Contests, Giveaways 1 10-01-2013 11:44 AM
New Product Release: StopTech Big Brake Kits for Scion FR-S and Subaru BRZ !!! PRO Import Tuners Brakes, Suspension, Chassis 16 08-24-2012 07:59 PM
