Old 05-01-2015, 07:40 PM   #1
AlaaTarawneh
AlaaTarawneh's Avatar
Drives: Toyota GT86 , 2.0L FA20 , RED
Toyota GT86 Basic Drift Setup
Hello ,
So I have my 2013 GT86 manual gear and want to start building it as a drift car but keeping the same engine without upgrading, reading and asking alot about what to do, the car as we know it does not have so much power but with correct setup it might give you more, Ive been practicing on drifting for a while now using a 350Z and G35 which had basic setup ( suspensions, wheels, E-Brake ) using the stock engine , knowing that the GT86 is lighter it could do better
What I have in mind to change is the following :
1. change the current LSD with a LSD 2-Way
2. Coilovers system
3. Semi-Slick Tires 195-210/35 and 16 inch or 15 inch rims
4. Hydraulic Handbrake
5. Airfilter/Headers/Catback
This is how i want to start with the car problem is im not that good to know which parts to buy, if someone can advice me would be better
AlaaTarawneh is offline   Reply With Quote
Old 05-02-2015, 12:58 AM   #2
Chanpion
Drives: 13 FRS Satin
You're missing high angle steering knuckles. It's what makes a drift car.
Chanpion is offline   Reply With Quote
Old 05-02-2015, 01:19 AM   #3
swarb
Double camber bolts.
Drift button.
Air pump.
Clutch adjustment.
Old 05-02-2015, 02:45 AM   #4
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
2jz
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
The Following 2 Users Say Thank You to edeekeos For This Useful Post:
Jrryjms07 (05-02-2015), YamahaR86 (01-17-2020)
Old 05-02-2015, 02:59 AM   #5
AlaaTarawneh
Im only putting basic setup without angle @swarb : hydraulic handbrake is better the drift button , and im not changing the engine , which brands or models should i get from what I mentioned
Old 05-02-2015, 03:08 AM   #6
N234
N234's Avatar
Drives:
Welcome to the forum.
N234 is offline   Reply With Quote
The Following User Says Thank You to N234 For This Useful Post:
Old 05-02-2015, 03:10 AM   #7
AlaaTarawneh
Welcome @N234
The Following User Says Thank You to AlaaTarawneh For This Useful Post:
Old 05-02-2015, 03:19 AM   #8
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
i drifted mine descent completely stock, still mostly stock but its fun to get out to the track and let loose,
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 05-02-2015, 01:59 PM   #9
gtslow
Drives: 2015 Halo FR-S
So much trolling in this tread right now.. The car is RWD and has an LSD, increase your rear tire pressure and that is enough to start.
gtslow is offline   Reply With Quote
The Following User Says Thank You to gtslow For This Useful Post:
Jyn (05-04-2015)
Old 05-02-2015, 02:26 PM   #10
Vroomin86
Drives: 2015 Fire
Funny, setting up my RC drift cars has definitely given me much more insight into setting up my real car. Tires, very important, camber and toe, and lastly suspension rebound. after that some practice and skill will go a long way
Vroomin86 is offline   Reply With Quote
Old 05-04-2015, 04:29 AM   #11
paulca
Drives: Toyota GT86 Coupe Red (UK)
But jeremy clarkson says you can drift it while reading a book and none of you propose buying a book!
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
The Following 7 Users Say Thank You to paulca For This Useful Post:
Chimera (05-04-2015), GT86_PRAGUE (05-04-2015), JoeC (01-30-2020), meWant (05-04-2015), Tcoat (05-04-2015), whataboutbob (08-07-2021), YamahaR86 (01-17-2020)
Old 05-04-2015, 08:57 AM   #12
GT86_PRAGUE
Drives: GT86
BOOK
GT86_PRAGUE is offline   Reply With Quote
The Following User Says Thank You to GT86_PRAGUE For This Useful Post:
Tcoat (05-04-2015)
Old 05-04-2015, 08:58 AM   #13
GT86_PRAGUE
Drives: GT86
This might be interesting:
ASD 16" Hydraulic E-Brake
Old 05-04-2015, 12:30 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
To "drift well" the only real thing you need is a 2-way clutch-type LSD.
Everything else is secondary. On stock tires you can slide all day.
This is me with the stock Torsen LSD:
[ame="https://www.youtube.com/watch?v=cGwnf2tyDPA"]BRZ drifting @ Vegas Drift 05.30.14 - YouTube[/ame]
I could've done better as far as connecting the manji transitions, it's really just poor driving skills + the Torsen acting like an open diff with sloppy transitions.
-alex
ChrisD (12-22-2015)
drift, drifting, gt86
GT86 drift video mrbbs FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 20 05-03-2018 03:54 PM
circuit versus drift suspension setup chadori Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-23-2014 12:10 AM
Drift video GT86 mrbbs BRZ Photos, Videos, Wallpapers, Gallery Forum 0 09-22-2013 05:24 AM
8 different GT5 Nordschleife leaderboards with the Toyota GT86 (stock, tuned, drift) RaceR Other Vehicles & General Automotive Discussions 56 11-21-2012 10:56 PM
