Old 04-30-2015, 04:16 PM   #1
JARE_ee
Alaska Roll Lover
JARE_ee's Avatar
Drives: Blue.Series.Aozora
Sound Upgrade - Cost Effective
Hello,
What is the most cost effective way of improving the sound quality in the stock fr-s. The sound at the moment isn't too bad, but it could be better.
1. Add a sub and amp into the stock system.
2. Change the headunit, and keep everything the same.
3. Change speakers.
I don't mind a little bit more bass, but i more so looking at the sound quality.
Cost effective as in the least amount of money for the most significant improvement.
Thanks!
JARE_ee is offline   Reply With Quote
Old 04-30-2015, 04:28 PM   #2
fika84
fika84's Avatar
http://www.ft86club.com/forums/showthread.php?t=29545
http://www.ft86club.com/forums/showthread.php?t=85139
http://www.ft86club.com/forums/showthread.php?t=58497
LOTS of things already been discussed.. If that's not enough to get you going, here is how those were located.. https://www.google.com/search?safe=o....0.VmssTeposSI
fika84 is offline   Reply With Quote
The Following 3 Users Say Thank You to fika84 For This Useful Post:
Chimera (04-30-2015), JohnJuan (04-30-2015), Koa (05-01-2015)
Old 04-30-2015, 05:14 PM   #3
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
I found that replaceing the stock 3.5" with a decent coaxial speaker made a world of difference. The stock 3.5 seems a bit muffled and the stock tweeter is only .5". Replaceing the stock mid with an upgraded coaxial adresses both of these problems.
All the speakers in the car are wired at a 2 ohm load. The rears are 2 ohm, the front door speakers are 2 ohm, and the dash mid & tweeter are 4 ohms each wired in parallel for a 2 ohm load. I simply replaced the stock 3.5 with a good old 4" Kicker I had laying around, and it made a world of difference. The sound was much fuller and brighter. Fitting a 4" speaker took some massaging, but if I were to do it again I would just replace it with a better 3.5" coaxial. YMMV.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 04-30-2015, 09:56 PM   #4
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Sound deaden the doors. It makes a huge difference.
kmbkk is offline   Reply With Quote
Massive Sound upgrade on GT86 labskaus Electronics | Audio | NAV | Infotainment 39 08-28-2015 06:11 PM
Can you upgrade the sound system for around $500? Jar Electronics | Audio | NAV | Infotainment 4 03-26-2015 07:44 PM
Any more time/cost effective product than Optimum no rinse with wax? andrew1021 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 06-30-2014 11:14 AM
Cost effective way to upgrade sound? l0aded Electronics | Audio | NAV | Infotainment 6 02-22-2013 08:50 PM
