Old 11-07-2014, 03:43 AM   #71
johnnytsunami
johnnytsunami's Avatar
Drives: 14 firestorm FRS monogram series
Really good guide, definitely in for updates.
johnnytsunami is offline   Reply With Quote
Old 11-07-2014, 04:05 AM   #72
CSG Mike
CSG Mike's Avatar
What kind of updates would you like to see?
Old 11-07-2014, 11:18 AM   #73
johnnytsunami
Maybe mods that will help benefit us on the track?
Old 11-07-2014, 01:42 PM   #74
CSG Mike
CSG Mike's Avatar
That's really, really subjective...
but an oil cooler and camber bolts are nice.
Luckrider (11-07-2014)
Old 11-26-2014, 04:33 PM   #75
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
For a beginner signed up for an 8 session day with an instructor, would you recommend changing out the stock tires? I know they're good for providing feedback as I've seen in autocross days but I feel like a wider 225 stickier tire like PSS would be beneficial. (Car is prepped otherwise with a fresh oil change and brake pads/fluids.)
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
Old 11-26-2014, 09:36 PM   #76
jvincent
jvincent's Avatar
Run your first few days on the stock tires. You'll start to get faster and once you start to lose grip because of going faster and not making mistakes, upgrade them.
Old 03-25-2015, 08:34 AM   #77
funwheeldrive
Tracking obviously puts a big strain on the car. What are the differences in maintenance intervals with a tracked car and a non tracked car? How often do you change your oil/fluids/coolant/plugs?
The Following User Says Thank You to funwheeldrive For This Useful Post:
Jyn (03-25-2015)
Old 04-28-2015, 11:16 PM   #78
N234
N234's Avatar
Drives:
100% stock interior. The OEM seats are spectacular in this car, and will hold you in place rather well. I personally would never recommend a harness and harness bar with OEM seats.
I'd like to know why you don't recommend harnesses in OEM seats.
I've been eyeing the Schroth Rallye 3, a 4-point harness designed to anchor to the rear child seat anchor.
Your thought's on this are much appreciated.
N234 is offline   Reply With Quote
Old 04-29-2015, 02:33 AM   #79
CSG Mike
CSG Mike's Avatar
Attachment 108236
I wouldn't ever use that. That's asking to submarine.
Also, the only POSSIBLE way for that to be effective, is if you're a midget. Seriously.
kravi (01-16-2016)
Old 04-29-2015, 12:28 PM   #80
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
I second this.
n8dog11914 is offline   Reply With Quote
Old 04-29-2015, 01:23 PM   #81
jvincent
jvincent's Avatar
I think this has been covered earlier, but for me, the maintenance schedule is as follows. Note that we have winter here, so our track season is May - Oct.
- New trans, diff, and full brake fluid flush at the start of the season. I'm using Motul Gear300 for the trans and diff. RT700 brake fluid. I will probably bleed the brakes mid summer.
- New air filter at the start of the season.
- Oil changes every 4000 km or so, depending on the number of track days in between changes.
- Brake pads and rotors as required.
Unless I get a CEL, I won't be changing the plugs until the recommended interval. I'll probably flush the coolant sometime this summer.
Old 04-29-2015, 01:29 PM   #82
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Quick and dirty guide to track prepping your car
What are these plugs you guys are referring to?
Kronos is offline   Reply With Quote
Old 04-29-2015, 01:41 PM   #83
jvincent
jvincent's Avatar
Sparkplugs.
The Following 2 Users Say Thank You to jvincent For This Useful Post:
Koa (05-04-2015), Kronos (04-29-2015)
Old 04-29-2015, 04:04 PM   #84
CSG Mike
CSG Mike's Avatar
Originally Posted by n8dog11914 View Post
I second this.
We swap out engine oil at odd intervals, as we send in our oil for testing. Currently we are changing at 8k miles, and will continue to add miles to each interval until testing says otherwise. We run Motul 300V in the engine.
Transmission fluid is changed out every 10k. Testing is not performed on this fluid, as we consider it preventative maintenance.
Differnetial fluid, we have no interval, because we've been constantly changing settings on our LSD for testing, and the fluid is changed every time we reconfigure our LSD. For track driving, I'd also go with 10k.
YMMV. There is no one right use. Most people think our intervals are too long, especially for a car that sees the amount of track testing ours does (virtually every weekend).
funwheeldrive (04-29-2015)
FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel Pekingduck Interior Parts (Incl. Lighting) 7 02-12-2014 05:59 PM
prepping for winter Celica00 Scion FR-S / Toyota 86 GT86 General Forum 24 09-27-2012 08:17 AM
Prepping for rear spoiler install? zooki Cosmetic Modification (Interior/Exterior/Lighting) 2 09-02-2012 03:56 PM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-20-2012 11:33 PM
Clean & Dirty trueno86power Other Vehicles & General Automotive Discussions 1 02-07-2012 12:54 PM
