Old 04-28-2015, 04:00 PM   #281
Racecomp Engineering
- Andy
fika84 (04-29-2015)
Old 04-29-2015, 12:57 PM   #282
RBbugBITme
Drives: S60R/Corvette
Originally Posted by cdrazic93 View Post
What would that translate to on the graph? When you say all areas im assuming you mean a quadruple adjustable shock.
I simply mean that we have the ability to build a shock with almost any damping rate required at pretty much any sector of the shock dyno graph. We simply have to incorporate different technologies to do it such as cut bands, high flow/velocity dependent/linear/digressive/regressive pistons, various adjusters, remote flow control devices, interconnected suspensions, and active damping if necessary.
Ryan M.
Strange Engineering
Director of Suspension Development
RBbugBITme is offline   Reply With Quote
Old 04-29-2015, 01:28 PM   #283
Basically, you can close your eyes and draw a line that goes up and down and they can build it for you, with or without adjusters.
If you build the shock exactly the way you want, you don't need adjusters at all. They do help with quickly fine-tuning for different situations.
- Andy
cdrazic93 (04-29-2015)
Old 04-29-2015, 01:55 PM   #284
gramicci101
Off Topic
What I would love to see is something similar to PASM for these cars. I can't even imagine how much something like that would cost though. You'd need a control module with at least two accelerometers, preferably mounted somewhere near the CG of the vehicle. You'd need struts and shocks that could be electronically adjusted on the fly to compensate for road surfaces and driving styles, and springs that would work well with the entire range of adjustment. And you'd need some inspired programming to get it all to work properly.
Old 04-29-2015, 02:54 PM   #285
DeaconRoc
Drives: GT86
I'm doing my best to get as good an understanding of suspension and dampers as possible as I really do think a good suspension set up is make or break on a car.
However, obviously it's a really complex topic.
What would you expect a damper that produced a graph like this to be like:-
It uses this piston:-
DeaconRoc is offline   Reply With Quote
Old 04-29-2015, 03:33 PM   #286
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Ill take a crack at that;
My guess is that it looks like a digressive/linear piston from what Shankenstein posted.
Basically a shock that would be pretty predictable on the street while giving you a decent amount of damping. (Then again i could be impossibly wrong).
The Following User Says Thank You to cdrazic93 For This Useful Post:
DeaconRoc (04-29-2015)
Old 04-29-2015, 05:50 PM   #287
RBbugBITme
Meister seems to make a nice piston and that looks more like a high flow linear piston. I'm used to force/velocity graphs and maintaining uniform units of measure but the compression side is the high flow/lots of bleed side and the side we're looking at in the picture. Basically it dumps a ton of pressure when the shims open with the huge ports.
The smaller ports are the inlet for the rebound flow. Smaller ports allow for higher pressures/forces and greater adjustability range. The adjustable range is excessive. You could run any spring you ever want and never have to change the shim stack on the rebound side but I'd hope it has a lot of clicks that allow you to take smaller adjustment steps or you'll never be able to dial the car in correctly.
I have a piston similar to this in my Corvette and I love it on the street. With so much compression bleed it feels pretty good on pothole ridden streets. I barely notice running over train track crossings.
Ryan M.
Strange Engineering
The Following 2 Users Say Thank You to RBbugBITme For This Useful Post:
DeaconRoc (04-30-2015), Kostamojen (04-30-2015)
Old 04-30-2015, 03:03 AM   #288
DeaconRoc
Drives: GT86
Thank you for your thoughts on these.
They are single way 36 point adjustable - dialing them in is definitely proving a challenge!
You're 100% right about the potholes though - they soakthem up like no suspension I've ever tried. The internals are made by a company who specialise in rally car suspension which might explain it.
Old 07-16-2015, 01:02 PM   #289
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
asked this in a separate thread but got a hypothetical answer.
Does toe change in the rear with ride height changes?
And if it does even a little bit, which way does it change when the car goes up or down?
Old 07-16-2015, 01:06 PM   #290
fika84
fika84's Avatar
Someone with a model will have to check the amounts, but it absolutely changes with ride height! It just depends on the radius of curvature of the tie rod. Usually it will toe in under compression AND rebound, but it depends at the point the tie rod is at it's maximum extension. Someone with a model will need to tell us at what chassis height this maximum extension is at. Maybe @RBbugBITme has this info, or @Racecomp Engineering
fika84 is offline   Reply With Quote
Old 07-16-2015, 01:22 PM   #291
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
just to make sure, I'm interested in the rear of the car.
I'm particularly interested because I just had my alignment (a very aggressive, for testing) done with 1/4 tank and spare removed. I'm curious which way it will go once I put everything back in + an extra 50/60 pounds of cargo.
becase if it will go back towards centerline that's fine, but if it will increase my settings then I'd be worried. :o
Old 07-16-2015, 01:26 PM   #292
fika84
fika84's Avatar
Yes, the rear.. I use the term tie rod for both front and rear, even though in the rear it's a toe arm I guess.. same stuff to me.
Hopefully someone can chime in, I think I remember seeing a chart of someone that posted this kind of information.. I'll hunt around for it.
@7thgear - Here is a good link with someone saying they've measured it and it toes in under rebound and toes out almost the entire amount of travel under compression... I'd want a second look.
Old 07-16-2015, 01:35 PM   #293
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
no link!
Old 07-16-2015, 02:01 PM   #294
fika84
fika84's Avatar
no link!
I'm retarded... http://www.ft86club.com/forums/showthread.php?t=56488
The Following User Says Thank You to fika84 For This Useful Post:
cdrazic93 (01-18-2016)
New Rumor: Subaru Developing Turbo 4 2.0T for BRZ Hachiroku BRZ First-Gen (2012+) — General Topics 350 02-02-2013 01:52 PM
Need opinions on two new items we're developing! yospeed Cosmetic Modification (Interior/Exterior/Lighting) 56 12-03-2012 02:13 AM
Chances of Someone Developing 5x114.3 HUBS (not spacers)? Entropy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-04-2012 03:35 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 07:16 AM
