Old 04-29-2015, 07:11 AM   #1
LS1M
Drives: 2015 BRZ
Break-in time before FI?
I've been babying my car since new and will be doing my first oil change at 1000 miles soon. How long should I wait before installing a supercharger? I was thinking oil change at 1000, then normal driving, change oil at 5000 and then do the install. Sound about right?
Thanks!
-Mark
LS1M is offline   Reply With Quote
Old 04-29-2015, 07:46 AM   #2
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Thanks!
-Mark
You can do it whenever. I would say after the 1,000 mile mark, change to a heavier weight oil and do the install. Either way, it's going to break in normally and get rid of the metal bits. I would definitely put on the supercharger and have fun with it.
2016 Camaro SS is offline   Reply With Quote
Old 04-29-2015, 09:33 AM   #3
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I boosted mine at about 1800km and it's fine (currently at 22,000).
Modern engines don't need a formal "break in" period l iike they did way back in the day.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 04-29-2015, 11:35 AM   #4
LS1M
Drives: 2015 BRZ
OK sooner rather than later then. Thx!
Old 04-29-2015, 11:56 AM   #5
cnk
Drives: '13 DGM BRZ Limited
I would drive it until you feel comfortable that there are no issues with the car stock. Once you modify it, dealing with the dealer with any warranty claims can be hit or miss.
Old 04-29-2015, 12:39 PM   #6
LS1M
Drives: 2015 BRZ
I've pretty much resolved to forego the factory warranty when I boost it. At least for the drivetrain. I do have a really good dealership, though. They're brand new & right near the house, but if I get engine knock or oil blowby, I can't blame them for pointing to the blower as the culprit. I would.
I had the money for a new Mustang and bought this car instead, with enough $ left over to get a kit. Still deciding which one - down to either the JRSC or Vortech/OFT - but this money is burning a hole in my pocket...
Old 04-29-2015, 12:58 PM   #7
vividracing
vividracing's Avatar
The Subaru dealership I went to for my warranty thought my car was so cool, they sell BRZ's but they didn't often get to see one modified like mine was and all the service guys and techs asked me about stuff. If you get it supercharged, your engine warranty is pretty much scrapped but doesn't mean they can't warranty other stuff. I had an aftermarket header, tune, and exhaust and they didn't care, cause of the aformentioned coolness of it. Haha
Have you considered the Cosworth Supercharger? The JRSC and Vortech are centrifugal types while the Cosworth is a twin screw. The Cosworth gets more power
-RyanG
vividracing is offline   Reply With Quote
Old 04-29-2015, 01:21 PM   #8
LS1M
Drives: 2015 BRZ
No I hadn't. The numbers I saw for innovative looked low so I figured a twin screw wasn't a good match. How much will a Cosworth net me, all else being stock?
Old 04-29-2015, 02:32 PM   #9
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
You should've drove the car off the dealer lot straight to your garage to install the supercharger. Now that you've waited, the engine will need all gaskets replaced and all fluids changed, including the headlights.
If you install that supercharger now, the car is pretty much going to be totalled at that point.
The Following 2 Users Say Thank You to TylerLieberman For This Useful Post:
gramicci101 (04-29-2015), weederr33 (04-29-2015)
Old 04-29-2015, 02:38 PM   #10
vividracing
The Innovate system was basically the first generation of superchargers for the FA20 engine, and there have been lots of advancements since then. The Cosworth system has a specifically designed intake manifold for the system. The down side being it costs a bit more than the other systems you mentioned because of the extra engineering.
We actually have the Cosworth ready to ship and other systems including the Vortech, HKS, and Kraft Werks, see here: Vivid FA20 Superchargers
Here's our blog post about the Cosworth System: Vividracing Blog - Cosworth.
On the bottom of the blog post shows the dyno of the system and it's insane gains over stock.
If you were seriously interested in chatting about getting a system, Jay can help you out and get you a really good end of the month deal for it.
Would you like him to PM you?
-RyanG
Old 04-29-2015, 03:02 PM   #11
R3NIK
R3NIK's Avatar
Drives: 2013 FR-S/C
-RyanG
As for the two twinscrew systems out there, the Cosworth does have the nice twin intercoolers in the intake manifold, but the Sprintex also has a custom manifold and laminova intercooler for $4700 vs $6500+ (I'm guessing) for the Cosworth.
I'm eager to see real world dyno charts on the two systems to see what the premium price gives (The VR hosted dyno shows crank horsepower?). If I was a betting man, I'd put the JRSC as still being the best $/hp ratio.
R3NIK is offline   Reply With Quote
Old 04-29-2015, 03:48 PM   #12
LS1M
Drives: 2015 BRZ
Originally Posted by TylerLieberman View Post
You should've drove
*driven*
Old 04-29-2015, 03:58 PM   #13
CSG Mike
CSG Mike's Avatar
We boosted with less than 1000 miles on the clock on our 2014 BRZ.
Old 04-30-2015, 07:15 AM   #14
LS1M
Drives: 2015 BRZ
What about the trans/diff? I want to switch to Motul 300 75w90 (heard a lot of good things about it here) but not sure if the factory fill has any breakin additives
Break In New FRS Lunatic Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 43 08-22-2014 03:30 PM
Tax return time = WHEEL CLEARANCE TIME from Gram Lights and Yokohama vividracing Wheels and Tires 4 04-04-2014 02:46 PM
Break in Y/N ? FiRStscion Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 83 07-26-2013 12:41 PM
Break in ipothas Issues | Warranty | Recalls / TSB 11 10-21-2012 04:41 PM
