go_a_way1
Old 04-28-2015, 09:26 AM   #2199
uRBAN_Metal
Drives: '13 BRZ
Originally Posted by dj2020 View Post
Owners: how often do you guys clean the air filter? And particular way I should do this? There are a few videos on YouTube that I can follow for cleaning /oiling K&N air filters.
K&N says you can go 100,000 miles before cleaning the filter. I would clean it way before that in this application. Just buy the K&N cleaning kit and follow the instructions on the box. It's pretty easy as long as you give yourself enough time to follow the process properly.
uRBAN_Metal is offline   Reply With Quote
The Following User Says Thank You to uRBAN_Metal For This Useful Post:
dj2020 (04-28-2015)
Old 04-28-2015, 09:28 AM   #2200
dp1
driving smoother faster
Drives: Sold
Never, I use the AEM dry flow air filter wrap ([ame="http://www.amazon.com/AEM-1-4000-Flow-Filter-Wrap/dp/B00353G1SY"]Amazon.com: AEM 1-4000 Dry Flow Air Filter Wrap: Automotive[/ame]) during wet months. I take it off and clean it with microfiber cloth and window cleaner when I swipe finger against it and see dirt. I take off the filter wrap during mostly dry months and replace the filter at least once per year regardless of how it looks. It can probably be cleaned to some extent but I replace it. Replacement interval depends on the amount of dust and moisture the filter is exposed to.
dp1 is offline   Reply With Quote
Old 04-28-2015, 10:48 AM   #2201
CSG Mike
CSG Mike's Avatar
We use two filters, and swap in the "fresh" one whenever it looks dirty.
CSG Mike is online now   Reply With Quote
Old 04-28-2015, 12:59 PM   #2202
Juggles
Drives: 2013 FRS
I've been thinking about taking this same approach... have a link to where I can pick up an extra?
A zen master once told me "Do the opposite of everything I say", so I didn't.
Juggles is offline   Reply With Quote
Old 04-29-2015, 05:24 AM   #2203
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
If by "filters" you mean underwear, we are on the same page.
Coheed is offline   Reply With Quote
The Following 5 Users Say Thank You to Coheed For This Useful Post:
campy (05-01-2015), keithr (04-29-2015), PikachuBRZ (01-22-2023), SuperDave (05-01-2015), wparsons (05-01-2015)
Old 04-29-2015, 01:59 PM   #2204
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
http://jacksonracing.com/shop/air-fi...nd-air-filter/
JDMChris is offline   Reply With Quote
Old 04-29-2015, 04:08 PM   #2205
Xuningshen
Drives: Subaru BRZ
i've googled around a lot, checked parts.subaru.com and cannot find info on the exact size of the MAF o-ring... anybody have it on-hand that could help me out? i've taken mine on and off several times, carefully and it was slightly stretched the last time i took it off but still works, just need to have some sitting around for next time. thanks
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 04-29-2015, 04:59 PM   #2206
CSG Mike
CSG Mike's Avatar
PM me your address and I'll mail you one.
Old 04-29-2015, 05:34 PM   #2207
Raven240
Drives: 2015 Release Series 1.0 FRS
Do superchargers have a break in period? Or can I drive it hard the first day =D
075/1500 2015 Scion FRS Release Series 1.0 / Jackson Racing Supercharger + Oil Cooler / Tom's Red DOT LED lights / 18s staggered Enkei Raijin with RS3 / TRD Short Shifter / 328 Stoptech BBK Front / Velox Motorsports Diffuser / Whiteline bushings / Ohlins RT Coilovers / VIS Carbon Fiber Hood.
Raven240 is offline   Reply With Quote
Old 04-29-2015, 05:42 PM   #2208
CSG David
CSG David's Avatar
Follow the instruction manual. The break-in procedure is there.
Old 04-29-2015, 05:45 PM   #2209
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Both. It's a 100 mile break in, how to do it is in the manual
ScionOfHorus is offline   Reply With Quote
Old 04-29-2015, 05:55 PM   #2210
Xuningshen
Drives: Subaru BRZ
I appreciate the offer but I can't have you do all that work for me! I will drop by your shop Friday and buy some from you guys though lol
2014 WRB BRZ
Old 04-29-2015, 05:57 PM   #2211
CSG Mike
CSG Mike's Avatar
Keep the RPM down for the first 100 miles, and re-check fluid levels regularly. If everything looks good after the first 100, have fun
Old 04-29-2015, 05:58 PM   #2212
CSG Mike
CSG Mike's Avatar
Please call and make an appointment to make sure someone is there. CSG is primarily a R&D and shipping facility.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
