Old 04-27-2015, 10:48 AM   #71
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by enigma View Post
Pat, I may be game for that. I usually have a little free time in the afternoon on Fridays. Let me know when you're in KC and we could possibly meet up!
YGPM soon
Old 04-27-2015, 03:43 PM   #72
Swede
Drives: White
Following this, very interesting. This is what i want to do with my next car that might be a GT86, once my leave is over
Swede is offline   Reply With Quote
Old 04-27-2015, 06:12 PM   #73
xwd
Originally Posted by 350matt View Post
Thats a shame about no log data,
were you low on fuel at the time? as I know these cars can struggle with fuel pickup at anything less than a 1/4 tank of gas
one other thing is I've heard the DW65 pump isn't that reliable?
especially if there's any ethanol in the fuel - I'm not talking E85, just the 10% thats quite common in pump gas these days
however these guys do an E85 pump
http://asnuusa.com/ASNU92-FP330E
so might be an idea to swap?
cue loads of people now saying DW 65 is the best pump ever and they have fitted onto every car they own.....
Heh lots of people have had good luck with those pumps, lots of people have had bad luck. They are Chinese made cheap pumps so it's hit or miss.
Hole in the piston is detonation. To me if you are running 91 octane using FI on this car, especially using an off the shelf map, you should be 100% prepared for the worst. Personally I would never push the car on 91 period, but if I had to I'd definitely get it tuned locally.
Old 04-27-2015, 07:32 PM   #74
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
This kit looks excellent. Definitely filing this under the possibilities file for once I pay off the car at the end of this year.
Wise is offline   Reply With Quote
Old 04-27-2015, 09:30 PM   #75
sickmint79
Drives: bmw
does this kit *require* the oem intake be used? seems cars go back to it in the videos i stumble upon.
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
Old 04-27-2015, 09:37 PM   #76
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
I've been watching this build on and off for a while. When Cosworth talked about releasing this kit I got pretty interested in it, but I would like to use it in a different application....
I also saw there might be a KC meet up with the OP (from Denver) heading that way. Shit, maybe I will take off of work early and come down for a night. I live up in Omaha, NE. It would be nice to meet some FT86 cars outside of Nebraska and Minnesota
shiro is offline   Reply With Quote
The Following User Says Thank You to shiro For This Useful Post:
Pat (04-28-2015)
Old 04-27-2015, 10:01 PM   #77
wparsons
wparsons's Avatar
If you want to use the included inlet pipe, you're limited to the stock airbox or something like the Perrin that replaces just the airbox (their CAI, not their inlet pipe). The Perrin 3" (Big MAF) CAI would be a good match for this but would require editing the tune for the revised MAF scale.
flickr
Old 04-28-2015, 03:01 AM   #78
enigma
Drives: Asphalt 86
Scheduled dyno time Wednesday afternoon! Video and dyno sheet coming soon.
The more the merrier! We're a fairly active group in KC, so we have various meets that would be a good fit. May 17th we're meeting up with the St. Louis 86 group and the Springfield, MO 86 group down in Osage Beach, MO for lunch. You're welcome to join!
I plan on heading back to RPM (or MAM, whatever you want to call it) at some point this year, so you could always check the car out on track as well.
enigma is offline   Reply With Quote
The Following User Says Thank You to enigma For This Useful Post:
shiro (04-28-2015)
Old 04-28-2015, 08:14 AM   #79
Streetthrowback
Drives: 2015 brz
Subscribed
Streetthrowback is offline   Reply With Quote
Old 04-28-2015, 09:37 AM   #80
sickmint79
Drives: bmw
what about the airaid?
is there an e85/flex fuel tune for this as well?
trying to compare/contrast to sprintex for which i'd like to install next year. planning for track use.
Old 04-28-2015, 10:49 AM   #81
ajc209
Drives: GT86 Cosworth
Yeah don't get the sprintex for track use. It has well documented thermal issues. Intake temps quickly rise to the point were timing gets pulled. Either that or you run dangerously high temps.
The cosworth sc on the other hand, according to Cosworth themselves, never sees more than 10C post intercooler charge temps. It was designed to handle ~350hp planned for stage 3 internals.
ajc209 is offline   Reply With Quote
The Following 2 Users Say Thank You to ajc209 For This Useful Post:
ATL BRZ (04-28-2015), wparsons (04-28-2015)
Old 04-28-2015, 11:01 AM   #82
shiro
shiro's Avatar
Awesome and thanks! Yeah, the name changed to RPM but most people still know it as MAM. The Ice Cream Cruise (ICC) for Omaha will be at RPM this year, which will make it more convenient for those that want to use the drag strip.
Old 04-28-2015, 11:17 AM   #83
wparsons
wparsons's Avatar
Not sure, you would have to email them to find out. If you can use their airbox with the stock inlet pipe, then it would work with the cosworth supercharge inlet pipe. If not, then it probably won't work either.
Definitely don't get the sprintex for track use. I'd go cosworth or jackson racing.
flickr
Old 04-28-2015, 01:05 PM   #84
sickmint79
Drives: bmw
thanks guys. seems the cosworth is far superior in terms of heat management.
MCA Blue coilovers - Now with first impressions and install pics!!!!!!!! Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 52 05-23-2016 08:18 PM
Cosworth Stage 2 Supercharger Install (Dyno,Tech,Photos,Videos) RallySport Direct Forced Induction 49 08-20-2015 07:32 AM
Cosworth Stage 1.1-1.3 Power Package BRZ 2013-2014 / FR-S 2013-2014 With Videos! RallySport Direct Engine, Exhaust, Bolt-Ons 104 07-02-2015 10:10 AM
Stage 1.1 Cosworth FRS FR-S89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 12-22-2014 01:23 PM
Cosworth Stage 2 v86 Software Tuning 2 11-05-2014 07:47 PM
