Old 05-23-2012, 04:03 PM   #15
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
I'm experiencing this olin my toyoda rav4.. It's a year 97.. So guessin the temp control is broken or vent for heated air underhood is not closing fully.. Bring to service right away and let us know about it.
tintumz22 is offline   Reply With Quote
Old 05-23-2012, 04:08 PM   #16
Dang Lad
Dang Lad's Avatar
Drives: Asphalt MT FR-S
Originally Posted by smbrm View Post
I have some other Toyotas that do the same thing, blow warm air on vent with heat all off. I think it has to do with where the vent air is aquired from outside. With set a recirc it will definitely get hot and steamy as you are just recirculating cabin air!
My 2004 Corolla S has always done this as well. Feels like the outside AC vents take a detour next to the radiator for some reason .
Dang Lad is offline   Reply With Quote
Old 05-23-2012, 04:49 PM   #17
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Hopefully this isn't the case with the BRZ
Originally Posted by MTeator View Post
With my A/C off but the setting to "Cold" on the dial, the vent blows very warm. On "1" it's downright hot and on "4" it's very warm.
With the fan set to 0/off, the air blowing through from driving at highway speeds makes it very hot as well.
Basically, with the windows up I have to use the A/C or be cooked out of the car even though it's 70 degrees outside. With the windows down, it feels like you have an exhaust leak into the car.
What's everyone's else's experience? It seems broken to me, so I'm going to take it in for service.
My car also got a really bad knock today, but it went away. Very concerning.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 05-23-2012, 04:59 PM   #18
ngabdala
BTW you guys should change the vent setting to hot and maybe it will do the opposite
Old 05-23-2012, 05:09 PM   #19
avusblue
avusblue's Avatar
Drives: 2013 FR-S, Manual, Argento
Some cars are just that way, depending on how the underhood packaging, the exhaust pipe routing, and the HVAC ducting coincide with each other. My Miata's were always that way. The "vent" always issued warmer-than-ambient air, and having hot footwells was a very common pet peeve.
avusblue is offline   Reply With Quote
Old 05-23-2012, 05:30 PM   #20
ttknf
Drives: 350z Nismo, CBR1000RR
I've had a few cars that do this. It's probably due to the fact that the intake air has to pass firewall and then through the blower motor and all the plastic piping in the dash, so it has time to heat up.
ttknf is offline   Reply With Quote
Old 05-23-2012, 05:41 PM   #21
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
My Eclipse does this. It's not hot but a little bit warmer than ambient. Even when off it blows some air in so you have to redirect it or shut the vents. But I always have my windows open when it's warm out anyway. Unless it's warm and raining, then I turn the A/C on.
I'm kind of surprised this car would do this though. I thought that was something they fixed/changed with newer models. I wonder if it has something to do with Denso's system.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 05-23-2012, 05:42 PM   #22
Sasquachulator
Pavement Grey
Must be a Toyota thing...(My Corolla does this too)
Here's my solution:
Turn on A/C for awhile till the air is cold.
Then turn off the AC a little later. the air should start to cool down somewhat but will stay coldish.
I've always thought it had something to do with the ambient air temperature outside which its drawing the air from.
The worst part is sometimes i get a nasty smell with the dial on Cold until i turn on the AC which gets rid of it.
Old 05-23-2012, 05:47 PM   #23
Liquidsnake
Drives: "I drives like a Porsche"
My Z used to do this but the heat would be coming from the floor.........after a few months it just stopped on it own.
Liquidsnake is offline   Reply With Quote
Old 05-23-2012, 06:01 PM   #24
fastdrivingjr
fastdrivingjr's Avatar
Drives: Ducati 749 / Ktm Smc lc4 supermoto
My sister has a toyota camry 07 and it has the same problem since we first got it.. you could try before turning off the AC set the temp at a room temp(comfortable car temp) then turn it off. With camrys if you leave the dial on cold , and turn it off you will slowly feel the chill kick in.. Same goes with the dial on hot making your eyes dry out and a swamp in your seat
fastdrivingjr is offline   Reply With Quote
Old 05-23-2012, 06:20 PM   #25
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
Also if it wasn't suggested already, check your oil, in regards to the knock.
86'd is offline   Reply With Quote
Old 05-23-2012, 06:21 PM   #26
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
With the AC off arent you just getting outside air blowing in with nothing cooling it?
rcm47 is offline   Reply With Quote
Old 05-23-2012, 06:22 PM   #27
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
This happened in my Maxima, as well.
Symbiont is offline   Reply With Quote
Old 05-23-2012, 06:39 PM   #28
Big T
Drives: future FR-S
I live in Texas and if the AC isn't on then you won't get cold air period. We can only use the fan with no AC in November.
Big T is offline   Reply With Quote
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 01:28 AM
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 08:56 AM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 06:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 04:58 AM
