Old 02-20-2015, 05:01 PM   #15
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Looks good.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 03-03-2015, 08:29 AM   #16
rlpaul
Drives: point A to point C. Screw point B!
Installed the Always-On Module from @Diode Dynamics last night. Easy peasy install, but need to fix the routing at some point. Was too cold and I couldn't get the headlight harness behind some of the items, so its currently routed over the airbox, etc. Will probably have to wait until warmer weather arrives.
A few days ago somebody apparently backed into my car while it was parked at home. Management is going through the parking garage video, but not expecting much.
Thankfully the GrimmSpeed license relocation kit took the brunt of it:
Excuse all the salt and ice on the car; there's not any actual damage to the bumper. I'm going to contact @GrimmSpeed later to see if they can sell me just the two damaged parts. Luckily, I have a large stash of ti bolts from bike builds if any of those are bad now.
rlpaul is offline   Reply With Quote
Old 03-06-2015, 05:28 PM   #17
rlpaul
Finally had time to take a couple decent photos. Here's a shot of how the interior looks right now:
The black cover for the steering wheel is in. I have a few other ideas brewing, but just moved, so budget is a bit thin right now.
Weather should be better this weekend, so hopefully I can give her a wash and take some proper photos!
Old 03-19-2015, 04:06 PM   #18
rlpaul
Had the car detailed today. Not as nice a day as Monday, so lighting wasn't great for photos, but oh well.
Turns out there is some paint damage to the front bumper. Will require something a little more intensive than the basic detail to correct.
TWS TF-66F wheels are on the boat to @CounterSpace Garage so until they show up, will just keep the winter wheels on.
Without further ado, photos!
A better shot of the @Acree sidemarker:
A few exterior angles:
Interior:
A keen eye will notice my dome light fell again. Think I need a fresh piece of double-sided tape.
Old 04-02-2015, 09:03 AM   #19
rlpaul
Put in my first tank of E85 Tuesday night. Noticed STFT and LTFT rising this morning, so flashed the E85 tune this morning. Looking forward to the changes as the 93 tune was noticeably smoother, if not particularly harder pulling. The 33% reduction in gas price is nice as well. Despite the reduction in mileage E85 brings, should still be cheaper per mile, plus more POWAH.
@Diode Dynamics sent me the RMA for my Always On module, but I unfortunately forgot to change to my new address with them. I checked the status this morning, and USPS has been "forwarding" the package for the past week. Looks like I'll have to drop by the post office and pick it up.
Picked up some more LEDs from DD as well. Front turn signals installed. Y adapter and second SMD-12 board installed in cabin. And LED strip installed in trunk. Haven't had a chance to install the turn signal relay. With how annoying the location is, I may just buy a TapTurn and wait for that to arrive before going through the trouble.
I painted the XP80 turn signal base black with a paint pen I had lying around. Can't see any yellow in the headlight unless the signal is on. Mission accomplished.
Pulled out the passenger side panel for the seat delete and started trimming it to accommodate the armrest. Its taking a lot more trimming than expected. I'll post some photos once I have it trimmed properly.
Old 04-13-2015, 10:43 AM   #20
rlpaul
Sneak peek on my current project:
Mmmm... Alcantara...
Old 04-24-2015, 01:59 PM   #21
rlpaul
What's this???
Old 04-24-2015, 02:37 PM   #22
Scottemad123
Drives: 2014 SWP BRZ Limited
Originally Posted by rlpaul View Post
What's this???
Scottemad123 is offline   Reply With Quote
Old 04-25-2015, 09:14 PM   #23
rlpaul
Old 04-27-2015, 02:11 PM   #24
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
We worked quite a bit with the TWS motorsport engineer and the strongest possible design with the least amount of weight was the ultimate goal for this wheel. You'll find that these small spec changes amount to very large changes in performance.
CounterSpace Garage is offline   Reply With Quote
Old 04-27-2015, 09:34 PM   #25
rlpaul
I only have a few miles on them so far, so can't quite comment too much other than aesthetics. Dropped about 5 lbs per corner over stock. Granted, gained some of that back with the larger, performance oriented rubber on.
I noticed more road feel in my two short drives, but I attribute that to the difference in winter vs summer performance compounds.
I have some experience with Japanese forged parts, so I'm not too worried about the strength. I'm totally digging the attention to detail, such as the shaved spokes.
Quick mounted photo:
Unfortunately, they got a little carried away with the wax lube they use when they mount the tire (sigh). Hopefully won't take too much effort to clean that up...
Old 04-29-2015, 04:44 PM   #26
CSG David
CSG David's Avatar
Thoughts on cutting that gap?
Old 04-29-2015, 06:15 PM   #27
rlpaul
I have indeed been thinking about it!
Just started budgeting for coil-overs. I'm not sure how much track time I'm going to dedicate each year, so that's the biggest question mark right now. That, and I need some new furniture, which is cutting into my car funds. /grumble
That being said, if my choice in wheels isn't an indicator, I'm a fan of doing it right the first time... go big or go home! I'll probably need to have a few discussions to see which direction I should go. And therefore just how much I need to budget.
Old 05-01-2015, 03:51 PM   #28
rlpaul
Keep in mind this is completely stock suspension, and without a performance oriented alignment. I'm missing at least 1.5 degrees of camber up front, and some in the back as well.
brz, cbs, crystal black silica, rlpaul
Scion FRS - Track Dream build - under $20k - Normally aspirated philooo Tracking / Autocross / HPDE / Drifting 85 08-07-2015 10:16 PM
Piercemotorsports FRS Track Build Piercemotorsports Member's Car Journals 42 09-09-2014 07:46 PM
NJMP track after big build - observations dp1 Tracking / Autocross / HPDE / Drifting 15 07-21-2014 12:15 PM
WTB: Local shop for track build DatApex Great Lakes 1 06-17-2013 07:56 PM
