Old 04-24-2015, 06:14 PM   #29
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Swap engine with a V8.
Old 04-24-2015, 07:00 PM   #30
Chad_W
Drives: 2013 BRZ DGM
There's a simple rough way to calculate this....
The highest horsepower per liter on a production car is just shy of 130hp. Let's assume we can't upgrade enough to out engineer Ferrari or the like. Switching to e85 could net 10% on top of that and let's see would punch the engine up to 2.2 liters without compromising it too much.
That puts us at around 315hp at the crank, assuming you build something slightly below a race engine.
Chad_W is offline   Reply With Quote
Old 04-24-2015, 07:31 PM   #31
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Originally Posted by T-Steve View Post
This is actually an interesting question: Given a Formula 1 budget and resources, what power could an ultimate NA FA20 make?
Suppose we could get a BMEP of 200 PSI and spin it up to 13,000 RPM = 400 HP
It's a Subaru, not Honda. Sweet Dreams.
Old 04-24-2015, 07:56 PM   #32
Kostamojen
Its been done, but with an EJ20:
Also note: This wagon had a FR layout with the engine moved far back/down low and the suspension geometry lowered dramatically... Basically a wagon BRZ/FRS in 1998
The Following 3 Users Say Thank You to Kostamojen For This Useful Post:
chaoskaze (04-26-2015), Quentin (04-28-2015), SR5 (04-25-2015)
Old 04-24-2015, 08:05 PM   #33
Dimman
Kuruma Otaku
Dimman's Avatar
There is a guy in Aus that has taken a BEAMS 3SGE to 340 crank HP on E85 (still 2.0L). I mention a bit of what he's done to get there in the BEAMS swap thread.
Look up 'RA45 Celica BEAMS' to see what the guy's done to get there. Neither cheap nor easy.
Because titanium.
Old 04-24-2015, 11:45 PM   #34
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Originally Posted by BboyKidKoda View Post
Is there anyway to get 350-400hp out of this car without fi. And around how much compared to just boosting would it cost.
No real way to get 350-400hp out of the fa20. And even if you were somehow able to, it would likely be pretty unreliable. On top of that if you were going to go the na route you'd likely be forced to make a lot of custom parts as they don't yet exist for our car. Boosting would likely be the easier route. Most people seem to be happy with 300hp from this car though.
tyler_win_photo is offline   Reply With Quote
Old 04-25-2015, 12:29 AM   #35
SR5
SR5's Avatar
Drives: Raven
swap vs boosting, hmm? $$$ could be pretty close.
if you had to keep if FA20 NA, it would take a hell of a lot of money to get it to 350.
different Fuel and under the right Atmospheric conditions 300hp can be done. 350whp is a whole different story.. maybe in another Planet?
something smelly, and you still have crickets..
SR5 is offline   Reply With Quote
Old 04-25-2015, 07:52 PM   #36
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Honda S2000 (1st gen) 119 hp/litre @ 8,300 rpm
Ferrari 458 Speciale 132 hp/litre @ 9000 rpm
Hyper4mance2k's Frankenstein 13B 147.3 hp/l @7200 RPM
Caparo T1 159.3 hp/litre @ 10,500 rpm
Old 04-26-2015, 01:28 AM   #37
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Hyper4mance2k's Frankenstein 13B 147.3 hp/l @7200 RPM (192whp @7200 RPM, 148 ft lbs @ 6k RPM)
I build carbed rotaries. My last engine build saw over 30k street miles, 20+ autoXs, 4 dyno sessions, managed to average 21MPG, and after 3 years under my hood it has been running in a friends car since 2012. I have no idea how hard he is on it. I'll build you a 13B if you're interested, but you've got to figure out how to shoehorn it into your 86. LOL
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following 2 Users Say Thank You to Hyper4mance2k For This Useful Post:
Captain Snooze (04-26-2015), chaoskaze (04-26-2015)
Old 04-26-2015, 02:16 AM   #38
Captain Snooze
Drives: Red Herring
Fixed
Hyper4mance2k (04-26-2015)
Old 04-26-2015, 02:20 AM   #39
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Also, that engine build was all stock ports with no porting. To this day, I believe no one has made more power on a -hybrid or not- stock port 13B.
Old 04-26-2015, 02:31 AM   #40
Captain Snooze
Drives: Red Herring
*raises hand*
How does one increase a rotary's specific output without porting? I thought porting was all there was available (excluding fi).
Over here porting refers to any port work. Maybe over there porting might only refer to bridge and/or peripheral.
(Such a rarity now days to hear a ported car with the engine mad hunting at 2k idle)
Old 04-26-2015, 02:39 AM   #41
Captain Snooze
Drives: Red Herring
Any port in a storm.
Old 04-26-2015, 03:07 AM   #42
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
*raises hand*
Porting is like porting the head and installing a larger duration cam at the same time. It increases flow rates through the block, and changes port timing. As with any otto cycle internal combustion increasing flow rates in and out of the engine will increase volumetric efficiency and increase power. Swapping from the stock exhaust manifold on a NA rotary to an efficient header can yield actual 20 whp gains.
Is the FA20 a dud? No high horsepower use? hmong337 Engine, Exhaust, Transmission 115 01-22-2014 02:54 PM
High horsepower, straight line car forums... husker741 Scion FR-S / Toyota 86 GT86 General Forum 42 11-01-2013 12:50 PM
What's high horsepower to you? dem00n Off-Topic Lounge [WARNING: NO POLITICS] 41 04-13-2013 01:08 PM
Who says we need more horsepower? LeeMaster Scion FR-S / Toyota 86 GT86 General Forum 36 01-11-2013 11:05 AM
