Old 04-23-2015, 03:33 PM   #2437
DeaconRoc
Drives: GT86
Originally Posted by solidONE View Post
Can you share what brand dampers you are using?
They are Meister R bodies with Black Art Designs internals.
DeaconRoc is offline   Reply With Quote
Old 04-24-2015, 12:06 PM   #2438
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
I am thinking to purchase & install the whiteline subframe and trans bushing, and perrin trans bushing. However, the weather is still kinda cold here (about 40-45F). Are these bushings being recommended to be installed at a warmer weather? or as long as there is no road salt on my under body I should be good to install them now?
Thank you!
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 04-24-2015, 12:10 PM   #2439
jvincent
jvincent's Avatar
Only reason to wait for warmer weather is that being under the car in the cold sucks.
The Following User Says Thank You to jvincent For This Useful Post:
Figo (04-24-2015)
Old 04-24-2015, 12:14 PM   #2440
Figo
Figo's Avatar
Haha thanks.
If there is road salt, I think they might scratch and rust my frame.
Now there is no road salt, so I think the rubber might be hard because of the low temperature and being difficult to fit in after I installed them.
Old 04-24-2015, 12:21 PM   #2441
jvincent
jvincent's Avatar
The bushings shouldn't be affected by the cold too much and IIRC there is only one that needs to be stretched on, but it was an easy fit.
The hardest part of the sub-frame install is making sure that you don't crossthread the bolt going back in. Make 100% sure that you've got it threaded by hand before putting any tools to it.
Figo (04-24-2015)
Old 04-24-2015, 12:26 PM   #2442
Figo
Figo's Avatar
Thank you so much!
Old 04-24-2015, 12:34 PM   #2443
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by Figo View Post
Thank you so much!
No issues with my car and all the bushings I have from Whiteline in my car (I have all of them) after two winters here. See my build thread for the list. No salt on the west side of 'murica however.
The Following User Says Thank You to stockysnail For This Useful Post:
Figo (04-24-2015)
Old 04-24-2015, 01:46 PM   #2444
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
OK, not sure if I just missed anything or it hasn't been brought up yet, but...
How should I go about balancing aero with suspension upgrades? Currently stock on both, but planning to get aero (driveway labs splitter, side skirts, and diffuser, and a gt wing), then coilovers, then a bbk as funds allow.
I plan to track about 4-6 times per year depending on work and finances. Currently have only done 2 weekends, with another coming up in may. Then none for a while.
My skill level definitely doesn't really require any of them just yet, but I'm also going to do it anyways because I love the look, hence the upgrade order. But if adding the aero will make the ride worse without stiffer spring rates/better dampening/anything else I'll get the coils first and the aero right after.
I'll be ending up around 260whp once I reinstall my supercharger, and goal is 300whp once I get flex fuel.
ScionOfHorus is offline   Reply With Quote
Old 04-24-2015, 01:51 PM   #2445
gramicci101
Off Topic
You should probably do the suspension first. Otherwise how will you know what aero treatments you need?
Old 04-24-2015, 01:52 PM   #2446
ScionOfHorus
Because they look awesome
Old 04-24-2015, 02:12 PM   #2447
Pat
Pat's Avatar
Drives: 2023 BRZ
You're putting the cart before the horse. The short answer: you won't notice any performance difference with aero until you improve your driving significantly.
Balancing aero with suspension is about item number 27 on your list of things to consider.
Adding aero now won't make the ride worse. Adding aero now will take away funds that could otherwise be used to make yourself a better driver and make your car perform better. If you prioritize the look of aero above improving your driving or your car's performance, by all means, buy some aero now. It's just not the route I would go.
Old 04-24-2015, 02:16 PM   #2448
ScionOfHorus
I go out and track when I can. It's not so much a money issue, as it's a time issue. And I've already used all my vacation days this year...
But I'm going to just be sure... Aero first won't significantly change the handling, so I'll be just fine until I'm a better driver?
Old 04-24-2015, 02:40 PM   #2449
Racecomp Engineering
I've seen very of these cars with "real" aero...the kind that produces significant downforce and requires significant suspension changes.
If you do get a decent aero package going, you may end up changing out springs to dial things in just right, so I'd recommend a quality damper with some valving range and separate compression and rebound adjustment (2 way).
Depending on your tire choice, I'd do the BBK first, then coilovers, then aero.
- Andy
Old 04-24-2015, 02:41 PM   #2450
jvincent
jvincent's Avatar
There are aero threads that talks about the reduction in lift from adding a splitter and a rear diffuser that you probably want to look at.
To summarize, the balance of the car changes depending on what you do. Adding a wing on top of that will probably make the balance changes larger.
If you do it up front, and learn with it that way, then you'll probably by OK in the long term, but it might take you longer to get better.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
