Old 04-23-2015, 11:18 PM   #1
wootwoot
Drives: FRS
Wrapping stainless header
I just bought a new Tomie header and was thinking of wrapping it with Titanium wrap. I have been researching on the web and people swear up and down that wrapping a mild-steel header degrades it but I can't find any info on wrapping stainless. I would prefer to wrap as oppose to coating it as the wrap is much more effective. I really have two worries:
1. Will the wrapped header send more heat into my secondary cat and burn it out?
2. Will the wrap fatigue the stainless and shorten its life span?
Old 04-23-2015, 11:26 PM   #2
Teseo
Drives: frs
Best option is to do is a profesional ceramic coat
The Following 3 Users Say Thank You to Teseo For This Useful Post:
Apoc (04-24-2015), JB86'd (04-23-2015), JohnJuan (04-25-2015)
Old 04-23-2015, 11:56 PM   #3
wootwoot
Drives: FRS
Coating is not as effective. Wrap has come a long way in the last few years and that is what I am asking about. Looking for Experiance and/or research to make this choice.
Old 04-24-2015, 12:11 AM   #4
Turdinator
Señor Member
Turdinator's Avatar
1974 TA22 Celica
2013 86 GT
The Following 4 Users Say Thank You to Turdinator For This Useful Post:
Dimman (04-24-2015), DustinS (04-28-2015), Hyper4mance2k (04-28-2015), industrial (04-24-2015)
Old 04-24-2015, 12:16 AM   #5
swarb
Melting point of stainless is very high so it won't make a difference. It would take many many heat cycles before the header would degrade, probably in the thousands if not much more.
Cats are made to handle the heat, they probably work better at higher heat.
I've seen a header wrapped and removed about 3 years later with no problems.
We have a underpanels and pretty much no rain/salt in cali to speed the corrosion process.
DO IT. Or double up and ceramic coat it and wrap it.
Old 04-24-2015, 02:58 PM   #6
wootwoot
Drives: FRS
Anyone else?
Old 04-24-2015, 03:17 PM   #7
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Swaintech coating is
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
Old 04-24-2015, 03:23 PM   #8
wootwoot
Drives: FRS
Evidence? I have yet to see a coating that performs better than an actual barrier like wrapping. The coatings are just not thick enough to compete.
In any event, I'm asking about header wraps, not header coating.
Old 04-24-2015, 03:25 PM   #9
wootwoot
Drives: FRS
Originally Posted by vroom4 View Post
Mines coated with swaintech, cool to the touch in the surrounding area. leaks at slip joint though
Leaks? That sucks.... Are you saying the coating is causing it to leak?
Old 04-24-2015, 03:47 PM   #10
aghuman
aghuman's Avatar
Drives: 2013 Asphalt FR-S
Is the purpose of the coating/wrapping to help in thermal efficiency or for an extra layer of corrosion protection?
aghuman is offline   Reply With Quote
Old 04-24-2015, 03:50 PM   #11
wootwoot
Drives: FRS
Keeping engine bay temps as low as possible. Anything else is just a bonus in my opinion.
The Following User Says Thank You to wootwoot For This Useful Post:
aghuman (04-27-2015)
Old 04-24-2015, 04:33 PM   #12
vividracing
vividracing's Avatar
Wrapping doesn't help with corrosion protection, ceramic does.
Ceramic doesn't insulate, wrapping does.
That's the basic premise of either option. If you're worried about the header metal deteriorating or rusting, ceramic is best, but ceramic also is a good conductor of heat and will absorb and transmit the heat into the engine bay anyway. Ceramics also look good and you can get it colored to practically anything you want.
Wrapping is made of mostly fiberglass, and that's the same material most houses are also insulated with for the same reason. Fiberglass is a poor conductor of heat and doesn't absorb and transmit heat, it reflects it, in which case back to the pipes. Will it still be hot? Yes of course, but it doesn't transmit as much heat to the engine bay and that's the main purpose. The downside is that wrapping can absorb water and since it's not bonded to the pipes, water can seep to the pipes and stay there because of the wrapping. If your pipes are not made of stainless and made of iron, you're likely to get rust. Luckily though if you drive it, the heat will make the water evaporate, so if it rains or you wash your engine bay, a quick drive will dry it up.
I wrapped my OFH headers in black wrapping and I do in fact notice it's cooler than before compared to the stock headers. I figure this by putting my hand close to the headers and feeling the radiating heat after driving. The stock headers I can feel a lot of heat radiating out, with the wrap, I can have my hand like 1/2" away from it and only feel it's warm.
It was super difficult to wrap for me, never having experience, and I had to throw away my t-shirt cause of the fiberglass fragments getting into it, it's not possible to wash out! I had to wear a mask and gloves too. It took me a good 2 hours to wrap and spray with the coating.
-RyanG
vividracing is offline   Reply With Quote
The Following 3 Users Say Thank You to vividracing For This Useful Post:
aghuman (04-27-2015), SuperTom (12-24-2019), wootwoot (04-24-2015)
Old 04-24-2015, 04:48 PM   #13
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
I just wrapped my header, overpipe, and front pipe. I don't have cats in my system. I did notice a big difference in the engine bay. The heat radiating out after a drive is less, and the engine bay cools a lot faster when you open your hood.
Here's my thread about my wrap: http://www.ft86club.com/forums/showp...&postcount=399
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
Old 04-24-2015, 05:13 PM   #14
Tbird232ci
Drives: 2013 FRS
-RyanG
If you're using fiberglass wrap, soak it in water before wrapping. It keeps the fibers from floating around, and makes it easier to work with. With it wet, you can wrap and pull it tighter without it unraveling.
Tbird232ci is offline   Reply With Quote
RS1 Vinyl Wrapping KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 5 04-10-2015 09:58 AM
Car Wrapping in Northern NJ Verbal21 NY / NJ / CT / PA 10 03-27-2014 06:58 AM
DIY vinyl wrapping Maui AFRICA 9 01-28-2014 03:22 AM
FA20CLUB 4-1 EL STAINLESS STEEL HEADER FA20Club.com Engine, Exhaust, Bolt-Ons 12 04-23-2013 01:18 AM
