Old 08-20-2014, 12:12 PM   #589
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
So did that take care of it?
Originally Posted by CJB View Post
I finally found the source of my BRZ's "ticking". I'll post more details if anyone thinks they may have the same issue, but for now I'll keep it short.
It was coming from the brackets that mount the rear seat to the car's frame. No, not the hooks on the top that have been mentioned before, but the brackets on each side at the base of the rear seat. I didn't take any pictures, but you can see what I'm talking about in this write-up explaining how to remove the rear seat. It's the black bracket on each side (labeled "hidden bracket" in the linked post).
I removed the bottom part of the seats, loosened the three bolts of each bracket, added some grease behind the bracket and re-tightened them. That was it. For good measure, I went back later and added some thin adhesive felt where the brackets make contact with the frame of the car, but that may not even be necessary.
So if you hear a ticking/cracking sound when backing down the driveway, hitting a bump or taking a sharp turn, this may be something to investigate.
Jmonty is offline   Reply With Quote
Old 08-21-2014, 08:09 PM   #590
CJB
Drives: 2013 BRZ Premium MT
Yup, sure did. Upon closer inspection, there were a few bent/crooked metal lock washers that I suspect were the cause. Flattened them out and re-assembled, problem solved.
CJB is offline   Reply With Quote
Old 08-31-2014, 01:12 PM   #591
drifter-s
drifter-s's Avatar
Drives: 2013 Whiteout FR-S
After fixing a couple other rattles from the deck, I discovered there were still some coming from somewhere. I pinpointed mine to the rear corner panels where the rear deck and window meet.
There are two white clips that secure the panel and they are not the most secure. I used rubber cement (easily removable/reversible) along the base of the clips to better secure them (sorry no pics). I left the clips secured to the panel and brushed the rubber cement along the base of the clip and clip attachment point on the panel. Reinstalled and no rattles to speak of!
Be careful when removing the panels initially. The clips like to fall out.
drifter-s is offline   Reply With Quote
The Following 3 Users Say Thank You to drifter-s For This Useful Post:
CJB (09-06-2014), MJones_RB (05-19-2017), nzer (08-31-2014)
Old 10-20-2014, 06:40 PM   #592
Mikeez
Engineering Student
Drives: Scion FR-S 2015
I am having the same issue, I will investigate the matter soon. I will be posting a thread.
Mikeez is offline   Reply With Quote
Old 03-26-2015, 03:03 PM   #593
Mikeez
Engineering Student
@Mikeez
lol
There’s no time to stop for gas, we’re already late
Old 03-26-2015, 03:14 PM   #594
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
I had forgotten all about this, but now that i think about it, my car has stopped popping from the rear deck. Either that, or I just don't notice it anymore. But I don't think that's it, because it used to annoy the $hit out of me.
I'm not really sure when it quit, but I don't recall hearing it for some time now. I've got just shy of 20k miles on it. Maybe all the spot welds eventually broke loose on their own.
Other than a driver's side window seal that rolls over and causes a slight air leak, I don't really have any squeaks or rattles in my 2013.
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 04-20-2015, 01:33 PM   #595
Ayrton
Ayrton's Avatar
Drives: 86 HS AFE filter, BRZ Xors, Kaymak
Thanks man! Absolutely spot on. That knock was driving me crazy! Did as you said and hey presto! No noise since I repaired last month. Very pleased.
GT86 Power Brakes, AFE Filter, BRZ Xhorst,
Kamak Header, Phoenix Performance 95 RON Tune.
Ayrton is offline   Reply With Quote
Old 04-23-2015, 05:39 PM   #596
CJB
Glad to help! Still noise free on my end.
The Following User Says Thank You to CJB For This Useful Post:
Ayrton (10-15-2015)
Old 04-24-2015, 02:09 PM   #597
cycleboy
Drives: 2013 Scion FR-S - Argento
After messing with this off and on for awhile and quieting some things down, I still have the loudest/worst sound.
I'm convinced it is the seat latches. If I put the rear seat down it stops and if I grab the release handle and shake it a bit, the latch mechanism inside the rear seat back makes what sounds like the same thing I'm hearing. Because it is inside the trunk when it happens, it's LOUD.
I shoved a piece of foam down into the latch area, but it hasn't seemed to do much. The problem is there's NO space to get anything in there to tighten up the wobbliness in the latches. I tried various things and so far nothing working. This weekend I'll try putting something on the brackets the latches grab onto. Perhaps making them latch tighter will stop them from moving around.
cycleboy is offline   Reply With Quote
Old 04-24-2015, 02:23 PM   #598
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
I wrapped the seat latch bracket piece so it latches on tighter and that got rid of the rattles for me. I used frost king felt weatherseal and double sided 3m tape.
sprintertrueno86 is offline   Reply With Quote
Old 05-15-2015, 10:59 PM   #599
cycleboy
Ok, I stuck a piece of double sided tape on each seat latch U and I think (fingers crossed!) it may have gotten rid of the really loud and annoying popping and clunking.
Old 02-01-2016, 07:35 PM   #600
Limited
Drives: Monogram FR-S
I recently noticed the clicking noise 15K miles in...searched the forums, found this post, followed the instructions using WD40, and sanity restored! Thank you OP!
Limited is offline   Reply With Quote
The Following User Says Thank You to Limited For This Useful Post:
Sigh-on-Rice (02-01-2016)
Old 02-10-2016, 10:16 PM   #601
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Rear Deck "popping/clicking/tapping/ticking" noise.
You can fix it also permanently with my DIY because I thing only with WD40 the problem will came back... http://www.ft86club.com/forums/showthread.php?t=44636
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 09-06-2016, 02:51 PM   #602
lugao
Drives: 2015 Subaru BRZ Series.Blue
Hey guys, I just complained about my rear deck popping sound on my 2015 BRZ to the dealership near me and I told them that there is a TSB for this (12-140-12), The said that the TSB only applies to 2012 BRZs. Is this true? Thanks in advance!
lugao is offline   Reply With Quote
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) -- General Topics 59 12-01-2013 12:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 02:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) -- General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
