Old 04-18-2015, 09:57 AM   #15
eddieflyinv
eddieflyinv's Avatar
Well that's what I'm counting on I guess :/ I know I've come across some related issues in other threads as well, I'll just be sure to include lots of details in this thread with the pretty straightforward title lol
eddieflyinv is offline   Reply With Quote
The Following User Says Thank You to eddieflyinv For This Useful Post:
Tcoat (04-18-2015)
Old 04-18-2015, 12:21 PM   #16
ls1ac
ls1ac's Avatar
Just for the sake of giggles, did you disconnect the battery for ten minutes and then reconnect. With pure dumb luck sometimes things will reset.
The Following User Says Thank You to ls1ac For This Useful Post:
eddieflyinv (04-19-2015)
Old 04-18-2015, 04:05 PM   #17
blown
Drives: ft86
they wont work.. it'll come on once the car switches on and will not turn off until you pull the battery..
blown is offline   Reply With Quote
Old 04-19-2015, 06:50 PM   #18
eddieflyinv
Aha nah .. it was disconnected for an entire day or 2 and didn't change anything :p not that lucky, I'll update the thread Thursday when I find out what's up
Tcoat (04-19-2015)
Old 04-22-2015, 01:14 AM   #19
blown
Drives: ft86
junction block did nothing.. going to try the gauge cluster.
Old 04-22-2015, 07:18 AM   #20
steve99
Drives: FT86
just be aware that you cannot just swap the dash cluster, as its part of a secutity set with the ecu and imobiliser modules. you either swap all three as a set ot you will need to get dealer to recode the new dash cluster to work with the ecu\imobiliser.
Tcoat (04-22-2015)
Old 04-22-2015, 06:25 PM   #21
blown
Drives: ft86
yeah, we're not trying to start the car , just verify that it fixes the issue of the light staying on.. if it does fix it I will be ordering another cluster to have my local tuner program the keys to it..
The Following User Says Thank You to blown For This Useful Post:
steve99 (04-22-2015)
Old 04-22-2015, 07:57 PM   #22
steve99
Drives: FT86
i dont think any tuners can do the security coding for security set modules, its generally dealer only and closly guarded, as it stops you stealing cars by swaping in an imobiliser and key set.
Old 04-23-2015, 01:15 AM   #23
blown
Drives: ft86
wasn't the gauge cluster either, so now we're looking at wiring issue somewhere.
Old 04-23-2015, 04:48 PM   #24
Boostedpro
I would try replaceing the dimmer switch relay. According to the wiring diagrams it ties into the high beams and interior lighting which is also tied into the exterior lights. It should be in the underhood fuse block labeled as "dim relay". I think the relay took a power hit and getting stuck in the closed position which is making the car think the lights are on.
Boostedpro is offline   Reply With Quote
Old 04-29-2015, 05:28 PM   #25
blown
Drives: ft86
Not dim relay
Old 05-02-2015, 04:28 PM   #26
blown
Drives: ft86
not biu/relay/gauge cluster/junction block.
stumped but they are back probing all the pins on the biu to verify what is back feeding to the biu to make it think the lights are on.
Old 05-02-2015, 09:28 PM   #27
eddieflyinv
Hey guys, trip to the dealer cost me $750.. there was a broken ground somewhere in behind the bcm, the short never made it that far and I guess after they fixed the ground the hazard fuse blew, and I'm not sure if it was before or after the fix, but my headlights were both toast too, got so hot they melted lol
So it wasn't the BCM, just a broken ground and the short... Took them 5 hours in Labour to figure out, and then the cost of the headlights and a fuse and yeah... I'll never touch electrical again.
The Following 2 Users Say Thank You to eddieflyinv For This Useful Post:
Fastbrew (05-03-2015), Tcoat (05-03-2015)
Old 05-03-2015, 12:37 PM   #28
Chaetagnath
Drives: Whiteout FRS
Wow, that was a tough one. Thanks for sharing your saga, may help someone in the future. Did they tell you exactly which ground point was broken?
Chaetagnath is offline   Reply With Quote
Hot fuse tap - Which fuse? cgrey Electronics | Audio | NAV | Infotainment 9 09-17-2016 08:24 PM
Fuse box. Chen Northwest 4 01-19-2015 04:51 PM
Best fuse to tap that is hot with car off? Frs32907 Electronics | Audio | NAV | Infotainment 0 08-30-2014 11:11 AM
Fuse Box beagoodruslan Electronics | Audio | NAV | Infotainment 0 04-20-2014 12:31 AM
Does anyone know the secret to Japanese fried rice? jLoBRZ Off-Topic Lounge [WARNING: NO POLITICS] 12 03-27-2014 02:26 AM
