Old 04-22-2015, 09:16 AM   #29
raven1231
Originally Posted by BBYZILA View Post
When I cilck write on the OFT, it gives me 5 options IIRC, stg1 stg2 EL, stg2 UEL, stg2 EL E85, stg2 UEL E85. I just picked stg1...
my OFT came pre loaded w/ the latest tunes i believe.
If you go to their site you can download tunes specific to 91, 93, and e85. Just need to get your CAL ID off of the tablet.
BBYZILA (04-22-2015)
Old 04-22-2015, 09:17 AM   #30
raven1231
Go here : http://openflashtablet.com/BRZ_FR-S/...s-4/index.html
Old 04-22-2015, 09:17 AM   #31
raven1231
you will need to download the openflash manager too at the top of the page
Old 04-22-2015, 09:56 AM   #32
tennisfreak
Drives: 2018 BMW M240i
Pre OFT + OFH:
Post OFT + OFH:
The Following 8 Users Say Thank You to tennisfreak For This Useful Post:
BBYZILA (04-22-2015), flippy (05-18-2016), jvincent (04-22-2015), KalbiCool88 (11-29-2016), MattTheGinge (12-02-2016), mgarcia707 (08-20-2018), raven1231 (04-22-2015), Stealthy (04-23-2015)
Old 04-22-2015, 09:58 AM   #33
jvincent
jvincent's Avatar
It most likely defaults to 91 octane tunes, but to be sure, follow the other advice given above.
Old 04-22-2015, 10:55 AM   #34
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Just how noticeable is OFT+OFH and stage 2 tune?
Originally Posted by tracerit View Post
NOOOOO!!!!! I got the OFH primarily to get rid of the rasp. Now you're saying it still exists with an UEL map? :/ Makes me wonder if I should even install it (currently sitting in my garage for another two weeks).
I'm not sure what noise he was talking about but there is no rasp at all with the open flash header installed. I did heavy amounts of reading before I made the purchase and the cause of the rasp on stage 1 tune on a stock car was from a drastic increase in timing in the 4k torque dip area of the rpm band. That drastic increase in timing is not needed compensate for the the dip once the catless open flash header is installed. So the thing that is causing the sound literally isn't happening anymore
Kronos is offline   Reply With Quote
Old 04-22-2015, 11:02 AM   #35
BBYZILA
BBYZILA's Avatar
Drives: 2013 Firestorm FR-S
thanks everyone, i followed raven's advice and uploaded my oft w/ 93 tune and have then wrote it to my ecu. will report back.
BBYZILA is offline   Reply With Quote
The Following User Says Thank You to BBYZILA For This Useful Post:
Old 04-22-2015, 11:43 AM   #36
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
I've been following OFT for a bit. Can you tune for a catted header?
V_86 is offline   Reply With Quote
Old 04-22-2015, 12:01 PM   #37
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Stage 1 is what they recommend for a catted header. I am running a TRD Intake/Catback and FT86SpeedFactory UEL Catted Header with the Stage 1 OFT tune. Many members on this forum have been running an identical or similar setup with success.
Absolutely changed the character of the car
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline   Reply With Quote
The Following 2 Users Say Thank You to Re~Mix For This Useful Post:
KalbiCool88 (11-29-2016), Mr.Impreza (02-01-2016)
Old 04-22-2015, 02:42 PM   #38
V_86
V_86's Avatar
To follow up, I'm assuming catless just adds sound and power, but catted causes less CEL/ECM issues.
Old 04-22-2015, 03:21 PM   #39
jvincent
jvincent's Avatar
If you use the OFT/OFH you won't get a CEL.
The Following 2 Users Say Thank You to jvincent For This Useful Post:
KalbiCool88 (11-29-2016), pinski (04-22-2015)
Old 04-22-2015, 03:58 PM   #40
V_86
V_86's Avatar
True, but I want a header with a matte finish, and some filtration of smog gasses. Shiny object in engine bay = ticket for aftermarket mods in California, if inspected.
Old 04-22-2015, 04:27 PM   #41
jvincent
jvincent's Avatar
I believe that if you use the OFT tune it will mask the CEL no matter what header you use. Not 100% sure of that though.
Old 11-29-2016, 07:21 PM   #42
Ahernandez0909
Ahernandez0909's Avatar
Drives: '13 Asphalt FR-S M/T
Originally Posted by vividracing View Post
I have an Invidia N1 cat-back and combined with the OFT/OFH it sounds amazing. The performance difference isn't that much in my opinion. It does seem to accelerate a bit better, and through 2nd-4th gears it opens up.
I will be getting my car dyno'ed soon with a couple of FRS to compare modifications and finally learn my gains, as one of the cars is stock.
I'd buy the OFT/OFH and cat back just to change the sound and make it super sexy, which it is.
-RyanG
This was over a year ago, but I'm trying my chances lol. Updates? I'm about to do this exact thing.
Yes, yes that is a Scion.
Member Journal
Ahernandez0909 is offline   Reply With Quote
The Following User Says Thank You to Ahernandez0909 For This Useful Post:
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
OFT Stage 2 UEL tune concern iris mm Software Tuning 19 03-16-2015 06:46 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
Perrin Stage 1 Tune brz007 Northwest 5 10-03-2012 05:59 PM
