#43 |
Drives: 2013 Asphalt FRS M/T
#44 | |
Drives: '11 Cayman , '14 Camry, '11 Tacoma
#45 | |
Drives: 2013 GBS BRZ Limited
After I caught myself ONE TIME shifitng into reverse while still moving forward I STOPPED DOING THAT! I realized what I was doing before I let the clutch out but it was close. |
| The Following 2 Users Say Thank You to stugray For This Useful Post: | Bonburner (04-22-2015), ToySub1946 (04-21-2015) |
#46 |
Drives: GMC
Will resting your hand on the shifter void your warranty?
#47 | |
Early automotive gearboxes were "top loaders, with the shifter mounted on a plate on top of the tranny, and connected to the shifter forks directly. Every modern gearbox that I know of is actually "controlled' by a series of linkages connected to a "remote mounted" shifter, like our cars. Here is a pic of the Aisin gearbox as used in the twins. Note the rear-mounted shifter. Last edited by billwot; 04-21-2015 at 06:49 PM. |
#48 |
#49 | |
Drives: Yes
Anyway, I can see how it's not the perfect way to operate this piece of machinery, but I'm also not really worried that "resting" my almost weightless hand (I have an armrest that I actually lean most of my weight on) is doing any damage. There's plenty of feedback from the shifter to let you know when you're actually causing friction.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#50 | |
I suspect all linkage-operated shifters have stops. I know both of my MR2s did. |
#51 |
Drives: MY11 Maxima 350st, MY15 BRZ
Buying an A/T was great. Saved me money on an armrest too
![]() If just puttering around in traffic I find it quite comfortable to rest my palm on the shifter. It all comes down to how far forward or back you sit. I sit 2 or three clicks (on the seat rails) from the back and can't seem to find any other comfortable place for my arm. Even if I were to have an arm rest installed. Two hands on the wheel, unless in attack mode, is just not comfortable in general cruising.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
#52 |
Drives: frs 1.0
The only thing I have noticed is how cold the shifter is. The other front engine cars I have had from the 70s and 80s heat up the shifter shaft and knob pretty well.
#53 | |
Drives: FRS-RS1, Triumph Speed Triple, Lola
#54 | |
Drives: 2015 Fire
#55 |
two ways to solve this while resting your hand/arm...buy an automatic or buy the freak'n arm rest
#56 |
Look at the pic! There is no way moving the shifter from side-to-side transmits any force or motion to the linkage that actually moves the shifter forks. The linkage rods ONLY move forward and backward, never from side-to-side.
| Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? | soulstice | Cosmetic Modification (Interior/Exterior/Lighting) | 52 | 01-24-2016 08:20 PM |
| Shifter springs/bushings/shifter performance | Darnold | Engine, Exhaust, Transmission | 10 | 10-22-2014 11:49 PM |
| kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 01:41 AM |
| TRD Short Shifter Quick Shifter Scion FRS | hirollaz | Transmission and Driveline | 3 | 04-15-2014 01:24 AM |
| Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing | swansons | Issues | Warranty | Recalls / TSB | 4 | 02-02-2014 02:27 PM |
