Old 04-20-2015, 04:55 PM   #57
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Can't wait to see this thing in person Pete!
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 04-21-2015, 03:31 AM   #58
enigma
Drives: Asphalt 86
Originally Posted by 350matt View Post
if you're getting a lean signal combined with the noise have you checked all round the injector seals ? as these had to be moved over between manifolds
best way to find a vac leak is to spray butane / cigarette lighter gas carefully around each possible leak path as the engine pulls it in as fuel and will rev up if thats the source of the leak
Thanks Matt! Cosworth recommended looking there as well.
I'm going to try and get to it tomorrow, but it will be Wednesday at the latest.
I will say this. Thompson @ Cosworth USA has been incredibly helpful. He's been in constant contact with me since I reported the issue to me and has been trying to help troubleshoot from across the country. The customer service has been absolutely fantastic. He has put me into contact with one of the Senior Development Engineers who is working with me to try and sort the issue out as well.
I can give nothing but high praise for the kit. While this little hiccup is frustrating, these guys have been on their A game since day one with the assistance.
If I can get this sorted this week, I'm going to try and hit the dyno on Thursday, so stay hopeful, internet world! That's the last piece in my puzzle before compiling the video I've taken and making something useful.
enigma is offline   Reply With Quote
Old 04-21-2015, 08:44 AM   #59
JerryIII
Drives: Subaru BRZ
I will second what great service they provide. Chris is very good and gets thing done. Once you get it running smooth you will love it. Just burnt a hole in my #2 piston. waiting to get it rebuilt.
JerryIII is offline   Reply With Quote
Old 04-21-2015, 01:32 PM   #60
enigma
Drives: Asphalt 86
Holy crap Jerry! What in the world happened?
Old 04-21-2015, 02:08 PM   #61
JerryIII
Drives: Subaru BRZ
not to sure what the cause was. In the process of a rebuild.
Old 04-21-2015, 03:32 PM   #62
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by enigma View Post
That'd be awesome man! We could always use more 86 track rats around here.
Hey guys, I live in Denver, but will be in Wichita on the 8th for a lunch meeting. I know it's a long shot, but is anyone up for an early afternoon beer that day? I have to be in KC by 5:00.
Old 04-21-2015, 04:39 PM   #63
350matt
Drives: toyota mr2/ Toyota GT86
Sorry to hear that Jerry
what fuel was it running on? Or any signs of low fuel pressure before it had the issue?
350matt is offline   Reply With Quote
Old 04-22-2015, 08:49 AM   #64
JerryIII
Drives: Subaru BRZ
91 running map 1 and DW 65c fuel pump
Old 04-22-2015, 04:18 PM   #65
350matt
hello Jerry
I take it map 1 is cosworths' low octane 91 ( would be 95 in the UK) map ?
do you have any ECUtek logs of the car running?
Old 04-22-2015, 05:30 PM   #66
JerryIII
Drives: Subaru BRZ
no logs
Old 04-23-2015, 05:47 AM   #67
350matt
Thats a shame about no log data,
were you low on fuel at the time? as I know these cars can struggle with fuel pickup at anything less than a 1/4 tank of gas
one other thing is I've heard the DW65 pump isn't that reliable?
especially if there's any ethanol in the fuel - I'm not talking E85, just the 10% thats quite common in pump gas these days
however these guys do an E85 pump
http://asnuusa.com/ASNU92-FP330E
so might be an idea to swap?
cue loads of people now saying DW 65 is the best pump ever and they have fitted onto every car they own.....
Old 04-27-2015, 12:55 AM   #68
enigma
Drives: Asphalt 86
Well, it looks like my problem may be solved, and it looked to be user error (doh!)
When I was checking for vacuum leaks, I checked the connections for both the front and rear crank case breather hoses, but I didn't reach under the manifold and check the hoses themselves. As it turned out, I was likely having a vacuum "restriction," versus an actual leak. When installed the front crankcase breather, I set the hose for the path of least resistance: a straight line to the intake pipe that it was hooking into. What I didn't take into account, however, was how close of a tolerance there was between the bottom of the supercharger and the top of the engine. So, the hose actually was pinched underneath the supercharger, unable to move, and essentially being partially crushed.
Unbolted the manifold, removed the belt, lifted the manifold, relocated the hose, and my noise is gone! Everything seems to be running well. I've sent logs to Cosworth for review just to make 100% sure everything looks good, but I'm feeling optimistic!
I've scheduled time at the dyno next week to finally strap this thing down and see how much power she makes. Once that's done, I'll format my video and finally post that up! Stay tuned folks!
Old 04-27-2015, 12:56 AM   #69
enigma
Drives: Asphalt 86
Pat, I may be game for that. I usually have a little free time in the afternoon on Fridays. Let me know when you're in KC and we could possibly meet up!
Old 04-27-2015, 01:30 AM   #70
Crestwood1001
Drives: 2013 BRZ Limited (GBS)
One of the best threads on here, sounds like this kit is top notch
Crestwood1001 is offline   Reply With Quote
MCA Blue coilovers - Now with first impressions and install pics!!!!!!!! Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 52 05-23-2016 08:18 PM
Cosworth Stage 2 Supercharger Install (Dyno,Tech,Photos,Videos) RallySport Direct Forced Induction 49 08-20-2015 07:32 AM
Cosworth Stage 1.1-1.3 Power Package BRZ 2013-2014 / FR-S 2013-2014 With Videos! RallySport Direct Engine, Exhaust, Bolt-Ons 104 07-02-2015 10:10 AM
Stage 1.1 Cosworth FRS FR-S89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 12-22-2014 01:23 PM
Cosworth Stage 2 v86 Software Tuning 2 11-05-2014 07:47 PM
