Old 04-19-2015, 01:10 PM   #29
fasteddy
I would take Brembo at their word about this seeing as they designed the WRX STI calipers.
Pat
fasteddy is offline   Reply With Quote
Old 04-19-2015, 09:35 PM   #30
wparsons
wparsons's Avatar
Originally Posted by mikeTee View Post
The second statement from the article about the piston size being incorrect for the FRS/BRZ is bullsh*t because the BRZ tS in Japan comes with the exact same Brembo set up as the WRX STI - 4 piston front, 2 piston rear - though I can't know for sure what the size of the pistons themselves are, IMO the possible difference could only be marginal.
That article is talking about just swapping fronts. if you swap matching rears the bias won't be affected. Incorrect piston sizes will change how the pedal feels and how much travel you need though.
flickr
mikeTee (04-19-2015)
Old 04-19-2015, 10:36 PM   #31
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Actually IIRC if you swap the rears to Brembo as well, the front bias will be even greater compared to just using our stock rears. This is apparently due to the rear brembo piston being smaller than that stockers . But the rear brembo's will gain more "torque" (i think that's the right term?) due to the larger rotors. It all gets very technical and mathematical when you compare on paper.
But what I do know for sure is that my front + rear brembo setup behaves no differently to other WRX STI's that i've driven before. Even a couple of buddies who own STI's commented that my brakes feel very "OEM-like".
Fizz is offline   Reply With Quote
Old 04-20-2015, 01:01 AM   #32
CSG Mike
CSG Mike's Avatar
Originally Posted by mrk1 View Post
Very good read. Calipers are not just calipers.
https://racetechnologies.wordpress.c...or-subaru-brz/
I've been saying that for years... glad Race Tech finally wrote something about it.
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
DylanJZA (01-31-2023), Sportsguy83 (04-20-2015), srizzors25 (04-27-2015), Takumi788 (04-20-2015), wparsons (04-20-2015)
Old 04-20-2015, 01:02 AM   #33
CSG Mike
CSG Mike's Avatar
Originally Posted by Tbird232ci View Post
He is correct.
The bleeders not being inverted means the air gets trapped in the top of the caliper. Air naturally travels upwards and without the bleeders, it will just stay in the caliper. That will not create uneven pad wear, but it will create a soft and spongy pedal.
The incorrect piston staggering leading to pad wear is all theory. If nothing else, it will only be noticeable towards the end of the life of the pads, If you care enough, you could probably swap the inside pads for the outside pads to even out the wear. Brembos are incredibly easy to swap pads so it really isn't as inconvenient as it sounds.
It's not theory. Street driving only? Sure you'll probably never see uneven wear. Tracking the car with any sort of experience? You absolutely will see uneven wear.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
civicdrivr (04-20-2015), DylanJZA (01-31-2023), Sportsguy83 (04-20-2015)
Old 04-20-2015, 01:06 AM   #34
CSG Mike
CSG Mike's Avatar
Originally Posted by Poodles View Post
It's kinda comical that they consider more front bias dangerous when the inverse is the truth...
It's about the same as saying that understeer is safer than oversteer. Both have their inherent pros and cons.
DylanJZA (01-31-2023), Sportsguy83 (04-20-2015), wparsons (04-20-2015)
Old 04-20-2015, 01:07 AM   #35
CSG Mike
CSG Mike's Avatar
The first statement does address the possibility of an issue if the staggered STI Brembos which in the past have used 46mm and 40mm pistons on the front caliper but again I think the size of the pistons and their positions is marginal - and I do believe that Subaru is reusing the same brembos for their WRX STI as the BRZ tS, I refuse to believe that they had a car specific brembo made for the tS but again I could be wrong about this.
Lastly, is there any validity to the statement about not being able to fully bleed out the caliper? I keep on thinking about how brakes are bled out and I don't really see how the air can't all be forced out.
It is indeed car specific, per the Brembo engineers I spoke with. Brembo is very capable of making small runs of calipers sized specific to an application. They're very similar *looking*.
civicdrivr (04-20-2015), DylanJZA (01-31-2023), mikeTee (04-20-2015)
Old 04-20-2015, 01:09 AM   #36
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
It is indeed car specific. Brembo is very capable of making small runs of calipers sized specific to an application.
Thank you for the clarification. If only we knew the piston sizes!!!
mikeTee is offline   Reply With Quote
The Following User Says Thank You to mikeTee For This Useful Post:
CSG Mike (04-20-2015)
Old 04-20-2015, 01:12 AM   #37
CSG Mike
CSG Mike's Avatar
Pat
For the record, Race Technologies is to Brembo, as Essex/Stillen are to AP Racing.
Now, Brembo and AP are owned by the same entity (Brembo), but are still competing brands. Technically, AP Racing is a direct competitor to Brembo Racing, which is a separate brand from Brembo.
DylanJZA (01-31-2023), midnight23 (04-20-2015)
Old 04-20-2015, 02:00 AM   #38
WesleyG
Drives: 2014 Satin White Pearl GTS auto
While I do not have the technical know how to prove or disprove the technical reasoning in the article, I cannot help but notice the advertisement in the bottom and the 3k price tag for the upgrade from them.
Hey guys dont use the second hand calipers that fit on your car, because you will die, but instead buy this kit from us.........
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
The Following User Says Thank You to WesleyG For This Useful Post:
protpibe (04-20-2015)
Old 04-20-2015, 10:27 AM   #39
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I love this thread. That wordpress "article" is filled with opinions and no facts. They list 30% but don't mention if that is with just swapping the fronts or swapping fronts and rears and with what pad compound front and rear. ABS problems, haha. All ABS cares about is what that wheel speed sensor is telling the ABS computer. You can lock up your brakes and get into ABS with or without the STI calipers. You won't kill yourself if you do the STI swap, and there are plenty of ways to get the air bubbles out with the pistons in proper orientation and the bleeders swapped. Air bubbles can get trapped anywhere in the calipers not just the crossover bar. That is why you are supposed to hit them with a rubber mallet to dislodge the air bubbles to the bleeder location. Brake bias is something that can be adjusted with pad choices or a brake bias adjuster in more track oriented applications.
Old 04-20-2015, 01:28 PM   #40
CSG Mike
CSG Mike's Avatar
While many of those fixes are hacks that do work at a basic level, as you progress as a driver, you'll hit the limitations of the system much faster.
For example, the front bias can be somewhat mitigated with a more aggressive rear compound, but then now the rear is working harder. As the rear heats up faster, the Mu also rises faster (typical with most pads), causing, now, a rear brake bias. As the rear continues to work harder, it heats faster than the front, and then overheats much earlier than it should. Now you only have front brakes.
How would this constantly changing brake bias benefit a newer driver, who is trying to learn to safely drive on track, when the brakes are changing on him in real time?
Old 04-20-2015, 01:41 PM   #41
Racecomp Engineering
I would be pretty surprised if the tS BRZ used the same brembos as the STI. The brake bias with the full front and rear kit is pretty awful (as noted by those who have actually tracked the full set-up).
I'm someone who can do math, so in this case it's something that checks out on paper and in the real world. Yes, it's mostly fine on the street and you can shift brake bias in other ways, but I'd much rather just run a proper kit (which in some cases is not a ton of money).
FWIW, the Brembo front and FHI 2006 WRX 2 pot rear combo is better.
- Andrew
CSG Mike (04-20-2015), DylanJZA (01-31-2023)
Old 04-20-2015, 01:56 PM   #42
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
- Andrew
better? as in its not recommend, but if you are hell bent on doing a sti brembo swap, its better to do brembo front/wrx rear? Or better to just avoid it all together since they are both "bad" for bias.
I only ask because I was heavily contemplating doing this. My buddy has a full set of the 06 4 pot/2pot calipers for me, but because of the rear brake bias issue of doing the full 4/2 pot swap I haven't done anything with them yet, and I was thinking of doing the sti brembo front, and the 2 pot wrx on the rear.
The Truth Will Set You Free~ Kiske Off-Topic Lounge [WARNING: NO POLITICS] 8 01-06-2015 07:53 AM
Moment of truth. Humor is welcome! gt8613 Off-Topic Lounge [WARNING: NO POLITICS] 12 11-11-2014 02:08 PM
any truth to this? fluffy-reindeer-slayer Scion FR-S / Toyota 86 GT86 General Forum 17 06-11-2014 08:00 PM
An inconvenient Truth Maxim Scion FR-S / Toyota 86 GT86 General Forum 49 06-17-2011 10:35 PM
