Old 01-19-2015, 03:20 PM   #57
kilohercas
Drives: Subaru BRZ (soon?)
Originally Posted by Black Tire View Post
Ok, it looks like Blue Subaru super coolant maybe will be better overall, so i will stick with that.
Somehow i did not take into account that engine is ~60% heat, i did not expect that cooling will not be as efficient, and head temperature will rise quite a bit. With that in mind, In electronics is so easy to take 1kj/s of heat with oil or water, but engine has significantly higher heat output...
kilohercas is offline   Reply With Quote
Old 01-19-2015, 04:42 PM   #58
Tenament05
Drives: fast
Water is king when it comes to commercial/automotive cooling, full stop. The only reason why we do not run 100% water in cooling applications is because of water's lofty freezing point
Tenament05 is offline   Reply With Quote
Old 02-21-2015, 12:33 PM   #59
BRZBlack
BRZBlack's Avatar
Drives: 2013 Subaru BRZ
Didn't see it anywhere in this thread but the Subaru part # for coolant is SAO868V9270.
BRZBlack is offline   Reply With Quote
Old 03-07-2015, 12:18 AM   #60
congee
congee's Avatar
Drives: SSM BRZ
Anyone know if I can just add coolant without draining it?? I just checked my coolant, and its non-existent but my engine temperature is normal and heater is working fine. Do I leave the car running with the heater on while adding coolant or just the heater on is fine?? My first car so don't really know what the procedure is. Have about 28,000km on my brz.
congee is offline   Reply With Quote
Old 03-07-2015, 12:28 AM   #61
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Top it off with blue subaru coolant or toyota frs blue coolant. The subaru version is cheaper because other subarus use the same coolant. The Toyota one is more expensive.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
congee (03-07-2015)
Old 03-07-2015, 12:38 AM   #62
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
If your car hasn't overheated, the coolant level in the radiator is probably okay. The coolant tank that you check is the reservoir, so it's not a disaster if it's empty. You won't need to drain it, just be sure to top it off with the Subaru Super Coolant (blue, not green)--mixing coolant types (ie different colors) will reduce the lifetime of the coolant.
Lelantas is offline   Reply With Quote
The Following User Says Thank You to Lelantas For This Useful Post:
congee (03-07-2015)
Old 03-07-2015, 12:44 AM   #63
congee
congee's Avatar
Drives: SSM BRZ
I've read that I need to mix 50/50 with distilled water. True??
Old 03-07-2015, 01:26 AM   #64
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
No. The Subaru Super Coolant (blue color) is pre-mixed with water, definitely don't dilute it with water.
Old 03-07-2015, 01:29 AM   #65
N1rve
N1rve's Avatar
False.
The bottle itself says do not add water.
[IMG]https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-xap1/v/t1.0-9/10157316_10203401547220606_694036708_n.jpg?oh=04b4 34685b994f***972e7c217d4deb6&oe=5572CDFF&__gda__=1 434429477_cdd55bb1ac7c0fb060dd88667367512f[/IMG]
N1rve
congee (03-07-2015)
Old 03-12-2015, 03:21 PM   #66
leoh007
leoh007's Avatar
Drives: 2014 Monogram
I just purchased the Blue coolant at the Subie Dealer. it came out to be the same price from Subaru PArts Online, $24.14. My car had literally NO coolant whatsoever so when I cold started the car it sounded like it wanted to get some coolant but couldnt get any because there wasnt any. Problem is now gone because of the topped off coolant though
leoh007 is offline   Reply With Quote
Old 04-20-2015, 12:23 AM   #67
1NVAZN
Drives: 14 FRS Base currently FS, DM 4 info
Does anyone know where i can get the Blue Super Long Life Coolant besides the toyota dealer? ie canadian tire etc
1NVAZN is offline   Reply With Quote
The Following User Says Thank You to 1NVAZN For This Useful Post:
Chad86 (10-03-2015)
Old 04-20-2015, 12:38 AM   #68
bass_114
bass_114's Avatar
Drives: wrb brz
I beleive its actually exclusive to subaru so best bet is to visit the local dealership
bass_114 is offline   Reply With Quote
The Following User Says Thank You to bass_114 For This Useful Post:
Chad86 (10-03-2015)
Old 04-20-2015, 01:09 AM   #69
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I had to top mine off before a long road trip through the desert - i saw my temperature gauge drop a whole notch comparing southern california to vegas deserts - kind of a big deal to me
Old 08-17-2015, 05:42 AM   #70
Jackal84
Jackal84's Avatar
Drives: Toyota GT86
Hello to all!
Just a quick question about the coolant.
Here in Italy seem is impossible to find the Toyota/Subaru Blu stuff 50/50 so i searched other products.
Motul advice is this:
https://www.motul.com/it/en/products...inugel-optimal
The specs are the same mentioned in the owner manual of the car..
Go for it?
Thanks!
Jackal84 is offline   Reply With Quote
GALAXY BLUE SILICA BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 595 12-08-2022 05:55 AM
Galaxy Blue VINs? dorkymork BRZ First-Gen (2012+) — General Topics 49 06-02-2012 09:55 PM
Black, blue, or gray.. i may have a choice here Mykflo BRZ First-Gen (2012+) — General Topics 27 05-26-2012 11:26 AM
I want this edition... (blue modified 86 TRD) xantonin Scion FR-S / Toyota 86 GT86 General Forum 119 02-15-2012 01:02 AM
More pix of blue 86 w/aero+ rims Alfie FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 11-29-2011 08:17 PM
