Old 04-19-2015, 10:37 AM   #15
Atticus808
Atticus808's Avatar
Drives: Splash Mountain
He's yanking your chain.
OP, the thing to remember about clutch conservation is to focus on spending the least amount of time possible with the clutch in slip, especially don't gas it while the clutch is slipping. Hard to explain in words. It's a rhythm thing easier understood when seen demonstrated. Like @Tcoat said, classes are reasonable and very much worth the cost.
In the end remember it's just a clutch.
I thought so but then I ended up second guessing lol
Atticus808 is offline   Reply With Quote
Old 04-19-2015, 12:55 PM   #16
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
What hasnt been covered yet....oh yeah if you have an aftermarket exhaust, remember to wake up early every morning. Drive to the main road of wherever you live, clutch kick it, opposite lock. This will definitely help with throttle control. Trust me its what the pros do
/sarcasm.
Old 04-19-2015, 01:00 PM   #17
SR5
SR5's Avatar
Drives: Raven
Post
Originally Posted by Teseo View Post
I tried not gas when clutch still slipping and the car jerks like crazy
then in that situation, give it a little more gas to slip out of the jerk.
It's a balanced act, the amount of slip you give is the amount of gas you give on the start.
As a driver coming from auto, you should get a feeling of giving it more clutch (leaving your foot in the clutch more) even after shifting it into gear. This will smooth things out with much less jerk.
Honda clutch has less room for error, the clutch on this car has lots of room! But yes, it can still jerk if your timing is off or if its cold & not warmed up.
Don't worry about clutch Conservation yet, until you've learned. Clutch is a wear item just like brakes, it just last longer. You'll eventually have to replace it if you keep the car.
Like I said, focus on giving it more clutch since you're use to auto, and the amount of gas you give should be natural.
something smelly, and you still have crickets..
SR5 is offline   Reply With Quote
Old 04-19-2015, 01:41 PM   #18
Oops. Yeah, I didn't express that very well. What I meant to say was try not to rev the engine too much when it's slipping.
Ok to rev the engine when the clutch is just starting to make contact but then less torque/gas as the clutch goes towards full engagement.
Typically from a stop, I goose the throttle and begin engaging the clutch while the engine is spooling down. Then I give it gas only after the clutch is fully engaged. It's not cut and dry and takes practice.
Just don't rev the shit out of it while the clutch is only half engaged. Consider that old trick of rubbing your palms together to warm them. Now multiply that by 50,000.
Old 04-19-2015, 01:57 PM   #19
serialk11r
Drives: '06 AM V8V Coupe
You can definitely gas it while slipping the clutch (in fact you should), just don't rev the engine too high.
Just go by "feel". If you drive like most automatic drivers you will soon get annoyed at all the starting and stopping, and will adapt your driving accordingly. I try to not brake and just roll in 1st or neutral until I'm forced to a stop. If traffic isn't completely frozen, I accelerate in 1st (or 2nd) and either coast with clutch in or roll along in 2nd or 3rd or something.
Old 04-19-2015, 03:20 PM   #20
humdizzle
Drives: 2018 GT3 / 2015 M3
Here is a good video for first timers::
[ame="https://www.youtube.com/watch?v=m0O0Ta8tzXs"]J's s2000 vs Amuse s2300 Touge , Best Motoring - YouTube[/ame]
2018 GT3 6MT
2021 M2 Comp DCT
Past: 458 Italia, R35 GTR, E36/E46/F80 M3, 335i, Scion FRS
humdizzle is offline   Reply With Quote
Old 04-19-2015, 09:42 PM   #21
PMPB
Drives: BRZ Sport-tech
MT drivers that spend a lot of time in stop and go will often try to stay in second gear as often as possible and just let the car pull itself along at idle. With our cars, this works out to about 13km/h. It gets frustrating though as when the gap gets to big, it fill up with lane changers, and you have to come to a stop anyways.
PMPB is offline   Reply With Quote
Old 04-19-2015, 10:34 PM   #22
soapbox
With respect to the gap, remember, drivers are required to maintain enough distance to allow another vehicle to merge unobstructed. People don't do it but it's the flip side to the law saying the merging driver must yield to already flowing traffic.
/soapbox
Old 04-19-2015, 10:40 PM   #23
Tgionet
SPACESHIP
Tgionet's Avatar
Drives: BRZ Ltd 6MT WRB
how else would you move up if you just want to move like 2 meters?
Leave it in neutral, open the door, and push it forward with your left foot.
Tgionet is offline   Reply With Quote
Old 04-19-2015, 10:52 PM   #24
SR5
SR5's Avatar
Drives: Raven
this is done in the garage a lot!
2 meters? Don't even lift off the clutch completely. It should still be slipping. Most transmissions are not fully engaged to move that distance from the start.
Old 04-19-2015, 11:07 PM   #25
HachiRo
Drives: 2013 White-Out FRS
If it makes you feel any better, this is my first ManTran car also and I learned it AFTER I bougt the car LOL
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 04-19-2015, 11:11 PM   #26
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
let's say you're at a stop and traffic is beginning to move.
1.) clutch in
2.) shift from neutral to first
3.) let clutch out to engagement point and give gas as needed. At this point the clutch won't be fully out if im only moving a bit.
then lets say traffic stops again
4.) clutch in and brake
5.) go from first to neutral again OR leave in first and leave clutch in (depending on how long you think traffic will be stopped for)
someone correct me if I gave some bad advice lol
This. It's a feeling thing. You'll get it pretty quickly I'm sure
To add to the above comment, I think of the clutch and gas as a constant and equal ratio. As one goes in the other comes out. It'll take some feeling to get the balance but once you get it you'll know what I mean.
Also, you're a lot like me lol. You're building it up a lot in your mind. Take all the info here into consideration but the best way to figure it out is getting in a MT and learning man.
Good luck.
KevinK121 is offline   Reply With Quote
Old 04-19-2015, 11:12 PM   #27
Haha... I do that all the time because go-kart.
Old 04-19-2015, 11:37 PM   #28
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
soapbox
/soapbox
Maybe in Canada, I've never heard of a US state that has that requirement
V_86 is offline   Reply With Quote
tight
Is the frs/brz your first manual transmission car? swarb Off-Topic Lounge [WARNING: NO POLITICS] 36 03-04-2015 08:22 PM
Has anyone had a Manual transmission apart? SilverSRTSedan Engine, Exhaust, Transmission 9 03-23-2014 08:05 PM
Manual transmission 2nd into 1st MrMista Engine, Exhaust, Transmission 9 10-13-2013 10:48 AM
Second Impression with a Manual Transmission Bristecom Scion FR-S / Toyota 86 GT86 General Forum 22 08-30-2012 08:21 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
