#2129 |
Drives: 2013 fr-s, sr20 180sx
As awesome as the CSG spec SRC's are. They may be overkill for me as I'm not tracking my car at the moment and don't have the knowledge or skill yet to need them. Although.... I tend to go balls out when it comes to my mods.
we'll see where things end up after I've replenished funds.
#2130 |
Track Junkie
Drives: Argento Scion FR-S
I figured I'd share my remotedyno session with @moto-mike last weekend.
I had a track event the same weekend and I love how this supercharger pulls, now its just to fix a few issues that came up.. namely my clutch. lol Also had a dyno day with the Houston 86 Club at DDPR. Numbers didn't change much! |
| The Following 3 Users Say Thank You to The Slow One For This Useful Post: |
#2131 |
#2132 | |
#2133 |
#2134 |
Drives: 2015 Release Series 1.0 FRS
I think you're the same Mike that my friend Kevin spoke of. He's got a black 370z. He spoke of you tonight cause he's going to help me with my JR install. You said something about the bumper >_<
075/1500 2015 Scion FRS Release Series 1.0 / Jackson Racing Supercharger + Oil Cooler / Tom's Red DOT LED lights / 18s staggered Enkei Raijin with RS3 / TRD Short Shifter / 328 Stoptech BBK Front / Velox Motorsports Diffuser / Whiteline bushings / Ohlins RT Coilovers / VIS Carbon Fiber Hood.
#2135 | |
Jackson Racing Supercharger Owners Thread
I believe I've found a solution for our inaccurate outside temp reading post JRSC install. Mine was reading easily 20+ degrees F after 10-15 minutes of driving when located behind the radiator, oil cooler and intercooler. First, I ended up relocating my outside temp sensor to the passenger side vertical air guide that I had initially removed for the JRSC install. I simply dremeled the air guide to fit around the new intercooler piping and drilled two holes into the guide so that I could zip tie the temp sensor against the guide. The sensor now sits away from the radiator and oil cooler. When viewing from the front, it sits just below and slightly behind the intercooler exit piping. The temp wiring harness is just long enough to accommodate this. This setup gave me temp readings that were consistently 5 degrees (F) higher than the geolocated temp reading from my iPhone's weather app after 10 minutes of driving. Typically the outside temp reading stabilized after 10 minutes of driving: car was at normal operating temp and enough air had been blowing across the sensor. Attachment 107435 Attachment 107436 Attachment 107437 The final step was using the Techstream Software and calibrating the ambient temp sensor to -3 degrees C (5.4 degrees F). This gave me outside temp readings that were within 1-3 degrees F of my weather app! Ambient temps in Las Vegas have been hovering between 45-85 degrees and the temp sensor has been pretty accurate within that range. The real test is when we start hitting triple digits in the summer months. I realize this has no effect on the performance of this kit but just more of a fix if anyone was annoyed with the hugely inaccurate outside temp reading post install. YMMV. Hope this helps! Attachment 114404Attachment 114405 Last edited by dj2020; 07-06-2015 at 06:23 PM. |
#2136 |
Thanks Mike. Sorry to say I didn't order from u, as much as I wanted to go thru CSG I couldn't pass up the deal I got. But I'm holding CSG responsible for all my suspension, braking, and consumable needs.
I'll be getting my exhaust system n flex fuel kit from u as well if I give in to the power hunger...
#2137 |
#2138 |
Drives: 2015 Series.Blue BRZ
Either way... Can't afford it. I'll be either getting the RCE yellow springs, or RCE Tarmac IIs. Depends on if I have to buy a new supercharger or not.
#2139 |
Any of you guys running a catch can on the PCV side of things? Specifically I'm looking at the Mishimoto PCV can. Is it catching any oil? Street or track driven? I'm also wondering if it's necessary to have the additional CCV can for our boosted application. For a NA FRS/BRZ application, Mishimoto showed that it was not necessary to have a CCV can. I'm hoping someone can chime in with real world experience detailing if the CCV can is needed when boosted.
#2140 |
Drives: Subaru BRZ
I had an interesting situation while i was a good 130 miles away from home. I was out in the desert, joshua tree, (3000ft elev) and my car threw a CEL p0172 as I was just normal driving along about 10 minutes after I been ringing the engine out a decent bit. I did notice the engine was pulling timing, I figured this could've been due to heat and elevation. anyways. to top that off, i had been camping for almost two days and accidently hit a stupid low rock reversing out of a parking spot and it pushed my exhaust back 2"... which i was able to just pull back and after visual inspection the exhaust did not look damaged, as good as i could see from under the car using the emergency jack. this threw off my initial diagnosis. I thought it might've caused a leak causing the o2 sensor to read incorrectly.
anyways. cleared the code for giggles, and yup, it came back. right after i cleared it, the car would not idle. it would die. i gave it gas and i guess fuel trims adjusted and it was able to idle... but LTFT was basically pegged at -25%.... yikes. STFT would spike up to 11%. so needless to say I kept it out of boost for the rest of the day I was there, and for my 2 hour drive back home. got home... napped... because i had 6 hours of sleep over the past two days. and did some reading. I figured i'd try the easy thing first, and clean the maf sensor. 8 bucks later, and some electrical contact cleaner, sprayed the crap out of the whole maf sensor, let it dry, plugged it back in (CEL was still on, and had not been cleared. fired it up, my STFT reached a mighty 33% on cold start cat warmup and then it threw an additional code of p117b. scary... i decided to just clear the codes and start fresh. did that. and now the car seems to be fine fuel trims look fine. +/- 10% stft and +/- %% LTFT i'm sure they'll settled down even more after i get more than 20 miles on too. idled fine from the get go after the clearing the codes (which resets LTFTs)I'm trying to get ideas on what exactly happened. and also want to know why my air filter is in such bad shape. after this I inspected my air filter. and its not just dirty, but physically damaged. two spots of the grating to it is frayed and at those same two spots (about 1/2" long by 1/16" wide, just a sliver that were facing down towards the fans so i couldn't see it) are super dirty. I'm going to order a new air filter. but I only have 6k miles on the kit? i know its dusty in the desert and all... but still... i'll do a UOA on this batch of oil and see my silicon content. anyways super tired from my camping trip, post might be rambling dunno. any thoughts? tl:dr. Maf sensor dirty(did not look dirty to my naked eye, cleaned anyway), threw code p0172, only 6k miles on air filter, filter looks slightly damaged in two spots, not from my own handling abuse. cleaned maf and all appears good. wut?
2014 WRB BRZ
#2141 | |
Drives: Subaru BRZ
2014 WRB BRZ
#2142 | |
You think you'll more likely catch oil on the CCV side of things vs the PCV? |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
