Old 04-17-2015, 10:27 AM   #1
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
How to size wastegate
How do you size your wastegate setup? I'm running a Turbosmart comp gate 40 paired with a GTX3076R and seeing consistent boost creep under WOT.
I am only running spring pressure of 7psi, but by the end of a WOT run, I have creeped to 10psi.
Also I have worked this out in my head, but an EBC wouldn't help with this either right, because once the EBC opens up, we're going to be essentially wide open WG?
Thanks
crazyfrenchbiker is offline   Reply With Quote
Old 04-17-2015, 12:53 PM   #2
Basket Case
Drives: 2013 Raven fr-s
I'm pretty sure an EBC should prevent boost creep but I could be completely wrong...
Basket Case is offline   Reply With Quote
Old 04-17-2015, 01:21 PM   #3
aagun
Drives: 86
Use ur bov to leak extra boost .
aagun is offline   Reply With Quote
Old 04-17-2015, 01:53 PM   #4
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Try a smaller spring in the gate.
Jesse@JDLAutodesign is offline   Reply With Quote
Old 04-17-2015, 02:08 PM   #5
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
7psi is way low on a gtx3076. Probably going to be hard to get it to not creep at least a little with such low boost. A manual boost controller without a gate ball/spring might work too if you plan on even running a controller. Let's the wastegate start to crack open just before full pressure
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 04-17-2015, 02:58 PM   #6
crazyfrenchbiker
Hot Lava 6MT
I do plan on going to higher boost, so it may be wiser to just install the EBC and run at say 9-10PSI to start?
I would think this should help the WG.
Old 04-17-2015, 02:59 PM   #7
crazyfrenchbiker
Hot Lava 6MT
Like a 5PSI spring and letting it creep to 7 or 8psi?
I would think that the lower the pressure, the more intense the creeping will be.
Old 04-17-2015, 05:43 PM   #8
mrk1
Drives: Sterling BRZ Ltd
The idea of a softer spring is to get the gate to open farther so more gas can by pass the turbine. Softer spring could compress more allowing more flow through.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-17-2015, 06:06 PM   #9
crazyfrenchbiker
Hot Lava 6MT
That makes sense. Thank you sir.
The Following User Says Thank You to crazyfrenchbiker For This Useful Post:
mrk1 (04-17-2015)
Fs:SoCal tial f41 wastegate enjetek Engine, Exhaust, Bolt-Ons 2 11-20-2014 12:30 PM
WTB: 44-46mm Wastegate, BRZ Limited Pass Seat, BRZ Dash Panels OmarGC Want-To-Buy Requests 3 09-19-2014 01:31 AM
FS: BNIB Precision 39mm Wastegate PW39 pleong Engine, Exhaust, Bolt-Ons 1 05-20-2014 04:33 PM
Garrett GTX2863R turbo, TiAL v-band wastegate Turbowned Engine, Exhaust, Bolt-Ons 10 11-27-2013 03:07 PM
Sti Genome gauges, Perrin Pulley, wastegate precision 46mm, BOV turbosmart raceport dompower Engine, Exhaust, Bolt-Ons 1 03-28-2013 11:22 AM
