Old 04-16-2015, 05:30 PM   #15
ls1ac
ls1ac's Avatar
Do as suggested and while it is happening put the car in N or depress the clutch, if it decreases or goes away it is engine related, if it stays it is drivetrain or body.
Revving the engine standing still produces very little sustainable manifold vacuum. You may still be able to find a leak using brake cleaner and listening for a RPM change while at idle.
Old 04-16-2015, 07:47 PM   #16
retrosmiths
Drives: Scion FR-S Whiteout
Originally Posted by White64Goat View Post
That would tend to eliminate the throw-out bearing (if it's a manual trans.) Since you only hear it while moving my next thought would be a dust shield rubbing on a brake rotor.
What Shutter said ...........
Originally Posted by Shutter View Post
get up to speed and throw the car in neutral? Just to make sure its not a wind noise from airflow
determines if its from the engine, or car
Ok, this is weird. Now I hear it while revving even when the car is parked. It's also near the passenger footwell, which leads me to believe it has something to do with that noise generator pipe, or something beneath the chassis (i.e. exhaust pipe).
The engine also needs to be running for quite a few minutes (10+) before it starts happening, like a certain temperature. Could it possibly be a small leak in the exhaust pipe, which only opens up when the temperature is high enough and the metal expands/contracts?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 04-16-2015, 08:13 PM   #17
Yep!
Old 04-16-2015, 08:39 PM   #18
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
First thing that popped into my head was trans related. But it doesnt whistle.
My money is on a ever so slightly warped gasket near the sound tube.
Old 04-16-2015, 09:13 PM   #19
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
SO weird. I've been having this problem at highway speeds. Exactly as you described. At first I thought it was a ground loop issue with the stereo, but I shut it off and it still remained. My car is also 100% stock.
Jesse36m3 is offline   Reply With Quote
Old 04-16-2015, 10:36 PM   #20
retrosmiths
Was planning on getting an inlet tube, hoping that will fix this.
2013 Scion FR-S
Old 04-16-2015, 10:58 PM   #21
TheyCallMeBaker
Drives: 2013 Scion FR-S Asphalt
With your "symptoms"
"Usually happens when the engine is warm
Gets a bit louder/higher-pitched on higher RPMs
(NOT!) Cannot reproduce if the car is parked and I rev
Sounds something like a tea kettle noise
Stock exhaust pipes, stock intake system except for K&N drop-in filter
I triple-checked the filter to make sure it sits properly and that the box closes fully
I also plugged the pipe that leads from the intake to the cabin, and it didn't help
No matching symptoms with an intake/exhaust leak
First thing I'd do is get your hands on a back pressure gauge that you can put in your O2 sensor before the cat. Do it cold then let it idle and get to operating temp. Check where gauge is, roughly 4-6 psi is acceptable. If it's higher or pegging the needle and fluctuating I would replace your catalytic converter. Too much back pressure can leak out of gaskets causing your symptoms. Just personal experiences. I work in a shop not saying I'm 100% sure but I've seen it often on other vehicles. Havnt seen a case on a frs or brz but it could happen. And in my frs I've put 22k on it back roads and a few canyon runs but never had 23-26 mpg I'm sitting around 29-31 with k&n also so it could be I drive like a grandma but I'm leaning personally towards a cat.
TheyCallMeBaker is offline   Reply With Quote
Old 04-17-2015, 01:58 AM   #22
pdhami
Drives: 2014 Argento FR-S
I literally just had the same problem as you on my drive to school and then on my drive home the sound is gone, I hope it doesn't come back it scared the shit outtve me when it happened haha
pdhami is offline   Reply With Quote
Old 04-20-2015, 11:45 PM   #23
orangeblue
Drives: Whiteout
I've got the same thing, it happens at freeway speeds while feathering the gas. No throttle and the noise goes away. I drive 60 miles a day (at least) on the highway, so it's annoying.
orangeblue is offline   Reply With Quote
Old 04-21-2015, 05:21 PM   #24
retrosmiths
It sounds like a whistle, at the same time it goes up in pitch the higher the rev is.
2013 Scion FR-S
Old 04-25-2015, 09:10 PM   #25
White64Goat
Well, has anyone found the source yet?
Old 04-27-2015, 12:54 AM   #26
unlimited86
Drives: s2000
I just notice mines today, Only happens when I am in 6th gear and at least 3k rpm, it gets louder when i get it up to 3.5k and the sound will go away if i let off throttle and will come right back when Im on it. Does not happen in other gears and I would say its more of a whining sound, its going to be irritating going on long road trips.
unlimited86 is offline   Reply With Quote
Old 04-27-2015, 12:56 AM   #27
Wyattkb
Drives: 2014 Whiteout FRS
I have this same thing, very noticeable at 75+ MPH. It sounds to me like some sort of gear whine.
Wyattkb is offline   Reply With Quote
Old 04-27-2015, 01:12 AM   #28
unlimited86
Drives: s2000
Yup, exactly. Don't have any aftermarket parts that would increase NVH.
Faint Honking sound Raven604 Issues | Warranty | Recalls / TSB 117 07-14-2023 05:04 AM
Whistling sound..? tintumz22 Issues | Warranty | Recalls / TSB 34 11-21-2015 08:54 PM
not very loud, but high pitched sound at 70+mph fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 16 10-16-2013 10:30 PM
High pitched whine from sound tube and idle jumping Nourdmrolnmt1 Issues | Warranty | Recalls / TSB 0 04-17-2013 11:00 PM
TSB - FRS (re: High pitched chirping...) PNW FRS Issues | Warranty | Recalls / TSB 1 01-19-2013 01:05 AM
