Fried BCM ? fuse ? something ?
had a few drinks after work and attempted the sidemarker as signal mod today..
ill leave out most of the boring details besides the fact that i forgot to disconnect the battery before doing anything. and tapped into my signal wire and then connected it to my sidemarker, only did the driver side and went to test it when i realized everything was wrong. no sparks or anything during the process, but i must have shorted something out. when key is turned to the on position the parking lights are all on (on the signal stalk it is in off position), on the dash it seems the car thinks my highbeams are on, yet i have no lowbeam or highbeam function at all, theres a solid beep that sounds, and the only way that any of this goes away is to disconnect the battery (figures as it probably wouldve prevented this at all. ) i did do a search prior to this thread, so im 90% sure that its the bcm or whatever its called, checked a variety of fuses, and changed the one for tail lights/sidemarkers but no change, im sure this stupid mistake is going to cost me huge, but before it does, if there is anything else that anyone can think of that could be the problem, please share below.. |
#2 | |
Drives: Whiteout FRS
Did you undo what you did? Are you sure the headlight control stalk isn't pushed forward in the high beam position? Did you check the "TAIL" fuse?
#3 |
Undid what I did, the stalk is not in highbeam position, and yeah I replaced the tail fuse with a new one
#4 |
#5 |
A Demon
Drives: Raven GT86
Are you just checking the fuse box under the hood or under the dash as well?
I'd double check your ground connection as well. Sent from my iPhone using Tapatalk |
#6 |
The fuse was not blown, I replaced it anyways, then replaced all the ones listed in the manual that are related to the main body ecu even though none were blown, as for the ground connection the battery terminals were tight as shit, not sure where there are any other grounds to the chassis or anything, still no change through unfortunately..
#7 | |
Other than all the weirdness with the lights, and the beep tone, is anything else messed up? Does your car start? Does the A/C work?
#8 |
Yeah the car starts perfectly, I tested everything else and it works; all climate controls, radio, Windows, door locks, interior lights, wipers
No limp mode or anything, can rev the car up perfectly, it's like it's just the lights control that's fucked. Earliest appointment available at my dealer is next week Thursday so Im gonna see what they say is wrong. I'm thinking bcm and I already found a replacement if it's not covered under warranty, and went over the replacement procedure in the tech service manual, so if thats what it is I'll just replace it myself (assuming of course that the dealer will charge large for it) |
| The Following User Says Thank You to eddieflyinv For This Useful Post: | Tcoat (04-17-2015) |
#9 | |
A Demon
Drives: Raven GT86
Please keep this post updated in case anyone has this issue in the future Sent from my iPhone using Tapatalk |
| The Following 2 Users Say Thank You to ZOMFGAARON For This Useful Post: | Abenaki (04-17-2015), eddieflyinv (04-17-2015) |
#10 |
Will do, never know it might be useful to someone. And the only thread I found with exact same issues wasn't very detailed in the what was wrong department... I love details lol
#11 | |
Would be interesting to know what happened. In looking at the circuit diagram http://www.ft86club.com/files/BRZwiringi.pdf, there really aren't many places that it directly interacts with the main body ECU. I assume you tapped the r-w from the turn signal (this is from the BRZ wiring diagram where the turn signal is in the headlamp assembly, but it should wire similarly) then clipped the red wire going into the side marker and attached the two together? If you had a static charge at the side marker, the only place it could have hit the main body ECU would have been going through that TAIL fuse, which either wasn't enough to protect the surge and allowed it to fry the ECM at that TRLY point, or it's not the problem. Once clipped and connected to the wire you tapped, the sidemarker would not have been the problem. So, assuming some sort of static discharge on the turn signal side, it would either hit the turn signal flasher assembly or the combination meter assembly. The turn signal flasher assembly has two fuses associated with it, 15A HAZ near the battery and 7.5A gauge in the interior fuse panel. You might check those two if you haven't already. The combination meter assembly also has two fuses associated with it, the same 7.5A Gauge fuse mentioned earlier, and 7.5A MPX-B fuse located by the battery. I suggest you check that one too. Another question, are the dash lights all on as well? The side markers are activated by the main body ECU at that junction that says TRLY (see page 176 of the circuit diagram) which activates the TAIL relay, which turns on the power to both the TAIL fuse and the PANEL fuse. The PANEL fuse activates the dash back lights, so if there is a problem with the ECU keeping that TRLY connector active, all that stuff would be on in addition to the side markers. Since you say the headlights won't turn on at all, it makes me think it might be the ECU as well. They are ultimately also controlled by the main body ECU so, it is possible they got fried in there. However, possibly you got lucky and somehow fried the headlight control stalk, which would be a cheaper fix. |
| The Following User Says Thank You to Chaetagnath For This Useful Post: | eddieflyinv (04-18-2015) |
#12 |
Notttt exactly
I military spliced into the red wire from the turn signal as you suspected, but then military spliced right into the negative (black) wire on the side marker, rather than just clipping them together as I think I was supposed to. Not sure if that changes anything about what's happened.. Also I replaced the tail, panel, mpx-b, gauge, and hazard fuses, despite the fact that none of them were blown and no change ![]() But yes the headlights won't turn on, and the dash lights remain illuminated with the parking lights (signal/marker/rear lights) I'm going to bet 99% of everything I own on the unfortunate reality that it's the BCM, buuuut, since my appointment isn't till Thursday, would I be able to tell if the control stalk was fried by looking at it ? Or even looking at the BCM ? I had it out of the car and opened up earlier but didn't see anything that stood out as physically wrong with it.. Also despite the fact it may not fix anything, thanks for the time you put into that reply lol |
#13 | |
There have been others on the subject (buried in threads with other titles) with issues that are exactly the same as yours and if memory serves me they all were related to the BCM being damaged.
| The Following User Says Thank You to Tcoat For This Useful Post: | eddieflyinv (04-18-2015) |
#14 |
Drives: ft86
or the junction block. I have the same issue, a new BIU did not correct the issue.. I have ordered just the junction block, fingers crossed this fixes it. otherwise its the gauge cluster..
| The Following 2 Users Say Thank You to blown For This Useful Post: | eddieflyinv (04-18-2015), Tcoat (04-17-2015) |
| Hot fuse tap - Which fuse? | cgrey | Electronics | Audio | NAV | Infotainment | 9 | 09-17-2016 07:24 PM |
| Fuse box. | Chen | Northwest | 4 | 01-19-2015 03:51 PM |
| Best fuse to tap that is hot with car off? | Frs32907 | Electronics | Audio | NAV | Infotainment | 0 | 08-30-2014 10:11 AM |
| Fuse Box | beagoodruslan | Electronics | Audio | NAV | Infotainment | 0 | 04-19-2014 11:31 PM |
| Does anyone know the secret to Japanese fried rice? | jLoBRZ | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 03-27-2014 01:26 AM |
