Old 04-14-2015, 02:42 PM   #2087
CSG Mike
CSG Mike's Avatar
Originally Posted by alpax View Post
So, do I understand correctly - even though CARB tune was designed for 91, using 93 would actually be better?
I'm just thinking if it would make sense at all to use 94 available at Chevron in our area. Will it give more power? Any other pros/cons?
Absolutely. It will make more power on 93, even with the CARB tune.
As octane increases, the CARB tune is capable of adapting to the higher octane, and will safely give you more power.
While the primary purpose of the CARB tune is to give California owners a legal way to boost the car, it's not going to be a limitation for those outside of California that have better fuel.
alpax (04-15-2015)
Old 04-14-2015, 02:43 PM   #2088
ravisraval
Drives: 2013 FRS
Anyone have a typical CARB tune, 91 octane 0-60/ quarter mile time? Also, is a BBK pretty much required or are you ok with upgraded pads?
ravisraval is offline   Reply With Quote
Old 04-14-2015, 02:44 PM   #2089
CSG Mike
CSG Mike's Avatar
Originally Posted by LS1M View Post
I don't understand. You don't recommend adding water injection to the JRSC kit, unless I can do so without asking someone about it first?
...confused...
Originally Posted by lastexile1987 View Post
I think what he means is, if you do not have the know how to judge for yourself if you should get water/meth injection, then you are not ready to do it. If you have not already planned out potential failures/potential problems and what it means to run it, then it might not be recommended.
That's what I got from his post.
Precisely this. Generally speaking, those that add Water/Meth injection know that they're adding a significant amount of risk.
I wouldn't ever recommend it for a street driven car.
Old 04-14-2015, 03:10 PM   #2090
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
I've tracked it on stock brakes, and brakes didn't fade until near end of 4th session.
But it was TWS CCW, so I didn't need to brake that much. And it was like 40°F
ScionOfHorus is offline   Reply With Quote
Old 04-14-2015, 03:12 PM   #2091
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
I wouldn't recommend meth period
Old 04-14-2015, 04:22 PM   #2092
The Slow One
Track Junkie
Drives: Argento Scion FR-S
New driver is what you are. Going CW at tws, I had major brake fade on xp10s on stock brakes. I'm on sprints now with c300s and couldn't be happier.
The Slow One is offline   Reply With Quote
Old 04-14-2015, 04:25 PM   #2093
CSG Mike
CSG Mike's Avatar
Cold weather = more power = more braking requirements!
sw20kosh (04-14-2015)
Old 04-14-2015, 05:15 PM   #2094
ScionOfHorus
CW is way harder on the brakes. What with having to drop from ~125-135+ to about 40 for Larry, moe, and curly.
Also, who's faster, you or dai?
Old 04-14-2015, 05:15 PM   #2095
ScionOfHorus
And they cool faster
Old 04-14-2015, 05:25 PM   #2096
CSG Mike
CSG Mike's Avatar
That's a bad thing, not a good thing...
Old 04-14-2015, 05:28 PM   #2097
ScionOfHorus
Not if they stay in operating range.
The Following User Says Thank You to ScionOfHorus For This Useful Post:
CSG Mike (04-15-2015)
Old 04-14-2015, 06:16 PM   #2098
The Slow One
Track Junkie
Dai is by 3-4 seconds, having aero helps if you get to our level, I had sti brembos going ccw so I can't count that way and it's not that hard on brakes on either direction other then going into 15. And I go into turn 15 over 80 mph and brush off speed as I go.
The Following User Says Thank You to The Slow One For This Useful Post:
Old 04-14-2015, 06:49 PM   #2099
sw20kosh
Drives: 2013 Black FR-S
No. Huge swings in temperature are bad regardless. Don't argue with Mike/CSG unless you are extremely experienced at track driving. They live and breathe track and do very much know what they are talking about.
The Following User Says Thank You to sw20kosh For This Useful Post:
The Slow One (04-14-2015)
Old 04-14-2015, 07:14 PM   #2100
ScionOfHorus
So is getting your brakes hot enough to boil the fluid.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
