Sam Strano
Old 04-13-2015, 11:35 AM   #2857
chucky12012
Drives: 2013 Asphalt Scion FR-S
Congrats to Dave on the win. With such a high speed course on day 1, he had to really drive the car well to stay on top of the RX-8's. I managed to stumble my way into the fifth spot, which given the drivers/cars ahead of me, isn't too bad in this case! Courses were very fast and a blast to drive.
Day 2 was tricky with the wet course, but by CS's third runs, most of the lines were drying up, except for the last quarter of the quarter which was still very slick. Side note, four different tires in the top five of CS. I don't think any of the top cars are fully prepped for 2015 yet either as Dave mentioned about his own, I think the only one might be the 2nd/4th place RX-8.
Here is my fast run on day 2 (ended up without data on my fast day 1 run for some reason). You can see on the last quarter of the course that it was still really slick. It looked like for heats 3 and 4, this last section actually dried up pretty well as we actually got some sun too.
[ame="https://www.youtube.com/watch?v=Ux8hR-XKhRw"]https://www.youtube.com/watch?v=Ux8hR-XKhRw[/ame]
And just to show the difference for those not there, here is the first run of the same heat on Day 2.
[ame="https://www.youtube.com/watch?v=qPgA7s8XSjQ"]https://www.youtube.com/watch?v=qPgA7s8XSjQ[/ame]
chucky12012 is offline   Reply With Quote
The Following User Says Thank You to chucky12012 For This Useful Post:
MTCRX (04-13-2015)
Old 04-13-2015, 11:57 AM   #2858
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
so due to weather, any real feedback re:trd springs and the new bridgestone is tainted...?
Old 04-13-2015, 12:09 PM   #2859
chucky12012
Saturday was great weather really. I think at this point you can feel comfortable that the Bridgestones are very fast. I can say the TRD springs felt good with my B6's, car felt very flat during high speed offsets. SoloStorm seems to show me holding up to about 1.1 g's during sweepers and peaking at 1.3 g's during transitions from this weekend. I'm running Dunlop Star Specs, so I wouldn't be surprised if that would go up on Bridgestones.
I only had two events with my revalved B6's before putting on the TRD springs, so it's a bit hard to seperate the effects of the two different parts. I don't have much doubt that they improve the car a bit, I don't think it's leaps and bounds, but I expect there to be a larger impact in the fact that you can now change both sways, increase spring rate and adjust shocks as whole. Giving you the ability to tune the suspension where as before, we had what we had.
Old 04-13-2015, 01:28 PM   #2860
YawMomentRacing
YawMomentRacing's Avatar
Drives: 2013 Red 6MT Scion FR-S
The 2nd/4th place RX-8 is not fully prepped. It has the right wheels/tires but that's about it I think. I drove it during the Evo Advantage School and it felt pretty quick though.
Dave Ogburn | Yaw Moment Racing
2013 Scion FR-S - C-Street
http://yawmomentracing.blogspot.com/
YouTube Channel
YawMomentRacing is offline   Reply With Quote
Old 04-13-2015, 03:34 PM   #2861
bslate3
Drives: 2015 CWP BRZ
Have any BRZ guys tried out a 16mm rear sway bar instead of putting a larger front bar on?
I have the 19mm Perrin bar with stock shocks. It feels pretty good but it pushes in the fast steady state sweepers.
bslate3 is offline   Reply With Quote
Old 04-13-2015, 04:14 PM   #2862
Biggins
Drives: Yes
What setting on the Perrin bar?
Biggins is offline   Reply With Quote
Old 04-13-2015, 04:28 PM   #2863
bslate3
Softest setting.
I just wonder if a slightly stiffer rear bar would be a better fit for the BRZ since it is more prone to understeer than the FRS due to the spring rates.
Old 04-13-2015, 07:01 PM   #2864
xwd
It's always a tradeoff. I tried a WRX rear bar early on and it's less understeer in sweepers, but in quicker transitions or slaloms it makes the car too unstable. I don't even like a larger rear bar with the STX setup.
Old 04-13-2015, 07:04 PM   #2865
mpicher
Autocross Nut
mpicher's Avatar
Drives: Argento 2013 Scion FR-S - MT
Originally Posted by cactus View Post
You have to remove the hubs to get the ARP suds in.
Only in the back... there's a punchout for the front hubs.
mpicher is offline   Reply With Quote
Old 04-13-2015, 11:59 PM   #2866
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Originally Posted by YawMomentRacing View Post
Here is my onboard video from College Station.
Day 1:
https://www.youtube.com/watch?v=N6k1rOiI_iI&feature=youtu.be
Day 2:
Just wondering if it was worth shifting to 3rd (except the finish) ?
Looking at the mph, wouldn't you have the same speed in 2nd?
Just wondering?
Nice driving .
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 04-14-2015, 09:56 AM   #2867
YawMomentRacing
The first shift was absolutely worth it. I didn't shift to 3rd on the first lap and hit the limiter right as I tracked out to the "cone wall" and basically had to coast into the corner on the rev limiter. This was a large portion of my time gain from Run 1 to Run 2.
The 2nd shift is debatable - I did it differently every run. First run I shifted to 3rd and left it in until the next "hairpin", the 2nd run I didn't shift, and the 3rd lap (after looking at data from the first two runs) I tried to get the best of both world which was to upshift then downshift early to mid-corner so keep the revs/torque up for the exit but still get more speed on the "straight" before the corner. My 2nd to 3rd runs were pretty close through that section, but the 2nd run was a touch quicker. I downshifted a little early and pulled a little too much speed out when I downshifted on the 3rd so it certainly could have been better. The third shift through the finish was worth it I think.
Managing the shifts is a new part of the "strategy" for me and it can pay huge dividends if you get it right and conversely huge penalties if it's wrong. Coming from a 75mph 2nd gear ESP car, this was not the case.
YouTube Channel
Old 04-14-2015, 10:37 AM   #2868
chucky12012
Yeah, there were three shift points on the day 1 course. With my current setup I was maxing out 2nd gear at about 58 mph, when I shifted to 3rd in all three areas I saw beyond 60 mph. Going into the hairpin I saw about 62/63 and the same at the finish.
Old 04-14-2015, 01:15 PM   #2869
Simmons
Simmons's Avatar
Good to hear. The good thing is these cars are easy to shift compared to others.
You are probably missing having that HP/TQ the Camaro had also
Simmons
Old 04-14-2015, 01:53 PM   #2870
YawMomentRacing
Simmons
Yes, torque is nice....
YouTube Channel
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
