Old 04-09-2015, 11:15 PM   #365
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
@steve99
I think I'm getting some IAT related knock so I was going to run these changes, what exactly does it do? Does it pull timing with respect to temperature, so at 86 degrees it pulls 1.05 degrees of timing from the entire table?
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 04-10-2015, 12:02 AM   #366
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by Wayno View Post
Interesting. I wonder if that's the issue I'm having. Doesn't hurt to give it a whirl.
Old 04-12-2015, 08:11 PM   #367
Wyattkb
Drives: 2014 Whiteout FRS
Could someone review these 2 small logs I made and let me know if anything looks bad or if I am missing any other parameters I should be logging?
http://www.datazap.me/u/wyattkb/pull-1
and
http://www.datazap.me/u/wyattkb/pull-2
Wyattkb is offline   Reply With Quote
Old 04-12-2015, 09:55 PM   #368
phrosty
and
Your IAM is < 1, so you're experiencing some knock that you might want to work on. You're also running very rich at WOT, do you have an intake?
phrosty is offline   Reply With Quote
Old 04-12-2015, 11:00 PM   #369
Wyattkb
Dang. I do have an AEM drop in filter. UEL Catless header and a muffler delete. Running on the latest stage 2 OFT flash.
What can I do to work on the knock?
Old 04-13-2015, 01:01 AM   #370
steve99
Drives: FT86
If its only a drop in filter thats fine its only a problem if entire intake changed.
Your fuel trims look fine
Are you on 91 fuel ?
looks like its knock below 4000 rpm ca(sing iam to drop.
dont panic its only minor knock.
oft tunes tend to run rich for safety.
the knock and richness is easily fixed by pulling a bit of timing and scaling open loop maf values see below.
Wyattkb (04-13-2015)
Old 04-13-2015, 01:19 AM   #371
Wyattkb
I am running on 91 QT gas. Looks like I have some reading to do.
In the mean time I was going to change my tune from v2.063 to v1.59 and see if there are any changes. I tried to read the update logs but I didn't see anything "big". Anyone know what the main changes are?
Old 04-13-2015, 08:00 AM   #372
steve99
Drives: FT86
ask some of the california guys they only have 91 so have sweakek their tunes a bit they can probably send you rom or table chaged try @JB86'd
Old 04-16-2015, 11:28 PM   #373
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Stage 2 EL E85 tune:
http://datazap.me/u/slowbaru/april-1...9&zoom=263-590
Ran through half a tank of e85 before doing these pulls.
BRZoomTX is offline   Reply With Quote
Old 04-17-2015, 12:25 AM   #374
Phantobe
Phantobe's Avatar
I'm still tweaking my tune lol the knock is strong with this one...
I think this revision my IAM shouldnt drop below .95 so I think Ill be happy enough to switch to E85 for the long term.
Old 04-17-2015, 09:34 PM   #375
ChuckButta
Drives: 2015 FRS RS1
Hey guys just got my OFT few days ago and loaded up the Stage 1 tune. I am a total newb at software tuning, but i am eager to learn !
I have a 2015 FRS RS1, with grimmspeed cold air. Stock other than that. If anyone could give it a look and let me know the good, the bad, the ugly about my readout i would appreciate it. Im pretty positive this is a second to 3rd pull.
http://www.datazap.me/u/chuckbutta/1...e?log=0&data=1
ChuckButta is offline   Reply With Quote
Old 04-17-2015, 10:04 PM   #376
steve99
Drives: FT86
looks pretty normal for oft tune nothing to be concerned about.
chase up the oft guys about fixing the advance multiplier and flkc logging on the new D00C and D roms
looks like Adbance Multiplier logging still not working on the latest roms as its logging at zero should be 1, also try logging knock correction and flkc
read the links below will explain
ChuckButta (04-17-2015)
Old 04-18-2015, 03:03 PM   #377
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
JDL UEL, GrimmSpeed CAI and 94 oct. I have scaled the MAF several times and it's starting to look like it is as good as I can do.
http://datazap.me/u/dmmccrea/apr-18-...zoom=1025-1541
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
Koa (04-18-2015)
Old 04-18-2015, 03:23 PM   #378
Koa
IAM/MafV working on my D00C since they updated 2-3 months ago
he may have not downloaded latest updates
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
