Old 05-20-2012, 05:28 PM   #71
RearDrive
Drives: 2000 accord v6 coupe
How about 18x8.5+30 or 38 all round! Also can't u just use spacers in the rear with the same width all around without creating more understeer while making it more flush?
RearDrive is offline   Reply With Quote
Old 05-21-2012, 10:14 AM   #72
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
This was asked earlier.
Originally Posted by Draco-REX View Post
Widening the track will have similar results to having a staggered setup. The wider track will reduce weight transfer between the tires and increase overall grip in the rear. Though it would likely have less of an effect than larger tires so it may not matter a whole lot.
Originally Posted by Brian S View Post
How much do you think that will effect handling? In other words how much understeer will it promote?
For the average driver? Only a little, maybe not enough for a driver like that to notice. But for an AutoXer, enough that the spacers would likely be removed for competition.
Old 05-22-2012, 03:28 AM   #73
blags
Drives: Toyota 86
I'd like to run 18x9+30 front and 18x10+38 rear. In saying that, I'll be buying coilovers, that'll change any clearance issues wouldn't it?
blags is offline   Reply With Quote
Old 05-22-2012, 07:20 AM   #74
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yes but maybe for the worse.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-22-2012, 07:55 AM   #75
Staticfrost
Drives: Eight Six
how would 18x8 +40 be all round?
Staticfrost is offline   Reply With Quote
Old 05-22-2012, 01:14 PM   #76
MattR
Running in the 90s
MattR's Avatar
Drives: 2014 Scion FR-S Monogram
I feel all tame with the flush crowd chiming in. Must be getting old.
I'm going to run as close to stock offset as I can with 7.5 wide wheels sitting on 225s. Just tossing around whether or not I want to go with 17s or 18s. Leaning towards 17s currently for obvious reasons. 18s look really freakin good on this car though.
MattR is offline   Reply With Quote
Old 05-22-2012, 01:28 PM   #77
Srslidins14
Drives: S13, s14, yaris, 4runner
Can we get a picture like that of the op but with the wheel jacked up to normal ride height so we can get a better look at what offsets will fit. Of course the wheel will sink in alittle at the top when the suspension is settled....
Or is this what stock ride height looks like? Pictures are decieving...
Srslidins14 is offline   Reply With Quote
Old 05-22-2012, 05:22 PM   #78
RavSpec
Drives: Rx7
front is flush, but rear tuck in a bit.
RavSpec is offline   Reply With Quote
The Following 2 Users Say Thank You to RavSpec For This Useful Post:
civicdrivr (05-22-2012), Staticfrost (05-22-2012)
Old 05-22-2012, 05:22 PM   #79
RavSpec
Drives: Rx7
we didn't get a chance to load the suspension to normal height, but this is not going to be off too much.
Old 05-22-2012, 05:23 PM   #80
RavSpec
Drives: Rx7
we just confirmed 18x8.5 +47 will fits as well ...
The Following User Says Thank You to RavSpec For This Useful Post:
MattR (05-22-2012)
Old 05-22-2012, 06:28 PM   #81
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
RavSpec where are you in NY? I'm in Queens.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 05-22-2012, 06:30 PM   #82
Staticfrost
Drives: Eight Six
so how much tucked in is it in the rear?
What would be a good spacer size to get it close to flush
with the 18x8.5 +47 how were the fronts? wast here any poke?
Old 05-23-2012, 12:36 AM   #83
RavSpec
Drives: Rx7
deer park NY, exit 51 off LIE.
Old 05-23-2012, 12:38 AM   #84
RavSpec
Drives: Rx7
Should be no poke in the front with 8.5 +47.
If staying with 8.0, don't necessary need spacer. But if u want flush, I say around 15mm to 20mm spacers should do the trick.
Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 124 08-01-2016 10:38 PM
Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 05-26-2015 11:39 AM
Wheel Directory: Work Emotion XD9 18x10.0 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 05-22-2015 11:54 PM
Wheel Directory: Work VS-XX 18x9.0 +33 / 18x10.0 +33 brunofrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 11-08-2013 12:26 AM
Wheel Directory: Work Emotion 11R 18x9.5 +30 autofashionfred Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 08-11-2012 01:39 AM
