#2395 |
Drives: '16 BRZ Limited
I'm not sure if this is the correct thread to ask, but has anybody with a 2015 BRZ Limited replaced their springs with the RCE Yellows. Was hoping for somebody to chime in about how ride was compared to stock since there was supposed to be a suspension change for the 2015 MY
#2396 |
Drives:
@csgmike what type of upgraded springs do you recommend on stock suspension, with rs3s size 225 17 45, Vortech stock pulley, my home track is willow springs international raceway, two track days so far..
The stock setup feels like lots of body roll now I am also running the raceseng camber plates. Thank you! Sent from my SGH-M919 using Tapatalk 2 |
#2397 | |
#2398 |
Drives: '15 - WRB Brz Limited
Omg. I just 'read' all 110 pages of this thread today. It took a long time. I'd like to say thank you to @CSG Mike, @Racecomp Engineering, and @7thgear for the responses, suggestions, and advice. I don't know how you guys do it. The number of times I read different people ask the same question that has already been asked and answered in one form or another is ridiculous. As mentioned, you guys appear to have patience in spades. I'm sure I'll get around to asking you some of the same questions some day, just for reassurance like many people do, but not today.
2015 WRB Brz Limited 6MT
2001 BMW 540i 6MT M-Sport (sold) 2001 BMW 325ci 5MT (sold) 1988 Volvo 740 Turbo 4MT w/ electric OD/5th gear (sold) |
#2399 |
Actually, I do have a question @Racecomp Engineering & @CSG Mike. Have you guys gotten your hands on a stock MY15 BRZ to take a look at the rear spring rates and put the shocks on a dyno to see if there are any differences from the MY13 & MY14?
#2400 | |
#2401 | |
Drives: FRS
#2402 |
I'm not a suspension expert. Im not even a novice. But the questions you would need to answer for @Racecomp Engineering or @CSG Mike would be the followings:
1) what are your goals for the car? What are you trying to correct/improve (looks or performance)? 2) what kind of driving do you do/planning on doing? Just daily driving? Spirited driving? Canyons? AutoX? HPDE? Track? 3) what is your current wheel and tire setup (details is size/brand)? 4) for your budget, why are you thinking coils vs a quality lowing spring and quality shock that will perform better than an entry level coilover? 5) how are you planning on addressing camber (front & rear)? Going too low and not having a solution for excessive rear camber alone could have your car handling with less agility than stock.
#2403 |
Drives: FRS
I was joking.... They have been asked that question at least a hundred times and they are always very professional.
#2404 | |
I agree with you that those guys are A+
#2405 | |
Spring rates are the same, shocks are very close. - Andy |
#2406 |
Drives: Raven Fr-S
I apologize if this has been asked already, but which aftermarket shocks should i pair with the RCE yellows that i already have?
My FRS is a daily driver with canyon runs every warm month and 2-3 HPDEs a year. Wheels are 17X7 Kosei (14lbs) with Michelin PSS 215/45-17. I plan to achieve 190-200 lbs weight reduction on the car (currently at -135lbs). I guess my choices are Koni complete struts, Bilstein B6 and B8. Thanks in advance...
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
#2407 |
Drives: Whiteout FRS
Are new end links required for sway bars? I'm planning on purchasing 21mm front and 17mm rear solid sway bars.
Thanks! |
#2408 | |
- Andy |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
