Old 04-11-2015, 04:34 PM   #211
burdickjp
Drives: 2013 ultramarine Scion FR-S
Originally Posted by wparsons View Post
And how do you know when you've made an improvement or made something worse?
Volumetric efficiency goes up or goes down.
burdickjp is offline   Reply With Quote
Old 04-11-2015, 06:03 PM   #212
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
How is that measured?
Old 04-11-2015, 08:24 PM   #213
burdickjp
PV=nRT
Old 04-11-2015, 08:49 PM   #214
Andrew025
Andrew025's Avatar
PV=nRT
What I should have said, how can Kool measure that directly?
Old 04-11-2015, 10:26 PM   #215
zooki
Drives: waiting on a 2021...
Maybe if he gets better gas mileage pulling a trailer full of brush?
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 04-11-2015, 11:45 PM   #216
burdickjp
Can we be constructive? We've all beet wrong before, and we'll all be wrong again. Ridicule is not the most effective way to help people. The guy wants to play and is willing to share. Let's encourage him in the right way and provide positive suggestions rather than just calling his ideas stupid.
Old 04-11-2015, 11:50 PM   #217
steve99
Drives: FT86
http://www.romraider.com/forum/viewt...hp?f=15&t=6258
Old 04-12-2015, 12:59 AM   #218
burdickjp
That thread makes the common mistake of saying that volumetric efficiency is a ratio of volumes. It's not. VE, as defined by SAE J604 is actually calculated as the mass of air delivered through the intake valve with respect to a mass of air equivalent to the swept volume (not total volume) at ideal density.
I'm sure there are some people here who see problems with that in practice. For instance we were just discussing how charge can be delivered through the intake valve and then out the exhaust port. It would contribute to the VE calculation, but not combustion.
This is why I prefer using the ratio of the mass of charge in the cylinder when the intake valve closes over the mass of the swept volume at ambient temperature and pressure. That all may be unneccessary, though.
Here's an intriguing thought about MAF cars, which is new territory to me. I've previously only tuned with MAP and TPS based load (speed density and alpha-n for those who really care). The MAF is actually measuring the mass of air going in. It inverts the axes you'd otherwise use as load to say "at this load and RPM you have this VE." It would be saying "at this mass flow and RPM you have this mass flow".
So what we really need is something independent of the mass flow to use as an axis for the sake of comparison. You could use MAP, which would emulate speed density, or TPS, which would emulate alpha-n.
In this way you would log MAP, TPS, RPM, and load. You'd make a table with MAP as one axis, RPM as the other, and load as the interior values. You'd do that before and after changes and subtract one from the other. The difference is where you're getting better or worse VE.
You'd do the same for TPS for the sake of correlation.
You could invert that if you wanted to, and instead of maximizing mass at a given MAP or TPS, you could minimize MAP or TPS for a given load.
This is conjecture. I haven't done it yet, but it should give you something akin to VE comparison.
Old 04-12-2015, 01:23 AM   #219
That thread makes the common mistake of saying that volumetric efficiency is a ratio of volumes. It's not. VE, as defined by SAE J604 is actually calculated as the mass of air delivered through the intake valve with respect to a mass of air equivalent to the swept volume (not total volume) at ideal density. ...
I went down that rabbit hole earlier today but realized in the end absolute accuracy is irrelevant in this exercise. The before-after delta is still quite useful.
Old 04-12-2015, 10:35 AM   #220
burdickjp
For the sake of cam timing tuning, all we want is something we can use to get a delta.
I was thinking about it more last night, and I think calculating the mass of the swept volume for a given manifold pressure and intake temp and comparing it to load is probably the most correct. I believe that the romraider thread had discussed that at one point.
Old 04-12-2015, 01:10 PM   #221
Koa
There is life after a forest fire. Love the info here guys thank you
Old 04-12-2015, 04:42 PM   #222
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Started a new thread in the software tuning section, since this has come so far from the original thread. http://www.ft86club.com/forums/showthread.php?t=86569
KoolBRZ is offline   Reply With Quote
guy knows nothing, world's last, zero facts
Wtb ft86 uel header 86socal Want-To-Buy Requests 1 08-23-2014 09:00 PM
Anti A-Hole Button ButtonMasher Off-Topic Lounge [WARNING: NO POLITICS] 45 07-25-2014 12:55 PM
Eibach Anti-Roll Kit babykwiss Canada Classifieds 1 07-14-2014 09:29 AM
Fastest FT86 in the World 9.10@256km/hr! Bahraini86 Forced Induction 94 02-19-2014 12:25 PM
is it necessary to change anti-roll bar? yuli8466 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-25-2012 10:58 AM
