Old 01-19-2015, 05:28 PM   #743
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
http://instagram.com/p/yC_kU6QB9o/
texasbound972 is offline   Reply With Quote
Old 02-26-2015, 12:17 PM   #744
OnionTou
OnionTou's Avatar
Drives: Toyota GT 86
anyone know what kind of material is used in the gasket?
The shop that was doing the installation lost 1 of them, and I just want to be sure they buy the right material to replace the lost O-Ring.
OnionTou is offline   Reply With Quote
Old 02-26-2015, 12:28 PM   #745
s30series
Drives: 2015 BRZ Series.Blue
Originally Posted by texasbound972 View Post
What is this supposed to show?
s30series is offline   Reply With Quote
Old 02-27-2015, 12:51 PM   #746
texasbound972
USMC
The power blocks installed.
Old 03-19-2015, 01:01 PM   #747
OnionTou
OnionTou's Avatar
So after a long time I got a new O-ring, and I decided to install the powerblocks on my own. It really is a pain in the as_.
I had to unplug a few things, but when I restarted the car I had a P0108 error. "Manifold Absolute Pressure/Barometric Pressure Circuit High Input"
I cleared the error but it popped up again.
I checked all my connections, and everything looked fine. But just wanted to ask, where is the MAP sensor located to doublecheck it?
Old 03-21-2015, 05:00 PM   #748
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
So is anyone using these with one of the supercharger set ups?
Jmonty is offline   Reply With Quote
Old 04-11-2015, 01:21 PM   #749
texasbound972
USMC
The Following User Says Thank You to texasbound972 For This Useful Post:
GhostOp86 (04-16-2015)
Old 04-11-2015, 03:39 PM   #750
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
This is before and after power blocks on e85?
jaorocks1 is offline   Reply With Quote
Old 04-11-2015, 08:46 PM   #751
texasbound972
USMC
This is with the power blocks.
Old 04-11-2015, 08:51 PM   #752
texasbound972
USMC
I don't have a before with 23 psi.
Old 04-16-2015, 12:47 PM   #753
Ripp91
Ripp91's Avatar
Drives: 2013 Subaru BRZ
Did my install on these yesterday with a buddy ( highly recommend a second set of hands when doing this ) the total install went extremely smooth and only took about an hour and a half the most. And I gotta say the car feels amazing. You definitely notice the difference these make and the throttle response is 100 times better. I'm extremely pleased with these. Just need to give the car a bit more time to learn that they're in there but all in all I love the way the car drive even more.
Ripp91 is offline   Reply With Quote
The Following User Says Thank You to Ripp91 For This Useful Post:
Jmonty (04-19-2015)
Old 04-30-2015, 09:35 AM   #754
FRS-Bill
Drives: 2014 FRS
I put mine in this last weekend. Install went really smooth until it came time to bolt down the brake vacuum line. If you just bolt it down it makes the line really tight, So we took a piece of metal pipe the same inside diameter as the hole and cut it to 1.5 in length then used one of the factory intake bolts and the line has the same play as it did from the factory. I think Crawford should start putting one of these in the kits. By the way, the car runs great. Bill
FRS-Bill is offline   Reply With Quote
Old 06-06-2015, 01:59 PM   #755
Matey
Drives: Pearl White BRZ
Can someone explain to me why it doesn't benefit FI? it'd be doing the same thing it is right now, would it not? don't troll me. this is a 100% serious question. thanks.
Matey is offline   Reply With Quote
Old 07-24-2015, 10:38 AM   #756
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
I have a set as well, but never installed them because I am running the Vortech Supercharger kit. I wish Crawford would chime in and verify that they are only good for N/A cars.
Deepseadiver is offline   Reply With Quote
billet, crawford, magic blocks
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 06:19 PM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 09:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 03:29 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 10:40 PM
