Old 05-19-2012, 11:04 PM   #15
fatoni
Originally Posted by Midship Runabout View Post
Such a simple answer is getting waaaaay over complicated. Wider wheels allow wider tires. Wider tires equal larger contact patch. That simple.
I dont think you know what psi means. Explain your reasoning please because I dont follow
Old 05-19-2012, 11:07 PM   #16
fatoni
Originally Posted by chulooz View Post
This is certainly right.
Who would argue that a larger tire doesnt have a larger contact patch? Take a civic with 185s then a 911 with 235s, the naked eye can notice the difference.... driving it is even more impressionable.
by its very nature you cant see contact patch. Patch shape will change but the size wont
Old 05-20-2012, 03:53 AM   #17
DEnd
Drives: anyone seen my steering wheel?
I would but then again I know why I'm talking about.
A tire is basically an air spring, therefore as long as the spring rate is the same ( which may or may not be at different PSIs) then the size of the contact patch will be the same.
DEnd is offline   Reply With Quote
Old 05-20-2012, 10:17 AM   #18
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Lol at the guys who don't think larger tires have larger contact patches. Just keep on keepin on I guess.
chulooz is offline   Reply With Quote
Old 05-20-2012, 11:26 AM   #19
TwinscrollGT35R
Drives: 2006 Subaru
Exclamation
I know. I'm just kicking back watching. Tooo funny
TwinscrollGT35R is offline   Reply With Quote
Old 05-20-2012, 12:21 PM   #20
korinfox
Drives: Lexus IS300 Sportcross
Wider tires do not have larger contact patches given the same air pressure is used. Change in tire width only changes the shape of the contact patch, as long as the air pressure in the tire stays the same.
Read this article.
korinfox is offline   Reply With Quote
Old 05-20-2012, 12:43 PM   #21
TwinscrollGT35R
Drives: 2006 Subaru
Lol... how about some real life experience. I can go blog an article on bigfoot. Doesn't mean he is real too.
Old 05-20-2012, 01:35 PM   #22
Dimman
Kuruma Otaku
Dimman's Avatar
Please explain what real life experience we can use to evaluate contact patch area.
Because titanium.
The Following User Says Thank You to Dimman For This Useful Post:
fatoni (05-20-2012)
Old 05-21-2012, 11:33 PM   #23
DEnd
There have been glass floor measurements done that prove it.
Old 05-21-2012, 11:49 PM   #24
fatoni
I think he is just calling out this guy on his personal experience. Not the possibility to objectively measure contact patch size
Old 05-22-2012, 12:04 AM   #25
Dimman
Kuruma Otaku
Dimman's Avatar
Well I would love to be able to objectively measure my own contact patch myself, too.
Because titanium.
Old 05-22-2012, 12:36 AM   #26
chulooz
Registered you sir
chulooz's Avatar
Jack the corner/tire, chalk the rubber, lower the tire down onto dark paper/cardboard, voila there's the contact patch.
Old 05-22-2012, 01:43 AM   #27
Dimman
Kuruma Otaku
Dimman's Avatar
Way ahead of you. Heard of a 'polar compensating planimeter'? Now just trying to figure out a fast and convenient method to adjust camber and move large amounts of weight around...
Because titanium.
Old 05-22-2012, 01:46 AM   #28
DEnd
That will never work. You have to build a garage with a basement, then get some engineered glass to drive the car over so that you can look up and measure from the bottom. I mean really, why do stuff the cheap way when you can spend loads of money to get the same results?
Finally Got Mine...Yep Another One of These Threads! kmbkk Scion FR-S / Toyota 86 GT86 General Forum 15 05-24-2012 11:49 PM
