Old 04-09-2015, 04:45 PM   #169
DAEMANO
Time Traveller
Originally Posted by GotBRZ1691 View Post
Hey so I clicked the link and noticed I was not on the waiting list. I was at some point, has it been updated? or re-done?
Yes, the most recent update is here:
http://www.ft86club.com/forums/showp...postcount=8491
If you're not on and should be PM @fenton and @Robftss . I know you've been around for quite some time.
Update: Checked, you are #23 on the list, there are 6 RHD's above you, so that 23 might actually be #17.
The Following User Says Thank You to DAEMANO For This Useful Post:
GotBRZ1691 (04-09-2015)
Old 04-09-2015, 05:47 PM   #170
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Apparently I cannot read
GotBRZ1691 is offline   Reply With Quote
The Following User Says Thank You to GotBRZ1691 For This Useful Post:
DAEMANO (04-09-2015)
Old 04-09-2015, 06:05 PM   #171
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Since people keep pointing it out, what would it take to make the ESC a full time FI application or is it simply not possibly since its using a finite source of energy?
More efficient batteries, higher output alternator? Is it possible to regenerate more energy than you're using for this application?
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 04-09-2015, 06:15 PM   #172
DAEMANO
Time Traveller
Shiv's Procede Controller for Rob's Phantom kit will make it the Phantom ESC full time F.I.. This is being rolled out in the coming weeks. For Miata's even sooner. That's the PID controller being discussed earlier in the thread.
Old 04-09-2015, 06:17 PM   #173
DAEMANO
Time Traveller
Haha you're doing ok. If you don't want to wait at all, you can buy this one RIGHT MEOW!
http://www.ft86club.com/forums/showthread.php?t=86391
Old 04-09-2015, 06:20 PM   #174
Phantobe
Phantobe's Avatar
Originally Posted by DAEMANO View Post
Shiv's Proceed Controller for Rob's Phantom kit will make it the Phantom ESC full time F.I.. This is being rolled out in the coming weeks. For Miata's even sooner. That's the PID controller being discussed earlier in the thread.
How does it work? If you don't mind explaining lol.
Won't you eventually run out of juice to power the electric motor, if it's constantly under boost?
The Following User Says Thank You to Phantobe For This Useful Post:
Old 04-09-2015, 06:25 PM   #175
DAEMANO
Time Traveller
Apparently nope. The controller and alternator seem to have no problem keeping up. Read in this neighborhood:
http://forum.miata.net/vb/showthread...567709&page=13
The 86 integration is just a few weeks behind the Miata integration so the most up to date info is in the Miata camp. I'm sure @Shiv@Openflash and @Robftss will update the 86 info as progress is made. They've got 86 ESC owners (like me) chomping at the bit.
Old 04-09-2015, 09:32 PM   #176
PowderfaceTr.
PowderfaceTr.'s Avatar
Drives: stock
I just meant market data would be better for your argument.
Remember all the big auto engineers have this coming out as a compound boost assist tech. You all will be swapping out yours for a used OEM ESC. I'm pretty sure Id have the MERC ESC swapped into my BITURBO FT86 before some one knocks off robs.
LOl MIATA what a waste, you take the most bullet proof Mazda motor. The one that handles over 20psi in its stock form and only boost it with 8psi. Wow such unused potential. WHy not leace it stock so we can all race SM for another decade.
Advice On Proper Fundamentals of Japanese Motor Vehicle Feel free to ask.
PowderfaceTr. is offline   Reply With Quote
Old 04-09-2015, 10:04 PM   #177
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
The arguments change. But some things stay the same
Shiv@Openflash is offline   Reply With Quote
Old 04-09-2015, 10:44 PM   #178
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
It's definitely a niche market. The problem with ESC's long term is that they are a power adder for an internal combustion engine that relies on electrical energy storage. This means as battery tech gets better, the industry will be more likely to use that for propulsion directly rather than in an application like this. You hit diminishing returns very quickly both in cost and performance as desired boost and engine size increase. The utilization of this tech for reducing turbo lag or accessory engine load seems like a better long term approach to strapping on what is basically a second starter motor.
Can it be effective in small engine applications? I think it can, but it's also a product dependent on technology that invalidates its existence (better batteries).
Whatabouteggs is offline   Reply With Quote
The Following 2 Users Say Thank You to Whatabouteggs For This Useful Post:
PowderfaceTr. (04-09-2015), xuimod (04-18-2015)
Old 04-09-2015, 10:52 PM   #179
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Battery tech has gotten slightly better, but it is leaps behind becoming the standard in transportation, plus you forget they are fighting the oil companies who through physics, luck or intervention have seemed to stifle any alternative form of transportation energy for the past 100 years.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 04-09-2015, 11:01 PM   #180
DAEMANO
Time Traveller
I think @Whatabouteggs is talking about Hybrids and pure electrics. Even when battery tech is well enough to power a vehicle directly our refueling infrastructure won't be. For that reason, Internal combustion, fossil fuels, and ESCs are going to be around for another good 25-30 years.
Old 04-09-2015, 11:33 PM   #181
PowderfaceTr.
Drives: stock
^^The last two messages were the best things so far in his thread. I would like to take some credit here for indirectly provoking this kind of open discussion.
While we are off topic, I MUST say:
There is a trend in hyper light materials engineering. Lighter high temp pistons may be developed before nano chemistry becomes energy dense enough.
If micro pistons are not developed first. These new batteries, assuming they are rare compounds, would go strictly into commercial aviation for solar propulsion.
Before silent vacations to Europe. I would really prefer to see 20,000 rpm 1 Liter Atkins engines. Ones which bolted on is a compressor powered off the waste heat via thermoelectric material coatings.
Old 04-09-2015, 11:47 PM   #182
DAEMANO
Time Traveller
I would love to see how pretty the colors are in your mind.
tyrantcf (04-11-2015)
Open Source Electric Supercharger neutron256 Forced Induction 913 08-22-2021 05:16 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
FS: Phantom ESC (Electric Supercharger) *SOLD* SloS14 Engine, Exhaust, Bolt-Ons 13 01-13-2015 09:18 PM
Phantom Electric Supercharger cuddefred AUSTRALIA 2 07-11-2014 01:13 AM
Anyone with Phantom Electric Supercharger? frslee Mid-Atlantic 0 06-19-2014 12:29 AM
