Old 05-17-2012, 12:13 AM   #15
PERRIN_Jeff
PERRIN_Jeff's Avatar
Drives: Matte Black STI
Our first version will be a dual tip setup, and today we played around with sound. Its amazing how quiet the car is with no catback. Fun times to come for sure!
PERRIN_Jeff is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Jeff For This Useful Post:
ESBjiujitsu (05-21-2012)
Old 05-20-2012, 04:24 PM   #16
DanPO
DanPO's Avatar
Drives: Future BRZ owner
I hope Perrin comes out with a straight back (center exit) race pipe with dual tips (no muffler). You would obviously need a different rear lower fascia/valance (whatever it's called) to make the center single exit pipe look nice. Would be cool if there was a carbon fiber option on the rear lower fascia/valance. This setup without a muffler would save a ton of weight and be an aggressive option for track go-ers.
DanPO is offline   Reply With Quote
The Following User Says Thank You to DanPO For This Useful Post:
Old 05-21-2012, 09:40 AM   #17
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
yes yes yes!!!!! but i would love straight pipe single to dolphin tip and a carbon fiber exit delete on the other side but im sure anything they put out will sound and function amazing!
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 05-21-2012, 04:54 PM   #18
Subaruwrxfan
Subaruwrxfan's Avatar
Drives: 2015 Mustang EcoBoost
Please do something amazing with the sound. That's one of the weakest points on the car for me is the lack of a good exhaust note. I am still rocking a Perrin Catback on my Legacy GT that you guys discontinued a long time ago and I still think it's the best sounding exhaust for the LGT. Crackles, burbles, and even pops sometimes, great bass but no drone, perfect volume. Glorious.
Check out my BRZ videos on my YouTube page: youtube.com/subaruwrxfan
Subaruwrxfan is offline   Reply With Quote
The Following 2 Users Say Thank You to Subaruwrxfan For This Useful Post:
civicdrivr (05-21-2012), PERRIN_ADAM (05-23-2012)
Old 05-21-2012, 10:40 PM   #19
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Dual tip center exit exhaust FOR THE WIN!! Make it happen Perrin!
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 05-21-2012, 11:02 PM   #20
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by serialk11r View Post
Turbowned, you're quite mistaken about the primary cat, which I've seen you post 2 times now lol. That's the precat, the primary cat is downstream.
Originally Posted by Turbowned View Post
Ugh, now I gotta dig through old threads to confirm... gimme 5 minutes!
Yep, you're right. Pre-cat. I think I read Draco-REX say it and I just regurgitated. You corrected him, too.
The second cat isn't monitored. The downstream O2 is located after the cat in the manifold and before the second cat further down.
Are you referring to a difference in construction? Because as far as the ECU is concerned, the cat in the manifold is the only cat on the car.
Old 05-21-2012, 11:05 PM   #21
Draco-REX
Corner Junkie
Draco-REX's Avatar
Oh, On-Topic post:
Because the HKS Spec-L specifically is designed for lightness and the manufacturer has stated a weight for it, it is now at the top of my list.
Weight matters with this car, so it matters to me more than ever.
The Following User Says Thank You to Draco-REX For This Useful Post:
stevo_12v (07-23-2013)
Old 05-22-2012, 04:44 AM   #22
Gardus@Supersprint
Drives: Clio TCE
I think the Spec-L will be too loud once you start playing with the headers and cats.
I'd like to see what happens to the power and torque curve removing the secondary cat and fitting a good catback.
Gardus@Supersprint is offline   Reply With Quote
Old 05-22-2012, 05:13 AM   #23
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I was under the impression that removing emission control items made the car non-roadworthy.
Old 05-22-2012, 05:15 AM   #24
serialk11r
Drives: '06 AM V8V Coupe
I assume good catback includes a replacement catalytic converter?
Old 05-22-2012, 05:26 AM   #25
LivingLegend
Drives: 1994 Toyota Tercel
Correct me if I'm wrong but I always thought Catback exhausts replace whatever is behind the catalytic converter but you still would use your original cat...reason for the name catback. Unless your taking about the exhaust companies replacing the original cat with a high-flow cat? I feel like those exhaust would be really pricey...
LivingLegend is offline   Reply With Quote
Old 05-22-2012, 05:40 AM   #26
Gardus@Supersprint
Drives: Clio TCE
As there are two cats emission won't be terribile with just the 1st one.
Obviously the best solution is to replace both of them with a 1st grade sport cats, but to just replace the 2nd with a straight pipe is cheap and won't turn on any CEL as it's not monitored.
Old 05-22-2012, 05:56 AM   #27
Captain Snooze
Drives: Red Herring
I wasn't referring to being able to drive the car. I was referring to the legality of driving a vehicle with modified emission controls.
Old 05-22-2012, 06:26 AM   #28
Gardus@Supersprint
Drives: Clio TCE
That depends on the country...
Usually in Italy the pre-cat is enough to pass emission control, if the car is well warmed up.
Stock Wheel Weight Dionysus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-01-2012 02:46 AM
Official JDM BRZ weight and MPG ayau BRZ First-Gen (2012+) — General Topics 50 02-08-2012 03:04 AM
weight loss cynic Scion FR-S / Toyota 86 GT86 General Forum 36 10-24-2011 05:04 AM
Weight of FT-86? Levi Engine, Exhaust, Transmission 38 06-14-2011 11:43 PM
FT-86 weight distribution? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 15 04-04-2011 11:58 AM
