#29 |
Off Topic
#30 | |
Drives: FRS
and each speaker has passive crossover caps on board the speaker as I recall. I don't have any of them in anymore, I could look when I get home, but that's what I recall. edit: the full signal deff goes into the tweeter, I don't think it would be possible for them to have fit a crossover network on the back of the tweeter, I think it's a simple parallel setup
#31 | |
Off Topic
#32 | ||||||
Drives: 2014 BRZ Limited (DGM)
Yes, shitty speakers will likely sound shitty. But it has nothing to do with whether they're 8" or 10" diameter, it's because they're shitty. Quote:
While these are not at all bad speakers, my recommendation is that you take a step back and unprogram your brain that you must use 8" drivers. Quote:
http://www.pacificstereo.com/jl-audi...frs-10tw3.html Click the green button that says "Sign up" and you'll get a 20% off coupon for your first order. That makes the Stealthbox $520. http://www.sonicelectronix.com/item_...NVX-MVPA1.html $160. So, that's $680, which leaves you $70 for a wiring kit and any other miscellaneous items. And that Stealthbox will produce exactly the kind of bass you've been describing. It will not rattle the car apart, it will not blow the windows out of the neighbors' houses, but it will add a solid, clean, low-end thump. It installs in the corner of the trunk and makes the most efficient use of space possible. It *IS* capable of producing quite a surprising volume level of bass, so you'll want to be prepared to start hunting down rattles and vibrations in the car, which are the car's fault, not the sub. That's only a factor depending on your usage of the volume knob on the radio and the type of music you're listening to. Quote:
If he ran the cash register...well... hopefully he picked up some knowledge by osmosis. No, not right now. That amp is what makes your door speakers play. The radio. "HU" is cool audio guy slang for Head Unit, aka receiver, aka deck, aka source unit, aka radio. |
#33 |
There's a LOT to talk about if you're getting into car audio, but if you want to keep it simple for first steps then I'd also highly recommend the JL stealth box. One 10 or two 8's will be PLENTY unless you want to get loud. A single 10 moves more air than a single 8, so it can produce lower frequencies with less effort, but the same could be said for a 12, and a 15, and an 18... So you pick the size, power handling, and specs based on what fits your needs and the application. In this case, we have a tiny cabin and a small trunk, so a 10 is really your hard limit. A single 8 can do wonders in a small space. I have two 8's in individual sealed fiberglass enclosures driven by about 600 watts max RMS (dialed back of course), and it's more than I'll ever need, but I have headroom and the amp is never warm.
Good car audio is very subjective, everyone will have a different opinion of what's best. Having more bass is usually the first step. Most people jump in wanting WAY more than what they'll actually need, unless they're a teenager who wants to blow the glass out and piss off the neighbors. Then, at some point you'll want better overall quality and go with an aftermarket amp for mid and high drivers, maybe upgrade the head unit, and add some sound deadening to help control rattles and resonances (that can add unwanted color to even low volume music). Eventually some graduate to a really nice setup with additional sound deadening, a solid head unit with DSP (digital signal processing for better tuning, or a 3rd party DSP unit), with nice quality drivers all being driven individually for discreet adjustment of timing and frequency response. Most at this point will only use front component drivers with no rears for a clear "sound stage" and more accurate tuning. Once you get to this level you've begun to really appreciate good music on a system that's been adjusted to sound phenomenal. |
#34 |
Drives: 2015 scion FR-S
Noob question inbound
Where do I get a wiring kit? |
#35 |
Drives: FRS
amazon, or any stereo shop, your stereo installing friend should easily be able to provide one.
#36 |
Off Topic
Any walk-in car audio shop, Amazon, Crutchfield, Sonic Electronix, all kinds of places.
Match the wiring kit to what your amp requires. If the amp only needs an 8ga power wire, don't buy one with a 0ga wire on the premise that bigger is better. Also, make sure you even need a kit. If you're pulling signal from the door amp then you don't need RCAs. All I really needed was 15 ft of 12ga power wire and 2 ft of 12ga ground wire. I bought them singly for about $5 from a local shop, and then a couple of crimp connectors from Lowe's. |
#37 |
... I wouldn't tap any signals off the stock amp.
Garbage in = garbage out. You don't need to take a processed, speaker-level signal off a factory amp and feed it into a good amp and a good sub if your head unit has RCA subwoofer output(s). It's a very small time investment to pull the radio out and run a proper RCA line-level input to your amp. You'll also get the added benefits of the subwoofer controls (on/off, level, whatever is there... I don't know I don't have an FR-S) on the head unit actually working. If you tap the factory amp, those controls won't work. Chain, weakest link, you know the drill. |
#38 |
Off Topic
I didn't have the option for RCAs, unfortunately. I ended up getting a male and female plug and harness for the rear amp, putting those together, and pulling signal off the signal from the radio before it got to the amp.
#39 | |
Seems that although our HU was supposed to be "better" -- we didn't get some of the stuff that the FR-S got, like subwoofer RCAs on the HU. Instead we got eleventy billion harness plugs. Seriously, that's a lot of shit on the back of our radios. I was happy to yank that horrible BRZ HU out. I'm 10,000% happier with my Pioneer 4000NEX. |
#40 | |
Hit the road and I'm gone
What is missing in the concept as you describe it is the amount of excursion that the loudspeaker can achieve. A larger diameter speaker does not have to move as far to "push" the same amount of air but many 15" or even 18" woofers barely move at all. A 10" woofer can move the same amount of air, but must have much greater excursion to achieve the same volume level. You can accomplish the same thing with two smaller speakers that can push an equivalent amount of air, and they have less mass individually than the bigger diameter speaker. That is an advantage because lower mass usually means less distortion at a given volume level. Another thing that you can do is use a subwoofer amp with a smaller, long excursion speaker (designed to take the punishment) and have the amp internally equalized to increase the output (by way of greater excursion) the lower the pitch goes. This is what my home theater Klipsch subwoofer does; it is less than 12" on a side as a result, yet makes really wonderful bass. A large speaker is simpler and less complex to work into a system and often is more efficient. BUT, and this is important, the speaker cannot go much lower than its F(0), its resonant frequency. This number should be given as a specification along with power handling, frequency response, Xmax (excursion) and efficiency (in dB). Porting and other enclosure tricks are designed to get the speaker response closer to its F(0) but even there you really can't go lower than F(0). If you equalize the bass to go below F(0) then you MUST use a sealed cabinet (not ported) or the excursion will get out of control very quickly. This is not as straightforward as it seems, but there are some good books on speaker building out there and they all apply to car speakers too. It's just that the "enclosures" are sometimes a bit different (read: interior space of a door or a trunk). This website can provide some good information that also applies to cars: http://www.loudspeakerdesign.co.uk/ If you want to build an enclosure, I suggest that you start with an infinite baffle (sealed) box. They are easier to make. If you want to get adventurous, you might try a ported cabinet. Software is available free at this site: http://www.speakerbuilding.com/software/ I have used LspCAD Lite myself and it is an excellent product. Free! The main thing is to have fun and learn something new! Don't be afraid to dive in.
Slip, slidin' away.
#41 | |
IB are usually not perfectly sealed (air-tight), hence the baffle is, by definition, infinite. Like, a trunk, or behind a seat. Sealed boxes are, as the name implies, sealed airspace, therefore the baffle space is, by definition, finite. It's pedantic, yes, but if you're going to shoot the firehose of speaker box design information at the poor chap, it's worth noting.
| The Following User Says Thank You to keithr For This Useful Post: | Chimera (04-09-2015) |
#42 | |
The woofer doesn't need this, but may have an inductor in series to roll off the top frequency. A capacitor in line (series) with the woofer would block all low frequencies and defeat the purpose of the woofer altogether. Neither of these is usually very large on a tiny speaker like the stock one, so fine gauge wire in the inductor is OK to keep down the size of the coil. An electrolytic cap on the tweeter is pretty much standard practice. An inductor and a capacitor together form a first-order passive crossover. The impedance will not be a constant 4 ohms, but will vary widely with frequency and rise as the frequency does in the tweeter. If the speaker's impedance drops much below two ohms in the bass region, most amps are likely to blow up their output ICs due to excessive current. However, if each speaker (woofer and tweeter) are 4 ohms, then the "driven" load is considered to be 4 ohms also, parallel or not.
Slip, slidin' away.
| Audio Equipment Part out! AVH-x4500bt, illusion audio, OEM amp, arc audio and more!!! | CamryDS | Audio/Visual, Electronics, Infotainment, NAV | 25 | 10-23-2015 10:10 AM |
| Quick newb question | Gt86_nick | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-17-2014 08:58 PM |
| Newb with pics. | CBR600RR | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 07-10-2012 10:15 PM |
| newb rim question | carbonBLUE | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 06-29-2012 02:07 AM |
