Old 03-29-2015, 02:26 AM   #1
nguyen_er
nguyen_er's Avatar
Drives: 2013 Raven FR-S
Lights not working.
All my lights aren't working... The high beam signal is on but the stalk is in the neutral position, the high beams aren't even on. The side marker and tail lights are illuminated as well. I can't turn on the lights, signals or anything. I think the flasher relay is blown. Idk what else. Maybe the fuses for the lights? It's all Oem except my front turn signals are switch backs and the side markers are led.
Please help!!
nguyen_er is offline   Reply With Quote
Old 03-29-2015, 02:50 AM   #2
6spd
6spd's Avatar
check your fuse, replace a 15a fuse from the spare slot in fuse box, easy fix!
6spd is offline   Reply With Quote
The Following User Says Thank You to 6spd For This Useful Post:
nguyen_er (03-29-2015)
Old 03-29-2015, 06:31 AM   #3
nguyen_er
nguyen_er's Avatar
Thanks! I'll try it in the morning
Old 03-29-2015, 06:02 PM   #4
nguyen_er
nguyen_er's Avatar
Yeah it wasn't the fuse. I think it's either the electronic flasher relay or a shortage somewhere....
Old 03-30-2015, 05:05 PM   #5
KI_ZN6
KI_ZN6's Avatar
Please help!!
The OEM flasher unit is quite reliable so it may not be the flasher unit.
You might want to uninstall the front switchback LEDs and reinstall the factory bulbs and see if that resolves the problem. The side marker LEDs should not affect the turn signal lights because they operate independent from each other.
KI_ZN6 is offline   Reply With Quote
Old 03-30-2015, 08:46 PM   #6
nguyen_er
nguyen_er's Avatar
Thanks, I installed all the oem bulbs and still no go. I'm guessing since it's not the relay or a fuse. Then it has to be an electrical shortage somewhere. I hope it's covered under warranty since I've only had it since July 2013. Have an appointment with the dealership tomorrow.
Old 03-31-2015, 01:17 PM   #7
nguyen_er
nguyen_er's Avatar
Wow what the fuck. They're seriously going to tell me because I have leds in my dome light and my trunk that it's not covered under warranty anymore? That's some fucking bullshit.
Old 04-07-2015, 08:01 PM   #8
JohnSpartan
Drives: 2013 FRS
Please help!!
This exact thing happened to me today..... Did you ever get it fixed?? Do you know what it is???
JohnSpartan is offline   Reply With Quote
Old 04-07-2015, 11:21 PM   #9
nguyen_er
nguyen_er's Avatar
Yeah it was stupid as hell too. I swear I checked every single fuse. Thought it might have been the flasher relay. And changed all my light back to oem except I forgot my high beams. Ugh. I switch to some koya yellows or something forgot and they said the high beams were drawing too much power and blew a fuse. And on top of that because it was not Oem. It voided my warranty. Some bs. Had to pay 126. Ugh. Stupid.
Old 04-09-2015, 11:56 AM   #10
JohnSpartan
Drives: 2013 FRS
I am glad to hear you got it all fixed!!!
Which fuse was it?!? I thought I checked all of mine well too, but I was also working in the dark and a little frustrated at the time.
The Following User Says Thank You to JohnSpartan For This Useful Post:
nguyen_er (04-09-2015)
Old 04-09-2015, 12:27 PM   #11
wheelhaus
wheelhaus's Avatar
That doesn't necessarily mean your entire warranty is void, just that particular claim. Worst case they might give you grief over electrical system warranty issues in the future.
Old 04-09-2015, 01:29 PM   #12
8R6
8R6's Avatar
Drives: FRS
were they 55w bulbs?
8R6 is offline   Reply With Quote
Old 04-09-2015, 03:16 PM   #13
nguyen_er
nguyen_er's Avatar
I believe so. Should be 55w
Old 04-09-2015, 03:59 PM   #14
8R6
8R6's Avatar
Drives: FRS
i run 35w bulbs...
Car won't start - doesn't try to crank at all, but lights are working HELP cdo221 Issues | Warranty | Recalls / TSB 28 06-06-2018 07:30 PM
Valenti Tail Lights - Running Lights not working at all Antstronaut Cosmetic Modification (Interior/Exterior/Lighting) 12 08-10-2017 08:11 AM
Lights stopped working! LittleMonster Cosmetic Modification (Interior/Exterior/Lighting) 4 10-21-2014 12:15 PM
NEED HELP!! Reverse Lights Are Not Working! GarageBRZTuning Issues | Warranty | Recalls / TSB 2 11-28-2013 12:13 AM
Parking/fog lights not working THEWAKLER Cosmetic Modification (Interior/Exterior/Lighting) 2 10-09-2013 09:26 PM
