Old 04-08-2015, 08:15 PM   #6231
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Originally Posted by Vten View Post
Hmmm, red hi temp one ?
Also don't forget to use the oil and gas resistant Teflon on the fittings, as you most definitely will be getting blow by from the pcv/breather lines.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 04-08-2015, 09:42 PM   #6232
brianhj
Drives: 2017 Camaro 1SS
Originally Posted by sales@delicioustuning.com View Post
8.83 is only for intercooled kits, you're non-intercooled correct?
Sincerely,
Zach
I started out non-ic but I'm intercooled now with your flex fuel kit
brianhj is offline   Reply With Quote
Old 04-08-2015, 10:25 PM   #6233
Vten
Drives: Too heavy
Where do you get those oil and gas resistant Teflon tape ?
Vten is offline   Reply With Quote
Old 04-08-2015, 10:56 PM   #6234
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
In that case, just make one service order following this link: http://www.delicioustuning.com/service_work stating that you wish to upgrade to 8.83 and we can handle that for you.
Sincerely,
Zach
Old 04-08-2015, 11:10 PM   #6235
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
When I replaced the rear fittings on mine to brass items, I just used blue plumber's teflon tape that was lying around in my garage. It's been holding up fine so far.
But if I were to do it again i'd probably go with this: http://www.permatex.com/products-2/p...sealant-detail
It says they're oil resistant.
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
Vten (04-08-2015)
Old 04-09-2015, 10:07 AM   #6236
brianhj
I replaced the plastic fittings with brass ones (elbow + straight fitting). I didn't use any Teflon or thread sealant. How bad did I screw up?
I do have the issue with rpm dipping when moving from a complete stop. I've been revving to 2k+ before letting off the clutch to avoid it.
Old 04-09-2015, 01:46 PM   #6237
xxscaxx
Drives: 2013 SWP BRZ
I did. And the rpm still going up Everytime i spray the brake cleaner around the fitting .
Most likely the blower will be split apart again this weekend, I think that the best option.
Called mike@moto , and he said the car is should be okay to drive around, but I'm still worry if it'll do more damage to the engine .
When you spray, try spraying each side of the fitting. Make sure its not leaking from the hose side.
Do like Vten did and spray the fittings down with brake clean (use electronics part cleaner if you have it, less destructive on rubber/paint) and see if the idle fluctuates when you do. If so you have a leak. You can also use ECUtek to check your fuel trims and vacuum to see any potential leaks.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
brianhj (04-09-2015)
Old 04-10-2015, 12:04 AM   #6238
Chrisbrz14
Chrisbrz14's Avatar
Drives: Subaru Brz
Has anyone adjusted the vacuum actuator (whatever its called) on the back of the supercharger? Maybe it is just the nature of the supercharger but when starting from a stop up to about 2200 rpms the car is a little jerky. I seem to get a twitch of power after 2200-2300 rpms. Does this sound normal?
Chrisbrz14 is offline   Reply With Quote
The Following User Says Thank You to Chrisbrz14 For This Useful Post:
CarzCarzCarz (04-14-2015)
Old 04-10-2015, 01:07 PM   #6239
Dream20b
Y u do dis?
Just ordered mine!
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 04-10-2015, 01:54 PM   #6240
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
I have not adjusted mine, but I do experience what you are describing. To me it seemed more like the traction control causing it for me most of the time.
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
Old 04-10-2015, 04:41 PM   #6241
brianhj
Hey everyone, here to announce the official release of version 8.83 of our Innovate tunes for intercooled systems.
Version 8.83 of the Innovate tune will be a paid update, requiring a service fee of $65 to update from 8.65, available here: http://www.delicioustuning.com/service_work
Payment sent
The Following User Says Thank You to brianhj For This Useful Post:
Old 04-11-2015, 01:57 PM   #6242
FT86RGV
Quick question guys. Trying to replace the fittings on the back. For the life of me I can't figure out how to unscrew them. The fittings don't pass over the part of the blower that mounts to the intake manifold. Did you all just cut the bent part and unscrew the plastic fittings and screw on new straight brass fittings? If I want to put on right angle brass fittings would I need to remove the rear housing on the blower to have the space to screw them on?
FT86RGV is offline   Reply With Quote
Old 04-12-2015, 10:21 PM   #6243
brianhj
Did you remove the elbow from the supercharger?
Old 04-12-2015, 11:09 PM   #6244
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Its terribly difficult to replace them without removing the elbow, but it can be done with lots of patience and swearing. When I replaced mine to brass fittings, I simply snapped off the plastic fittings (helps when the weather is cold) then unscrewed the remaining piece.
But I found it next to impossible to screw in the new 90deg barbed fittings. Instead, what I did was get 2-piece fittings to make it 90deg. If that makes sense.
And get a set of crow foot wrench....it'll help massively.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
