Old 04-07-2015, 04:42 AM   #323
donoman
donoman's Avatar
Drives: '13 FR-S
@Dezoris I am also concerned. I don't think it's pinging/knocking but it doesn't exactly sound like VTEC, yo. It sounds like my Honda Insight valves when the motor was cold and the oil needed to be changed.
donoman is offline   Reply With Quote
Old 04-07-2015, 01:51 PM   #324
Dezoris
Dezoris's Avatar
Originally Posted by donoman View Post
Sounds to me like valvetrain noise. Or a cam chain. Something like that. It's not a good sound.
It does sound "raspy" like the old E46 M3's... not sure if that's a good thing though.
I had the aggressive VVT tuning removed from the tuning and noise was gone. No one has been able to explain mechanically what is causing the noise so I opted for safety.
Old 04-07-2015, 07:08 PM   #325
donoman
donoman's Avatar
Drives: '13 FR-S
@Dezoris
Thanks for the reply. How would I go about removing the aggressive VVT tuning on my OFT? I understand this question may be out of scope but I thought I would ask.
I ran an experiment today:
1) Smooth, light acceleration from start to high RPM - No buzzing
2) Hard acceleration from start to high RPM - Buzzing
3) Light accel around 4000 RPM - no buzzing
4) Hard accel around 4000 RPM - Buzzing
What I found is that the noise is not dependent on RPM as much as it is dependent on load. With that said, do the VVT maps account for load?
If they don't, then there is something being stressed in the motor due to load, which is causing the sound. This would make the hypothesis that the sound is due to valve overlap (or even simple mechanical resonance) a bad one. I believe both valve overlap and mechanical resonance should rear their ugly heads at a specific RPM, not necessarily a specific load.
Old 04-07-2015, 11:17 PM   #326
ztan
Drives: Toyota 86
The VVT maps are based on load/RPM and do change quite significantly as the throttle opens up at the top end. Open them up with ROMRaider and have a look. Kodename47 also has some nice VVT overlap spreadsheets that let you look at where the overlap numbers change.
ztan is offline   Reply With Quote
Old 04-08-2015, 12:21 AM   #327
donoman
donoman's Avatar
Drives: '13 FR-S
@ztan thanks for the advice!! Will check it out tonight. Is there a way for me to edit own VVT map and is it safe?
Old 04-08-2015, 01:30 AM   #328
ztan
Drives: Toyota 86
You can edit your own VVT (AVCS) maps, make sure you have a good grip on what you are trying to achieve and be able to log your engine well. I log knock parameters (FBKC, FLKC, IAM), fuelling trims and afr, and also calculate volumetric efficiency to see how well my engine is swallowing air.
Lots of good threads on NASIOC and other Subaru sites about engine tuning in general.
http://igotasti.com/vBforum/archive/...hp/t-4616.html
Td_d: "Do not take the process of AVCS tuning lightly. You will blow shit up."
Old 04-08-2015, 07:27 AM   #329
OkieSnuffBox
Drives: '23 BRZ Limited
I'm amazed that you still don't understand how cam timing and overlap can affect induction noise.
You remember the old Honda/Acura AEM intakes? The specifically used tuned resonance to force more air into the cylinder.
Or like these guys that modify the intake manifold to take advantage of intake reversion to increase midrange torque. http://www.metricmechanic.com/produc.../baby-six-m20/
Or like many cars today that have dual-stage intake manifolds one for low rpm and one for high rpm.
It's not difficult to understand, really.
Old 04-08-2015, 07:58 AM   #330
Dezoris
Dezoris's Avatar
I am not arguing the concept. But in the case of my motor it made virtually no difference in power delivery on dyno or in drivability. I have heard all the arguments as well and listened to multiple tuners explain not only VVT overlap and optimization but also tuners talk about how optimizing timing to increase power at higher RPM is safe too, and all the promises. The tuners generally want one thing, to show better results on a dyno. I have lost a lot of faith in plenty of tuners for this platform and and companies from owning this car.
And in this case the VVT optimizations it raised red flags, and everyone who was in the car who heard the "resonance" said it sounded horrible. At to have it at 3000-4000 rpm under partial throttle every shift is absurd for.daily driving.
Old 04-08-2015, 01:15 PM   #331
donoman
donoman's Avatar
Drives: '13 FR-S
@Shiv@Openflash Any chance you have a "non-aggressive VVT" tune available for OFT as Perrin has provided @Dezoris for their tune? I love everything about the OFT Stage 1 tune except the sound is very concerting.
Thanks in advance!
Old 04-08-2015, 01:46 PM   #332
OkieSnuffBox
Thanks in advance!
It is like a public concert. Were you looking for disconcerting or concerning?
I just find this all quite humorous. Buy a lightweight, loud, rough riding sports car, start modifying it and then complain about a brief harmless noise when accelerating hard.
Old 04-08-2015, 02:00 PM   #333
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
The real answer is EZ30 swap!! Ok I will show myself out...
Old 04-08-2015, 02:26 PM   #334
Shady195
Drives: '13 10 Series FRS #1203
Thanks in advance!
Part of what makes the OFT Stage 1 tune for those without headers so good is the aggressive VVT where the torque dip is concerned.
Shady195 is offline   Reply With Quote
The Following User Says Thank You to Shady195 For This Useful Post:
JB86'd (04-08-2015)
Old 04-08-2015, 03:23 PM   #335
donoman
donoman's Avatar
Drives: '13 FR-S
It doesn't matter whether it's my Porsche, my BMW or my Scion, I'm always looking for the best. "Harmless" is an assumption ... it just doesn't sound smooth like the VTEC hitting on my Honda's. I've never owned a Subaru before, so that may be what is tripping me out. I've never heard this kind of noise in any German car.
Old 04-09-2015, 04:56 PM   #336
OkieSnuffBox
You do understand the difference between VTEC and VVT, right?
Variable Valve "Butterfly" Exhaust dlux Southern California 19 02-22-2016 06:21 PM
First tank OFT E85 tuning. Noise? Tromatic Software Tuning 2 02-20-2014 05:43 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 01:47 AM
Exhaust Noise that goes away after warmed up FastLane1000 Engine, Exhaust, Transmission 10 08-15-2013 10:06 PM
Knock/valve slap/crick noise under accel yomny Issues | Warranty | Recalls / TSB 47 01-07-2013 08:53 PM
